Do i lose power / rpm when connecting a fan splitter to motherboard ? ( 1 plug to 4 fans )
287 (0.69/day)
System Name SYSTEM
Processor RYZEN 7 5700X
Motherboard TUF B550M GAMING PLUS
Cooling AG620 CPU COOLER
Memory 16GB RAM DUAL CHANNEL 3200MHZ STOCK
Video Card(s) RTX 4070 GIGABYTE 12GB WINDFORCE
Storage 1TB HDD 256GB SSD
Display(s) LG ULTRAGEAR 144HZ
Case AIGO DARK FLASH
Audio Device(s) MOTHERBOARD AUDIO
Power Supply XPG ADATA PYLON 650W
Mouse REDRAGON COBRA M711 V2
Software WINDOWS 11
Hello
I plan to install 4 more case fans ( to help ssd temps)
2 top exhaust , 2 bottom intake
i´ve came across this adapter
i don´t wan´t to use it full molex due to constant 100% rpm
but i´m wondering , is there any bottleneck to the interface ?
reduced rpm / speed etc
if so , what is the best alternative ?
unfortunately my PSU has only molex connections
thanks
5,252 (0.88/day)
System Name [Daily Driver]
Processor [Ryzen 7 5800X3D]
Motherboard [MSI MAG B550 TOMAHAWK]
Cooling [be quiet! Dark Rock Slim]
Memory [64GB Crucial Pro 3200MHz (32GBx2)]
Video Card(s) [PNY RTX 3070Ti XLR8]
Storage [1TB SN850 NVMe, 4TB 990 Pro NVMe, 2TB 870 EVO SSD, 2TB SA510 SSD]
Display(s) [2x 27" HP X27q at 1440p]
Case [Fractal Meshify-C]
Audio Device(s) [Fanmusic TRUTHEAR IEM, HyperX Duocast]
Power Supply [CORSAIR RMx 1000]
Mouse [Logitech G Pro Wireless]
Keyboard [Logitech G512 Carbon (GX-Brown)]
Software [Windows 11 64-Bit]
You have a 4070, buy a less shit PSU before your computer explodes.
Also if your motherboard only has 1 fan header... and you have a 4070... Re-evaluate your entire build.
287 (0.69/day)
System Name SYSTEM
Software WINDOWS 11
my psu is a core reactor 650w and the motherboard is a tuf b550m
i guess they arent shit but anyways
2,007 (0.62/day)
Processor Intel i5 8400
Storage 1TB 980 Pro
Software W11 Pro
[Phonetically] Ka-Boom .com :laugh:
Do some math on rated power draw of all fans combined and cross reference with amount a single fan header can supply (1A typically). Probably better off buying a fan hub or just using the headers on your board.
Regeneration
NGOHQ.COM
3,131 (0.45/day)
I always use 3-way PWM splitters for automatic speed control through the motherboard. Never had a problem.
Just be sure to check the fans' power rating and motherboard's manual for fan headers amp/watt rating.
On recent ASUS motherboards its normally 1A, maximum of 12W per header.
4-way maybe too much much depends on the fans you're using.
287 (0.69/day)
System Name SYSTEM
Software WINDOWS 11
I always use 3-way PWM splitters to monitor and control case fans. Never had a problem.
what would happen , they would stop spinning or reduced rpm?
287 (0.69/day)
System Name SYSTEM
Software WINDOWS 11
Do some math on rated power draw of all fans combined and cross reference with amount a single fan header can supply (1w typically). Probably better off buying a fan hub or just using the headers on your board.
a hub do you mean something like this ? unfortunately i´ve already used all my motherboard connections
this is the motherboard rating
3,316 (1.69/day)
Power Supply Corsair RM750x
Mouse Logitech M575
Best to get a fan hub that's powered via Molex or Sata power connector. That one does NOT look like it has an input for power.
287 (0.69/day)
System Name SYSTEM
Software WINDOWS 11
can you send me a link / model to one please?
i didn´t wan´t to use full molex due to 100% noise and my motherboard already has all the pins busy
3,316 (1.69/day)
Mouse Logitech M575
Looks like you have 4 fan headers. So possibly 3 could be used while the CPU uses 1.
Understand the molex or sata power would go to the HUB and the HUB should have 1 PWM input from the motherboard and multiple PWM outputs for the fans. In this way the motherboard will still control the speed of the fans.
How many fans to you have in total for your system (that you are going to use) and are they all of the same type? Do you know their power rating?
287 (0.69/day)
System Name SYSTEM
Software WINDOWS 11
Understand the molex or sata power would go to the HUB and the HUB should have 1 PWM input from the motherboard and multiple PWM outputs for the fans. In this way the motherboard will still control the speeds of the fans.
there aren´t that much options here in brazil since i can´t make a good choice
do these two ones i´ve linked are likely to run into problems?
i found this one , wondering if it is better
Ruru
S.T.A.R.S.
12,903 (2.95/day)
Jyväskylä, Finland
System Name 4K-gaming / media-PC
Processor AMD Ryzen 7 5800X / Intel Core i7-6700K
Motherboard Asus ROG Crosshair VII Hero / Asus Z170-K
Cooling Arctic Freezer 50 / Alphacool Eisbaer 240
Video Card(s) RTX 3080 10GB / RX 6700 XT
Storage 3.3TB of SSDs / several small SSDs
Audio Device(s) Creative 2.1
VR HMD Oculus Rift CV1
Just make sure that the power draw doesn't exceed 1A.
12,483 (5.78/day)
Midlands, UK
System Name Nebulon B
Cooling be quiet! Dark Rock 4
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
Depends on how much power a fan header can supply (you can see it in your motherboard's manual), and how much power your fans need (you can see it on the sticker on the fan). Amps and Watts add up. As long as you're still within the rating of the fan header, you're good.
3,316 (1.69/day)
Mouse Logitech M575
Getting a splitter is the simplest solution as others have advised being careful to stay in the power rating of the fan header. If you don't need a hub then use a splitter. FH-10 would be better if you need a hub in my opinion because it's powered but you still have to be careful not to exceed the power rating the power cable is supposed to provide.
The solution that will be ok for you depends on ...
- How are you using your current fan headers?
- How many fans total do you need to support?
- Are the fans all of the same type?
- What are their amp ratings?
Answers to these questions might determine what kind of splitter do you get, how many, or if a hub is a better choice.
287 (0.69/day)
System Name SYSTEM
Software WINDOWS 11
i´ve checked the case and i plan to buy 2 splitters
i will use 1 splitter with 3 fans ( 1 cooler master sickleflow fans and 2 deepcool rf120)
the another splitter will use the same configuration
so it would be 2 splitters with 3 fans each
so the math says it won´t exceed (0.15 A for each fan approx)
can i get this one and use it safely ?
i found this one as well but i guess it will run full speed
3,316 (1.69/day)
Mouse Logitech M575
sickleflow 120 = 1.8W , 0.15A
deepcool rf120 = 1.32 W, 0.11A
So if I just take your most power hungry fan and multiply by 3 = 0.45A (5.4w) max load per 3-way splitter. I guess that looks ok.
Typically one fan on a splitter will be reporting the RPM so by having different model fans on the same splitter the real RPM might be a little different and the noise profile may not be uniform.
287 (0.69/day)
System Name SYSTEM
Software WINDOWS 11
so i´m getting this hub right ?
i don´t plan to use more than 3 really
also , on a side note , i plan to use 2 front case fans ( 1 middle , 1 lower )
2 at the top
1 back exhaust
and 2 bottom intake
i only plan to improve nvme temps a bit
it is not that high anymore but i still want to improve it
this is my case https://www.darkflash.com/product/drx70
thanks
3,316 (1.69/day)
Mouse Logitech M575
2 at the top
1 back exhaust
and 2 bottom intake
thanks
Ok so you have now changed your plan from 6 fans to 7 is that correct?
287 (0.69/day)
System Name SYSTEM
Software WINDOWS 11
i mean 3 fans on the splitter because i already have 3 case fans on my system already
but i would be 2 front , 2 top , 1 back , 2 bottom really
the rest of my system has good temps , my aim is to improve the airflow near the nvme a bit
3,316 (1.69/day)
Mouse Logitech M575
Sorry I have to stop and ask another question. Currently you have 4 deepcool rf120 and 2 sickleflow 120 fans correct? What model is the 7th fan? (2+2+1+2=7)
287 (0.69/day)
System Name SYSTEM
Software WINDOWS 11
i already have 3 sickleflow only ( would buy 4 more deepcool)
3,316 (1.69/day)
Mouse Logitech M575
(side question) Why not 4 sickleflow instead so they all match?
12,483 (5.78/day)
Midlands, UK
That's another thing. Personally, I wouldn't mix different types of fan on the same splitter for accurate RPM reporting, but each to their own.
