AsRock
TPU addict
- Jun 23, 2007
- 18,195 (3.19/day)
- UK\USA
Processor | AMD 3900X \ AMD 7700X |
Motherboard | ASRock AM4 X570 Pro 4 \ ASUS X670Xe TUF |
Memory | Patriot 2x16GB PVS432G320C6K \ G.Skill Flare X5 F5-6000J3238F 2x16GB |
Video Card(s) | eVga GTX1060 SSC \ XFX RX 6950XT RX-695XATBD9 |
Storage | 2xIntel 80Gb (SATA2) Crucial MX500 \ Samsung 860 1TB +Samsung Evo 250GB+500GB Sabrent 1TB Rocket |
Display(s) | Samsung 1080P \ LG 43UN700 |
Case | HTPC400 \ Fractal Design Torrent. |
Audio Device(s) | Yamaha RX-V677 \ Yamaha CX-830+Yamaha MX-630 Infinity RS4000\Paradigm P Studio 20, Blue Yeti |
Power Supply | Seasonic Focus 650w \ Seasonic Prime TX-750 |
Mouse | Steelseries Sensei wireless \ Steelseries Sensei wireless |
Keyboard | Logitech K120 \ ROCCAT MK Pro ( modded amber leds ) |
Benchmark Scores | Meh benchmarks. |
There actually can be a difference with HDMI cables, but not generally with shorter cables(sub-10ft).
Longer lower quality cables can actually artifact at higher resolutions. For example, I've got a 25ft cable that shows green spots on the screen when used at 1080p, but works fine at 720p. I have a slightly higher quality 25ft cable that handles 1080p flawlessly. Mind you when I say slightly higher quality, I mean I spent $30 for a 22AWG cable vs. $20 for the 24AWG cable. No need to spend $100 on an HDMI cable, that is just ripping people off.
Could not agree more
I use a 25 foot HDMI cable without any issue but it is thick as hell some were around 10-12mm thick which makes it near as thick as the cable and is triple shielded and claims to be able to handle more than 1920x1080.
There is a limit on whats good and bad although $10 HDMI can be good or bad due to build quality like how well the hdmi plugs are connected.
To me there is no reason to spend more than $30 on a HDMI cable unless your not lucky in finding a good 25 foot one for less. I got mine on a sale.
To me go for brands that you know people had good luck with unless there falling for the Monster BS which i hated even in the analog days as i found that they strangled the sound..
