- Sep 9, 2006
- 994 (0.14/day)
- SoCal
Processor | Intel C2D E6420 (3.2 gHz @ 1.365v) |
Motherboard | Gigabyte 965P-DS3 |
Cooling | Zalman CNPS9500 LED |
Memory | 4 x 512mb Corsair XMS2 DDR2 667 |
Video Card(s) | Visiontek HD 4870 512mb |
Storage | 200gb Maxtor SATA, 400gb WD SATA |
Audio Device(s) | Audigy 2 ZS |
Software | Windows XP Pro SP2 |
Hi, I've found this forum to be useful in the past so naturally, I decided to ask here first
Anyways, I've found something wierd that happens with my reformats... if I install Windows XP (without SP2 already on it), my driver cd for the Intel D865PERL board shows up and installs everything normally. However, when I install with a XP with SP2 already on it, the cd fails to start up (the intel sign would show up, then freeze for 30-45 sec and then say that the "internal process timed out"). My question is, is there any fix to this? I have a serious problem to this because my SoundMAX 4XL driver (for the integrated sound) is on the cd, and because I had reformatted using the XP with SP2 included, the cd would not start up. Also included in the cd are the chipset updates and the driver for the integrated LAN (which I got off the Intel website).
Is there any difference to "licensed/licensing" versions of XP and "unlicensed" versions of it? I have reformatted using 6 different copies of XP (2 unlicensed w/o sp2, 4 licensed w/ sp2), and I was wondering if that had anything to do with it... any help would be appreciated
System specs (if needed):
P4 2.8E w/ HT
Intel D865PERL mobo
2gb Corsair XMS DDR-400 ram
Sapphire x800 GTO
80 gb WD on IDE
160gb WD on IDE
200gb Maxtor on SATA
P4 2.8E w/ HT
Intel D865PERL mobo
Sapphire x800 GTO
80 gb WD on IDE
160gb WD on IDE
