DTS DCH Driver for Realtek [DTS:X]
1,425 (3.43/day)
I made this video with SPDIF (Interactive), hence the multichannel. I purchased Sound Unbound, so I just download it.
Also note, you DONT need to disable enhancements or remove the Realtek APO to get multichannel on SPDIF.
This specification I get noise, not enough sample aggregate.
26 (0.04/day)
Hello Ferather, as always, thanks for your work!
I must have somehow lost RTK APO Tool during several cleanup reinstalls, although I clearly remember having it installed, and it doesn't seem to be present in the latest bundle.
May I ask for your help how to find the installer?
Thanks!
1,425 (3.43/day)
It should be in the older packages, you should store it if you still need it, I removed it as it can cause a problem (adding empty lines).
My AMD R7 (HDMI 1.4 to SPDIF) still produces about 10% better audio quality than my ALC 889 (SPDIF), better hardware, both are programmed identically.
On both devices I could not reach 8x 192khz, only 6x 192khz or 8x 96khz. They are quoted max 768khz, which is actually 1152khz.
805 (0.64/day)
System Name Dell Inspiron 7375
Processor AMD Ryzen™ 7 2700U Mobile Processor with Radeon™ RX Vega 10 Graphics
Memory 16GB (total) 2400MHz DDR4 SODIMM
Video Card(s) Radeon™ RX Vega 10 Graphics
Storage SanDisk X600 SATA SSD 512GB
Display(s) BOE NV13FHM
Audio Device(s) Realtek ALC3253 (Dell Labelling) ALC255 (Real name)
View attachment 220956View attachment 220957
Could you please provide a link to that HDMI to SPDIF tool you are using?
1,425 (3.43/day)
Sorry I forgot the '@' in my last response to you.
@CityCultivator, https://www.techpowerup.com/forums/threads/dts-dch-driver-for-realtek-dts-x.279972/post-4619748
Edit: Please note I am only using the digital portion of the extractor/convertor, I have not tried analogue and the DAC it comes with.
As a secondary post, if an audio device has a bad DAC or generally cheap components, lossless analogue will not be lossless when you hear it.
01100010 01101001 01110100 01110011 01110100 01110010 01100101 01100001 01101101 01101001 01101110 01100111 00100000 01110111 01101001 01101110 01110011
@dododo, USB and Virtual devices or not natively supported by the current, provided DTS APO4, I am still looking into it.
Also note, speaker and headphone detection is based on pin config data, SPDIF and HDMI do not use pin config.
Multichannel mode (home theatre), will enable freely for anything above 2 channel.
212 (0.28/day)
I must be a cyborg idiot, because I just read this:
"01100010 01101001 01110100 01110011 01110100 01110010 01100101 01100001 01101101 01101001 01101110 01100111 00100000 01110111 01101001 01101110 01110011"
as a tune in my head.
Anyway, great work Fer.
PM me for further missions.
STDINPUT
340 (0.13/day)
Processor AMD Phenom II X4 925
Motherboard Gigabyte GA-78LMT-USB3 R2
Memory 4 GB DDR3 1333Mhz
Audio Device(s) onboard Realtek ALC892
Power Supply Seasonic S12II 620w (SS-620GB)
Software Windows 10 Education x64 21H2
1,425 (3.43/day)
@dododo, don't worry, any changes Realtek release will come with this package, if necessary I can make a Win11 package. Thanks for the heads up. :)
@erpguy53, thanks, I will look into this at the weekend. If you have an ALC 2XX, you will find this post helpful (its due to OEM config).
Side note, a good friend and fellow gamer visited yesterday, he uses a 2 channel rocker chair, he was blown away when I played 360 audio over 5.1 (7.1 with virtual side).
He has decided to invest in a multichannel setup, although I had no idea what to suggest as SPDIF is not properly supported yet (if at all).
I am of coarse using HDMI (SPDIF), and DTS Interactive (DTS Surround), with DTS:X APO4 (in multichannel mode).
MichiW
6 (0.02/day)
Need a little help :
With the RTK Device Tool there is a test file which says :
Open the 'RTK Device Tool', press the first red 'X' (left), the text will now flash red (has RTKHDAUD.dat), now press 'Get Policy Driver', and press 'Save'.
but in my windows it says "no RTKHDAUD.dat" in green
How to geht this flashing in red with "has RTKHDAUD.dat" ??
"Location (copy for later): Windows\System32\drivers\RTKHDAUD.dat" i dont have that file in this folder
19 (0.12/day)
System Name Ghost Spectre Asus ROG Z390F Gaming
Processor Intel Core i3 9100F
Motherboard ASUS ROG Z390 F Gaming
Cooling Corsair LL120 RGB LED PWM Fan's
Memory 32GB 3200er CORSAIR VENGEANCE RGB
Video Card(s) Geforce GTX ****
Storage Seagate Barracuda and Sandisk SSD combinated RAID 0 Striping
Display(s) Two Samsung Displays (1 Digital Tv and 1 older Analog 2ms gaming Monitor) + Smart Tv
Case Rare Oldschool NZXT LED Gaming Case
Audio Device(s) Creative IRoar Rock with Subwoofer & Logitech Z906
Mouse Hyrican RGB Set
Keyboard Hyrican RGB Set
Software Ghost Spectre's Modded Windows 11 & much more stuff
Benchmark Scores Not tested yet
@MichiW
did he put a tick in the list after pressing "Get Policy Driver"?
it may well happen that your chip config is not recognized for various reasons and of course nothing is active after pressing "get policy driver"
if not it is because it is necessary that at least 1 tick is set in the settings in order to generate a rtkhdaud.dat at all
if you set any tick manually and save it, a file should be created directly
otherwise there are several custom configs (rtkhdaud.dat from mod packets) and other devices to download here in the forum
1,425 (3.43/day)
@MichiW
Sorry I was away for a few days, the RTKHDAUD.dat will only flash red if you currently have a policy file on the system, else it will be green.
When it is green, simply press 'get policy driver' and the 'save', once you have made the file, it will flash red.
Edit: I forgot to update the tweak list for DTS, don't enable Realtek NeoPC, it makes noise.
You should see the following in your Realtek panel (in some cases you might not, due to OEM), and have 24 bit recording.
Quick explanation:
When the driver loads, it will normally load the in-built policy (built into device by OEM), if a policy file exists, it will ignore the in-built policy and load the file policy.
If you have a policy file on the system, in order to make sure only the in-built is loaded (and saved), you delete the file then restart the computer.
When you make the file, the app will pull the policy from your in-built OEM policy, after this you can modify it (add-remove).
To delete a policy file, either delete it manually, or press the red 'X' next to the flashing red text.
Note: Windows audio drivers (not Realtek) will ignore the in-built and file policy, its not part of the Windows driver to read it.
1,425 (3.43/day)
Resized 'RTK Device Tool' by @leveltrauma, let me know if you prefer it.
Secondary note: Sound Unbound should be working on USB and virtual devices (and more), however you cannot change modes using the Ultra app at this time.
DTS seem to have programmed 'HDAUDIO' devices and 'Speaker pin', as the base for the service and app to unlock its modes (when using stereo).
It may be possible with some regedits, or in some cases policy settings (for SPDIF) to trick 'HDAUDIO' and-or 'Speaker pin'.
If anyone manages to find a clean and stable (no CPU spikes or crashing) way to bypass both issues let me know, your name will be credited.
There are a few possible methods, as mentioned regedits, policy (which effects the Realtek APO), or direct file patching.
Pro tip: Backup your Windows partition (full partition) before playing around, nobody likes to re-install Windows.
Reminder: If you like what you hear, buy a Sound Unbound license, I don't make DTS technology.
  • RTK Device Tool - leveltrauma.zip
19 (0.12/day)
doubled sound is because of stereo mix. sorry
1,425 (3.43/day)
Indeed, I also had it working on bluetooth and virtual, its very possible the mod came from one of Alan's earlier releases, after a Windows re-install the mod is gone.
However, this being said (and I said this the last time also), there was issues with CPU spikes and HDMI, and in some cases SPDIF, other issues.
35 (0.15/day)
System Name Destroyer Class
Processor AMD Ryzen 9 3900X
Motherboard TUF GAMING X570-PLUS (WI-FI)
Cooling MasterLiquid ML240L RGB
Memory 2X - G.Skill Trident Z Neo Series RGB 32GB (2 x 16GB) DDR4-3600 PC4-28800 CL16 Dual (64GB 4 x 16GB)
Video Card(s) AMD 5700XT
Storage PCI-E 4.0 Nvme 1TB 5GB/s - PCI-E 3.0 Nvme 1TB 3GB/s - 2TB 7200rpm HD
Display(s) ASUS TUF GAMING VG259QM - Vizio M Series 4k Dobly vison
Case Lancool-205
Audio Device(s) Realtek S1200A
Power Supply 750Watt
Mouse Corsair Dark Core
Keyboard Corsair K95 Platinum
Software Windows 10 pro
I cant listen to anything with less then 6 speakers a proper sound field is so important for immersion in gaming or content watching and honestly you work ferather really is pretty impressive with out you i would of never been able to hook my z906 speakers up to my onkyo integra receiver the sound is just incredible and handles the extra power with no issues even vs the 192/24 of just hooking the z906 up to my pc directly your friend could just get a home theater 5.1 set up there are many of them to pick from if he is outputting dts all of them should work
1,425 (3.43/day)
@ajf64, you are very welcome, I focused on keeping things clean and functional. While I handle the driver, files and other aspects, all feedback has come from the community.
Hopefully someone will find a clean way to overcome the final two unlocks (HDAUDIO, and speaker-headphone pin) for USB and other devices.
Edit: I also cannot stand stereo, although DTS does do a great job with stereo, its multichannel all the way for me.
USB and other devices should be working with the following:
Ok I managed to work out what to do and got 'Virtual Audio Cable' to work as before. So I installed VAC, disabled the audio device and then applied the 'DTS Settings' as normal (see video here).
Note: To apply the 'DTS Settings' to 'Virtual Audio Cable', use FX Config to open regedit as trusted installer, then file > import (once edited).
Then I edited the registry for the device, using FX Config to open 'Jump to Properties Key' which opens regedit on the right place, I added the Realtek config and HDAUDIO.
I then found and set the device properties settings key to my ALC889, which I got from my Realtek speakers (you can also use headphones settings).
{3ba0cd54-830f-4551-a6eb-f3eab68e3700},1
{3ba0cd54-830f-4551-a6eb-f3eab68e3700},4
{3ba0cd54-830f-4551-a6eb-f3eab68e3700},6
Restart your computer when done.
19 (0.12/day)
@Ferather a really quick and easy solution! :) keep it up bro
I've already done it with registry tweaks on Boom3D and HDMI (Nvidia) to activate
- Mono
- Stereo
- Quadrophony
- Surround
- 5.1
- 5.1
- 6.1
- 6.1
- 7.1
- Dolby Atmos for Home Theater
In other words to activate all channel layouts.
but does not work 100% yet because some are not supported so far @Ferather maybe you will be able to completely unlock all channels in this regard
VAC generates almost all layouts
(and for recording devices currently up to 10 channels - surely more possible.) ((interessting for Stereo Mix or Sonic Virtual))
With RegFromApps or similar tools it should be possible to see changed reg entries when creating a virtual cable and import them to the respective device, but in my opinion that is not all that needs to be changed.
Edit: of course also works for analog AUX/speaker/headphone devices (and possibly SPDIF?)
1,425 (3.43/day)
I have not seen key data for more than 7.1 channels, or third-party (such as DTS-Dolby), I do know the APO4 service supports 11.1 and maybe more.
Edit: You are welcome.
19 (0.12/day)
@Ferather that is absolutely correct, and also just feasible with "Audirvana Studio" (bombastic vst3 & more supported streaming app)
and some VST3 plugins like Dolby Atmos Music Panner or Auro3D plugins. to stream more than 7.2.4 or 11.1 surround/immersive encoded at all correctly.
or with which codecs except Dolby AC4 and co. could that even be implemented?
Since Boom & Virtual Audio Cable have a similar structure with regard to the root device, it is possible, for example, to export the properties REG entry from VAC,
Change certain required points about Boom3D properties, import them and use more than just stereo channels;
that is actually my plan but I have not yet found out which key gives the channels completely free
on HDAUDIO - Nvidia HDMI, I have already managed to fully activate 6.1 and the other channels of the virtual audio cable, but this device is basically 7.1 capable from the start, but still not 6.1 by default ..
if I just knew which key or entry in the driver is responsible for it! .. hmmm
1,425 (3.43/day)
You should already be able to send the maximum number of channels an encoder supports, for example a DTS-HD MA 11.1 track, this will be bitstreamed directly, and the receiver supports the 11.1.
If you was to decode it to PCM, while all the channels might be there (separately), you will end up with 7.1 and ignored channels, or downmixed 11.1 to 7.1.
In terms of PCM, you will need to edit the format keys from example 06 (5.1), to 12, and any other additional keys.
In terms of Boom3D, it should be the same as the guide, but it also uses its own SFX, MFX keys, you will need to manually input them, else I don't know sorry.
19 (0.12/day)
- Mono
- Stereo
- Quadrophony
- Surround
- 5.1
- 5.1
- 6.1
- 6.1
- 7.1
side notes/pictures
:rockout:
@Ferather
Thanks for the info! will deal with it a little & report back later :kookoo:
1,425 (3.43/day)
@AudiophiIe
Nice to see 10 channels on a PCM device, although I can see the config is still 7.1. Would be amazing to see this this on an actual SPDIF device.
PKEY_AudioEndpoint_PhysicalSpeakers = "{1DA5D803-D492-4EDD-8C23-E0C0FFEE7F0E},3"
PKEY_AudioEndpoint_FullRangeSpeakers = "{1DA5D803-D492-4EDD-8C23-E0C0FFEE7F0E},6"
In my driver for SPDIF and DTS Interactive (and also the settings.reg files), I use:
"{1da5d803-d492-4edd-8c23-e0c0ffee7f0e},3"=dword:0000003f
"{1da5d803-d492-4edd-8c23-e0c0ffee7f0e},6"=dword:0000063f
This translates to: process 8 channels, as 6 out (virtual side). A format key will look like the following:
41,00,06,00,01,00,00,00,FE,FF,06,00,80,BB,00,00,00,94,11,00,18,00,20,00,16,00,20,00,3F,00,00,00,03,00,00,00,00,00,10,00,80,00,00,AA,00,38,9B,71
The ones I coloured red, are the ones that specify the number of channels, for the final format, the final number of channels out.
The first 06, in the example might not be present, and instead a produced hex from the original number in the driver.
Please note, the PCM device(s) must support the changes you make, else it will not work.
More info on bitstreaming with SPDIF and HDMI here.
Form factor (link here):
It's possible to convert the form factor for 'SPDIF' and 'HDMI' to 'Speakers' or 'Headphones' to get stereo detection, however it will likely break digital bitstreaming (PCM should work as normal).
It would be better if DTS APO4 detected the number of channels via PKEY_AudioEndpoint_PhysicalSpeakers along with the form factor for SPDIF-HDMI endpoints.
Currently it reads and supports both PKEY_AudioEndpoint_PhysicalSpeakers and form factor, but not directly for stereo.
Essentially reading SPDIF and HDMI and checking the PhysicalSpeakers key for channel to mode.
leveltrauma
21 (0.08/day)
After reading about new efforts here I got new motivation to play with settings change + results - but mostly of time is wasted with the guids and the correlation to speakers etc.
I found a small commandline tool @github which also monitors changes in regedt from previously selected audio device.
Credits 100% going to Ravin Wang for sharing his sourcecode to the masses. I only compiled it to binary for x32 and x64. Uploadlink attached to post.
Small side note: compiled without VS's library which implements the castrated spectre libs ( called: Spectre-mitigations-libs )
Here some output from terminal:
Code:
            DeviceID: {0.0.0.00000000}.{7b58568e-eac8-40ef-85da-19dd2aff3d1f}
          DeviceName: Digital Output (SPDIF) (DTS DCH Audio Device)
 DeviceInterfaceName: DTS DCH Audio Device
               State: Active
[i] Show all properties
[x] Quit    [b] Back    [f] Forward    [p] Go-up    [?] Print this page
>>> i
    {B3F8FA53-0004-438E-9003-51A46E139BFC}/15:
                                               E5 07 08 00 01 00 17 00 0B 00 16 00 00 00 3D 00 - Õ.............=.
                    DEVPKEY_Device_DeviceDesc: Digital Output (SPDIF)
    {B3F8FA53-0004-438E-9003-51A46E139BFC}/06: DTS DCH Audio Device
    {B3F8FA53-0004-438E-9003-51A46E139BFC}/02: {1}.HDAUDIO\FUNC_01&VEN_10EC&DEV_1220&SUBSYS_1462CC35&REV_1001\5&273F6C07&2&0001
    {83DA6326-97A6-4088-9453-A1923F573B29}/03: oem13.inf:ed86ca11f23b705c:IntcAzAudModel:6.0.9209.1:hdaudio\func_01&ven_10ec
                   DEVPKEY_Device_InstallDate: 8/23/2021
                   DEVPKEY_Device_ContainerId: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
    {9637B4B9-11EE-4C35-B43C-7B2452C993CC}/01: {39F6387B-C9CC-42F3-A457-28FDAF817E6F}
                DEVPKEY_Device_EnumeratorName: HDAUDIO
                PKEY_AudioEndpoint_FormFactor: SPDIF
               PKEY_AudioEndpoint_JackSubType: {DFF21FE5-F70F-11D0-B917-00A0C9223196}
    {B3F8FA53-0004-438E-9003-51A46E139BFC}/05:
                                               58 00 00 00 02 00 00 00 05 00 00 00 08 00 00 00 - X...............
                                               00 00 10 00 80 00 00 AA 00 38 9B 71 0A 00 00 00 - .......¬.8.q....
                                               EA 0C 10 00 80 00 00 AA 00 38 9B 71 0B 00 00 00 - Û......¬.8.q....
                                               EA 0C 10 00 80 00 00 AA 00 38 9B 71 0C 00 00 00 - Û......¬.8.q....
                                               EA 0C 10 00 80 00 00 AA 00 38 9B 71 92 00 00 00 - Û......¬.8.q....
                                               00 00 10 00 80 00 00 AA 00 38 9B 71             - .......¬.8.q
                 DEVPKEY_DeviceClass_IconPath: %windir%\system32\mmres.dll,-3013
    {840B8171-B0AD-410F-8581-CCCC0382CFEF}/00:
               PKEY_AudioEndpoint_Association: {00000000-0000-0000-0000-000000000000}
         PKEY_AudioEndpoint_FullRangeSpeakers: 1599
          PKEY_AudioEndpoint_PhysicalSpeakers: 63
                   PKEY_AudioEngine_OEMFormat:
                                               |          wFormatTag: WAVE_FORMAT_EXTENSIBLE(0XFFFE)
                                               |           nChannels: 2
                                               |      nSamplesPerSec: 48000
                                               |     nAvgBytesPerSec: 192000
                                               |         nBlockAlign: 4
                                               |      wBitsPerSample: 16
                                               |              cbSize: 22
                                               | wValidBitsPerSample: 16
                                               |       dwChannelMask: KSAUDIO_SPEAKER_STEREO
                                               |           SubFormat: KSDATAFORMAT_SUBTYPE_IEC61937_DOLBY_DIGITAL
    PKEY_AudioEndpoint_Supports_EventDriven_Mode: 1
Code:
               State: Active
!!-->[DeviceID: {0.0.0.00000000}.{7b58568e-eac8-40ef-85da-19dd2aff3d1f}][DTS DCH Audio Device][property: {9855C4CD-DF8C-449C-A181-8191B68BD06C}/00] value is changed to:
    {9855C4CD-DF8C-449C-A181-8191B68BD06C}/00:
                                               00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 - ................
I think it make it easier to see change and reaction for example:restarting audiosrv results in only 2 Channel Volume Slider @ SPDIF - after starting playback again it is changed to 6 Channel now you can see the stuff behind
1,425 (3.43/day)
Hmm, with some extra programming it might be possible to put all of the DTS setup mods into a setup app (for non-Realtek programming).
Thanks for the post and work.
Reminder:
To use the provided Sound Unbound package (which contains a license), disable Windows store auto-updates.
You will also need to uninstall any updated version, before re-installing the provided one.
DTS DCH 6.0.9250.1 (Signed - Update)
How to setup USB-HDMI (non-Realtek devices) here, for HDAUDIO devices, you need only need the 'DTS Settings' part.
Main directory: https://www.mediafire.com/folder/9yrokjhyh2slx/DTS_DCH_Drivers
Apps: https://www.mediafire.com/folder/tk7ola8b5j6xt/DTS_UWP_Appx
