- Aug 22, 2019
- 132 (0.08/day)
@emanresu
(462) Get Windows 10 Store Paid Apps and Games For Free | The best trick you can ever know. - YouTube
you can use this trick to install any app from microsoft store when u dont have certificate
@emanresu
I have paid for both DTS Sound Unbound (and I want the old version before they "decoder"-nerfed it. Like Alanfittfox2000's 1.3.3.0 but the Mega.nz link is down down down.@emanresu
Do you know a way to install the UWP dump? They are not in .APPX format and I've spent days tryna get around the certificate problem that arises.@emanresu
if you can extract the APP by using 7z OR if u want to convert installed APP to .APPX u can try this(https://drive.google.com/file/d/1T3WVOicE5sHFW_malGsFNkKJbdR1Viuv/view?usp=sharingI have paid for both DTS Sound Unbound (and I want the old version before they "decoder"-nerfed it. Like Alanfittfox2000's 1.3.3.0 but the Mega.nz link is down down down.
what does he mean by UWP dump? (installed UWP?)He only has dumps, without the original .appx
Well it will work on that too. u dont need the originalThe extracted .appx without the original.
Str8 outta Compton!Currently I am testing a trick I found with analogue, its tells SPDIF it has 8 channels, but interactive is only 6, which on analogue produces virtual side.
If I program the same-similar trick to HDMI-DP, ultra see's HDMI-DP as 8 channel, and goes into multichannel and im gay
New BSOD? With colour bars?Hello! This drivers not work for me - new bsod with colour bars - when install this drivers
