- Jun 3, 2012
- 1,788 (0.41/day)
- Denmark
Processor | ryzen 9 5900x |
Motherboard | MSI B550 a-pro |
Cooling | Thermalright Peerless Assassin 120 |
Memory | 2x16gb 3600mhz cl 16 corsair vengeance lpx |
Video Card(s) | GIGABYTE GeForce RTX 3060 WindForce OC |
Storage | 1x2tb KC3000 & 2tb samsung 970 evo plus, 2 x 2 tb external usb harddrives |
Display(s) | LG 32GP850, IIyama G2470HSU-B1 |
Case | Corsair 5000D airflow tg |
Audio Device(s) | Yamaha R-N600A Triangle Esprit Titus Ez |
Power Supply | Corsair RM850X White |
Mouse | Logitech G PRO Superlight |
Keyboard | Corsair K70 RGB TKL Champion |
Software | Windows 11 64 bit, Free bitdefender |
Ryzen 5800x is on my pc at -30 in curve optimizer but still get's my atm moment 1 fan cooler master hyper 212 evo v2 (case fans 1 x 120mm artic p12 and 2x 140mm p14, higher rp than my be quiet shadow wing 120 mm fans) working hard
In a game like horizon zero dawn temps is just above 75c, which i think could be lower with a better cooler
I do have some extra coolers but i have some problems with them, i like my dark rock pro 4 but not for mounting
I need to take my gpu out and mabye my motherboard since the fan in the middle can't be connected with the gpu in the case, also i can't see the holes on the fans at the top of the case + the space is tight for my hand
Scythe fuma 2 is easy to mount but the middle fan has some high pitched sounds and i don't think even with the new higher rpm fans, it's good enough to cool my ryzen 5800x
An aio i would love to use but i don't like the noise from the pump, theres no aio that has a 100% silent pump
An easy to mount air cooler (mainly the fans) that is better than a cooler master hyper 212 evo v2 that doesn't costs as much as a premium cooler like the noctua nh-d15 and be quiet dark rock pro 4
If theres a 120mm fan that is noticeable better than the stock cooler master fan. i could try that fan
