I'm currently running Windows 10 Pro 64bit version 1809 OS on the Gigabyte Z270x Gaming K7 motherboard. Since having problems with Killer E2500 program I have simple resulted to using just one of my ethernet adapters. I'm using the Intel adapter instead of the Killer E2500 adapter which I believe is a Realtek. I also disable the Killer Lan connection in my BIOS. So my question is by doing this will this degrade my performance or should I install the both Lan ethernet adapters software and disabled one or the other in the Device Manager?
