Experiencing strange behavior (choppy audio + low fps) DPC Latency?
23 (0.01/day)
Processor AMD FX-6300 @ 3.5 GHz / 4.1 GHz turbo
Motherboard AsRock 980DE3/U3S3
Cooling Deepcool GAMMAXX 300
Memory 2 x Zeppelin 4GB DDR3 1600MHz
Video Card(s) Sapphire Radeon RX 480 Nitro+ OC 8GB
Storage HDD WD Blue 500GB / HDD WD Blue 1TB / SSD HyperX FURY 120GB
Display(s) LG W2043S
Case Zalman Z3 Plus
Power Supply Zalman ZM600-LX 600W
Mouse A4Tech F7
Keyboard Trust Silverline
Software Windows 10 64bit
Hello!
For the past couple of days I’ve been having some strange issues with my pc.
The first time I noticed that something was not right was when I was listening to a YouTube video. I left the video playing in the background and I pulled up the Steam window and I noticed the audio was getting choppy. I then reverted back to the video and it was all fine. I brought up the Steam window to see if it’s the culprit and the audio went bad again. (video)
Note: in the video I reproduced the problem using Steam's music player instead of YouTube
It appears that interaction with the window will cause this. I tried the same thing with Origin and I received the same result. I did not address the issue after the first encounter thinking that maybe some update will fix it.
The second time when it hit me, was after I just started a Dota 2 match to see that my fps was barely reaching 30 (usually it was around 60). Not only that but the audio was all choppy, the same way as the first time. What is even stranger is that if I bring up the menu, which is an overlay so the game still renders all, the fps and the audio get back to normal. (video) I have tested some other games and I figured only some are affected by this problem. For example GTA V gets affected (suffered a drop from 50-60 to 30-35) while Battlefield 4 doesn’t.
What I have tried: removed video drivers with DDU, installed most recent video driver, also tried the drivers that came on CD with the gpu, reinstalled steam, uninstalled audio drivers, messed with the settings in games and also with the Radeon Settings thingy, ran a scan with Malwarebytes Anti-Malware, temps are ok.
Note: the audio in the videos I uploaded sounds less choppy than it actually is.
I don’t know how to investigate this any further so I request your help.
Specs:
Mobo: AsRock 980DE3/U3S3
CPU: AMD FX-6300 @ 3.5 GHz / 4.1GHz turbo
GPU: Sapphire 7770 GHz OC @ 1100 MHz clock / 1250 MHz memory
Windows 10
Thanks in advance!
1,079 (0.24/day)
Indonesia
Processor AMD Ryzen 7 5700X
Motherboard ASUS STRIX X570-E
Cooling NOCTUA NH-U12A
Memory G.Skill FlareX 32 GB (4 x 8 GB) DDR4-3200
Video Card(s) ASUS RTX 4070 DUAL
Storage 1 TB WD Black SN850X | 2 TB WD Blue SN570 | 10 TB WD Purple Pro
Display(s) LG 32QP880N 32"
Case Fractal Design Define R5 Black
Power Supply Seasonic Focus Gold 750W
Mouse Pulsar X2
Keyboard KIRA EXS
23 (0.01/day)
Case Zalman Z3 Plus
Mouse A4Tech F7
Alright. I ran Dota 2 for about 3 minutes. Here's what I got from LatencyMon:
The Main tab
The Drivers tab
The CPUs tab
And the info from the Stats tab
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. Also one or more ISR routines that belong to a driver running in your system appear to be executing for too long. At least one detected problem appears to be network related. In case you are using a WLAN adapter, try disabling it to get better results. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:02:52 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: RAZVAN-PC
OS version: Windows 8 , 6.2, build: 9200 (x64)
Hardware: ASRock, 980DE3/U3S3
CPU: AuthenticAMD AMD FX(tm)-6300 Six-Core Processor
Logical processors: 6
Processor groups: 1
RAM: 8174 MB total
CPU SPEED
Reported CPU speed: 2643 MHz
Measured CPU speed: 22 MHz (approx.)
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
WARNING: the CPU speed that was measured is only a fraction of the CPU speed reported. Your CPUs may be throttled back due to variable speed settings and thermal issues. It is suggested that you run a utility which reports your actual CPU frequency and temperature.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 26968.092313
Average measured interrupt to process latency (µs): 14.804779
Highest measured interrupt to DPC latency (µs): 26961.247868
Average measured interrupt to DPC latency (µs): 7.579695
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 33747.784336
Driver with highest ISR routine execution time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Highest reported total ISR routine time (%): 0.420228
Driver with highest ISR total time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Total time spent in ISRs (%) 0.466985
ISR count (execution time <250 µs): 83392
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 68
ISR count (execution time 1000-1999 µs): 51
ISR count (execution time 2000-3999 µs): 77
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 36247.716988
Driver with highest DPC routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total DPC routine time (%): 0.728451
Driver with highest DPC total execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in DPCs (%) 1.603429
DPC count (execution time <250 µs): 799384
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 486
DPC count (execution time 1000-1999 µs): 102
DPC count (execution time 2000-3999 µs): 77
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: rundll32.exe
Total number of hard pagefaults 29401
Hard pagefault count of hardest hit process: 16342
Highest hard pagefault resolution time (µs): 3499103623151.0
Total time spent in hard pagefaults (%): 524728630.960052
Number of processes hit: 14
PER CPU DATA
CPU 0 Interrupt cycle time (s): 35.107849
CPU 0 ISR highest execution time (µs): 33348.480893
CPU 0 ISR total execution time (s): 2.065972
CPU 0 ISR count: 60202
CPU 0 DPC highest execution time (µs): 36247.716988
CPU 0 DPC total execution time (s): 12.398527
CPU 0 DPC count: 687429
CPU 1 Interrupt cycle time (s): 11.197214
CPU 1 ISR highest execution time (µs): 33747.784336
CPU 1 ISR total execution time (s): 2.356847
CPU 1 ISR count: 18324
CPU 1 DPC highest execution time (µs): 34265.813848
CPU 1 DPC total execution time (s): 3.126186
CPU 1 DPC count: 44639
CPU 2 Interrupt cycle time (s): 3.927578
CPU 2 ISR highest execution time (µs): 31532.259175
CPU 2 ISR total execution time (s): 0.374669
CPU 2 ISR count: 5234
CPU 2 DPC highest execution time (µs): 30518.333333
CPU 2 DPC total execution time (s): 0.406607
CPU 2 DPC count: 20565
CPU 3 Interrupt cycle time (s): 2.789741
CPU 3 ISR highest execution time (µs): 16685.189936
CPU 3 ISR total execution time (s): 0.024774
CPU 3 ISR count: 165
CPU 3 DPC highest execution time (µs): 15603.047673
CPU 3 DPC total execution time (s): 0.195355
CPU 3 DPC count: 15417
CPU 4 Interrupt cycle time (s): 2.647372
CPU 4 ISR highest execution time (µs): 18.922058
CPU 4 ISR total execution time (s): 0.000023
CPU 4 ISR count: 4
CPU 4 DPC highest execution time (µs): 3706.421869
CPU 4 DPC total execution time (s): 0.243215
CPU 4 DPC count: 19367
CPU 5 Interrupt cycle time (s): 2.775233
CPU 5 ISR highest execution time (µs): 17.303443
CPU 5 ISR total execution time (s): 0.000051
CPU 5 ISR count: 24
CPU 5 DPC highest execution time (µs): 16704.063564
CPU 5 DPC total execution time (s): 0.187982
CPU 5 DPC count: 13243
Edit:
I've ran the test again but this time I started recording after the game finished loading to exclude hangs during that time. The conclusion changed but the drivers with the biggest latency remain the same.
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. Also one or more ISR routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
1,079 (0.24/day)
Indonesia
Mouse Pulsar X2
Keyboard KIRA EXS
Wow, that numbers is just too high.
Try to update your USB port driver, use AMD chipset driver to update USB filter driver.
If it's still not helping, unplug all non necessary USB devices and try to disable your USB port from Device Manager.
Oh one last thing, try to disable Cool n Quiet if you have it enabled.
23 (0.01/day)
Case Zalman Z3 Plus
Mouse A4Tech F7
So... I'm a bit confused. Where should I get the chipset driver? AMD's site, AsRock's site or the cd that came with the motherboard?
Also, when I tried disabling the USB ports, some would not give me that option. Should I uninstall them?
1,079 (0.24/day)
Indonesia
Mouse Pulsar X2
Keyboard KIRA EXS
Chipset driver from AMD website : http://support.amd.com/en-us/download/desktop/legacy?product=legacy4&os=Windows 10 - 64
No need to disable the driver then, just unplug any non essential USB devices (printer, flashdrive, external harddrive, etc.), try to run with bare minimum USB devices connected, only mouse and keyboard.
If these steps still does not improve your latency then the problem might not be the latency, something else is causing it.
23 (0.01/day)
Case Zalman Z3 Plus
Mouse A4Tech F7
I have unplugged all the USB devices and disabled all the ports and plugged a PS/2 mouse and keyboard. I managed to get 40-45 fps in Dota (still 60 fps only with menu active). LatencyMon gave me this results:
144 (0.03/day)
London, UK
System Name Mercury
Processor AMD 2700X (Waiting for 4000 series)
Motherboard X570 I Aorus Pro Wifi
Cooling Custom Water Cooling
Memory Corsair Vengeance RGB 3200
Video Card(s) GTX 1080
Storage Samsung EVO 960 256GB + Seagate Firecuda 2TB
Display(s) LG 42' 4K HDR TV
Case Enthoo Evolv ITX
Audio Device(s) Stock
Power Supply Corsair SF 600
Mouse Razer Deathadder
Keyboard Razer Huntsman
Software Win 10 64bits
I had that same problem several weeks ago, for me it was a dying hdd, i had 2 hdds and a ssd, the hdd that died was my media drive not my main drive, even so it was the problem, after it died and i got it out of my pc everything started running fine again.
23 (0.01/day)
Case Zalman Z3 Plus
Mouse A4Tech F7
Alright, so I did some testing with my HDDs (defrag + bad sector scan) and they seem to be okay.
I've also installed the AMD chipset drivers, plugged my USB devices back and it looks like my performance has not changed (still 40-45 in Dota), which is some form of progress I guess.
I ran two tests on Dota with LatencyMon, one during normal play and the other with the menu overlay open and the latency is way lower when the menu is open.
First test, normal play
Second test, with menu open
6,439 (1.44/day)
Florida
System Name natr0n-PC
Processor Ryzen 5950x/5600x
Motherboard B450 AORUS M
Cooling EK AIO 360 - 6 fan action
Memory Patriot - Viper Steel DDR4 (B-Die)(4x8GB)
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) PIXIO IPS 240Hz 1080P
Case Thermaltake Level 20 VT
Power Supply Super Flower Leadex III ARGB 80+ Gold 650W
Software XP/7/8.1/10
23 (0.01/day)
Case Zalman Z3 Plus
Mouse A4Tech F7
1,079 (0.24/day)
Indonesia
Mouse Pulsar X2
Keyboard KIRA EXS
Can you check the SMART data for each of your hard drive?
I run LatencyMon on my system out of curiosity, strangely I also get a high number but no FPS drop, stuttering, or audio issues at all.
Mussels
Freshwater Moderator
58,413 (8.18/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Just as a possible alternative, quit or minimise these programs and see what happens - right before i left AMD for my Nvidya 970 i saw oddness with blizzards battle.net launcher open in the background, as it had the possibility to play videos (much like steam) it was locking my GPU to low 3D clocks and causing FPS drops.
It's kind of a wild guess, but look into all thees running programs and see - it COULD be a video driver/video codec bug like i had.
23 (0.01/day)
Case Zalman Z3 Plus
Mouse A4Tech F7
Here is the SMART data for each drive.
It seems that my old HDD has issues. Should I try unplugging it?
20,786 (3.41/day)
System Name Pioneer
Processor Ryzen R9 7950X
Case Thermaltake Core X31
Software Gentoo Linux x64
Should not make a difference, though it does have 7 pending sectors, FWIW.
23 (0.01/day)
Case Zalman Z3 Plus
Mouse A4Tech F7
I thought so. By the way I rarely use that drive. It just stores some files that I use from time to time.
Edit:
I ran an extended test with Western Digital Data LifeGuard Diagnostics and it passed. I don't think that old HDD is the issue.
23 (0.01/day)
Case Zalman Z3 Plus
Mouse A4Tech F7
Okay, so it appears that the choppy audio is gone and now I am only confronting with low fps (about 15-20 lower than usual). I ran a test with LatencyMon while playing GTA V and these were the results.
144 (0.03/day)
London, UK
System Name Mercury
you should try plugging out the old hdd (500GB one) it looks exactly like my failing hdd, its a quick test also, so i shouldn't be a problem, from the looks of it it is out of free sectors to relocate, and that is going to create reading error even when its idle, i'm just talking from my experience.
1,079 (0.24/day)
Indonesia
Mouse Pulsar X2
Keyboard KIRA EXS
I think you need to also try @Mussels, @little cat, and @Onderon suggestions. Could be audio & video driver issue and also Steam issue.
-What Crimson driver version are you in? Have you tried rollback to older driver?
-Try to play game with disabled onboard audio.
-Try to unplug the old HDD and play games to really check the possibility whether it's the problem or not.
And I saw your video recording here, for me GPU & CPU clocks and temperatures seems normal, only GPU usage seems a little bit high.
23 (0.01/day)
Case Zalman Z3 Plus
Mouse A4Tech F7
Scratch my last post. The audio choppiness is still there but it's less noticeable.
I will try those.
23 (0.01/day)
Case Zalman Z3 Plus
Mouse A4Tech F7
So, I pulled out the old HDD and it did not help and neither did disabling the audio drivers.
I currently have the 16.7.3 Crimson drivers. I tried rolling back to 16.3.2 and also the drivers that came on the cd with the GPU, 13.1 i believe, but no success.
About closing the Steam window when playing, yes, I did that too. It doesn't seem to affect it in any way. If you were talking about ending the process, well, if I do that then I wouldn't be able to run Dota since in needs Steam. Sorry for bringing up Dota so much but it's one of the few games that I know what fps I had before the issue arised and it's one of the few ways of telling if the problem is still present, even more now that the audio choppiness is less noticeable.
23 (0.01/day)
Case Zalman Z3 Plus
Mouse A4Tech F7
Yes, I have also made a thread there so that maybe a dev could point out to what's causing the issue. However that forum doesn't seem very alive.
