Fan speed control
196 (0.05/day)
Likes
11
Paris
Processor E6700@3447 (383.1*9)24/7; 3735(415*9)for benchies
Motherboard P5B dlx
Cooling Zalman cnps 9700 led; 1Thermaltake enlobel 120mm; 1Noctua 120 and 2NZXT 120 mm case fans
Memory Corsair Twinx 2Go Pc6400c4 @ 478.9 4-4-4-12
Video Card(s) hd 2900 xt @850/1050
Storage 400G Seagate; 75Go WD raptor (system disk)
Display(s) Sony h70
Case Modded NZXT apollo
Audio Device(s) Sound Blaster X-FI audio / Altec 2.1
Power Supply Enermax Infinity 720W
Software XP pro sp2
Benchmark Scores 3DMark=12907
#1
Found this on OC FORUMS by flamethrower.........an edit of the registry for fan control in CCC even for older cards.
"Go to RegEdit ( backup your registry if you think you'll mess it up .. I take no responsibility for anything you do to your own machines ! ).
Find all instances of following values by going to EDIT>Find :-
FanSpeedPercentActual_NA
FanSpeedPercentTarget_NA
FanSpeedRPMActual_NA
FanSpeedRPMTarget_NA
and change the default "1" disabled to "2"enabled.
When you've changed all instances of those values , close RegEdit -->> Reboot.
When you load CCC up next time, you should see the fan speed slider has appeared and it works too !!"
it works for my 2900xt on 9.2 CCC.......atitool and riva tuner etc were failing me.
kiriakost
1,054 (0.32/day)
Likes
69
Volos, Greece
System Name ATLAS
Processor Q6600 QUAD
Motherboard ASUS P5QC
Cooling ProlimaTech Armageddon
Memory HYPER-X KHX1600C8D3T1K2 /4GX PC3-12800 1600MHz
Video Card(s) Sapphire HD 5770 VAPOR-X
Storage Raptors 73Gb - Raid1
Display(s) DELL U2311H
Case HEC Special moded ..
Audio Device(s) X-Fi Music + mods Audigy front Panel (full working)
Power Supply HIPER 4M780 PE 980W Peak
Software XP PRO SP3
#2
Nice find .... but a screen shot, of the CCC with the slider, will be a nice thing to see .
So post one .
196 (0.05/day)
Likes
11
Paris
Motherboard P5B dlx
Display(s) Sony h70
Software XP pro sp2
#3
Here you are............:cool:
5,659 (1.67/day)
Likes
2,608
στο άλφα έως ωμέγα
System Name Ha/AhHa/Dell
Processor QX9650 SLAWN C1/i7-980x/i7-6700K
Motherboard GA-X48_DS4 (F3B bios)/Gigabyte x58A-UDR3 v 2.0(modded FH bios)/Dell Foxconn 0XJ8C4 Z170
Cooling CNPS9900 LED/H60/ 3 pipe-center fan-air
Memory 8 Gig of G.Skill F2-8800CL5D/24 Gb Corsair Vengence/ 24Gb Samsung DDR4 2133
Video Card(s) Galaxy NVIDIA GeForce GTX 960/PowerColor R9 280/ASUS R9 380X Strix G1
Storage All have SSDs with HDDs for extra storage and backup/Dell-M.2 Samsung 850 EVO PCIe
Display(s) Asus 266H/Viewsonic 1080p/HP ZR24W
Case CM-690/CM-690 II adv/Dell 8900 series
Audio Device(s) All use on board (Realtek) w/2.1 speakers
Power Supply PC P&C 750/PC P&C Silencer 950/CM 700 Extreme
Mouse Logitech
Keyboard Logitech
Software Windows 10 Pro - 64 bit/Windows 10 Pro - 64bit/Windows 10 Pro - 64bit
#4
SGTDRE
16 (0.01/day)
Likes
0
East Coast NJ
System Name My Gaming Rig (Built Back In 2005)
Processor P4 3.6 Ghz
Motherboard P5AD2-E Premium
Cooling CPU:Cooler Master V10,,GPU:Arctic Cooling Accelero Xtreme 2900
Memory 2 Gig CORSAIR XMS2 Pro TWIN2X1024-5400C4
Video Card(s) HD 2900 XT Just Installed Due To X1900XT Died
Storage Raptor 150GB 10,000 RPM,,Caviar 250GB 7,200 RPM
Display(s) Gateway XHD3000
Case Lian Li V1200
Audio Device(s) Creative SB Audigy 2ZS,,Creative Inspire 5.1 Speakers
Power Supply Enermax Revolution 85+ 1050W
Software WinXP SP3, Assorted Graphics & Photo Proggy, Games To many To List
Benchmark Scores None that are Recent, I just made some Changes/Upgrades From the Original Build.
#6
Great LiL Tip
Hello one and all, My first Post here and the new Kid on the block.
I just wanted to post a quick Thank you, I searched the net for god knows how long for a way to control My HD 2900 XT Fans. Then a I ran upon the forums here and this nice tip, I just finished doing a few mods to my system here and I also installed the Arctic Cooling Accelero Xtreme 2900, got it at www.performance-pcs.com for a nice $$$
I am not to crazy about the Heat these Cards put out, so that is why I got the AX 2900 XTREME yeah I know :) that it is, and I do have to say that it is perrty quiet, and it even lowered the Temps on the Card by about 8 to 10 C but I wanted to be able to crank up the Fan speed a bit more to bring it down the Temp a bit more.
I also Attached Two Pix, One just after doing the Reg Edit and doing the Auto tune Within CCC 9.3 and the other pic is just sitting here Idle as I type this message.
Dre
1,129 (0.34/day)
Likes
128
Christchurch New Zealand
System Name My Computer!
Processor AMD 6400+ Black @ 3.5
Motherboard Gigabyte AM2+ GA-MA790X DS4
Cooling Gigabyte G-Power 2 pro
Memory 2x2 gig Adata 800
Video Card(s) HD3870x2 @ 900gpu and 999mem
Storage 2x wd raid edition 120gig + 1 samsung 320 + samsung 250
Display(s) Samsung 40inch series6 full HD 1080p
Case NZXT Lexa
Audio Device(s) ALC889A HD audio with Enables a Superior Audio Experience (on board)
Power Supply Vantec ION2+ 550w
Software Vista Home pream 64
#7
thats awsum!!!
any more tricks you can do in the reg for ccc?
1,129 (0.34/day)
Likes
128
Case NZXT Lexa
#8
any know if you can override refresh rates using this sort of techneque?
1,129 (0.34/day)
Likes
128
Case NZXT Lexa
#9
also why dont ATI just give us the damn slider by defult?
1,888 (0.56/day)
Likes
142
System Name The Beast
Processor Intel Core i3-2100 @ 3.1GHz
Motherboard Asus P8P67 LE
Cooling Stock
Memory 4GB Corsair Vengeance DDR3 @ 1600MHz
Video Card(s) 1GB Sapphire Radeon HD4650 Ultimate Edition
Storage 60GB Corsair Force LE, 1TB Samsung SpinPoint F1, 500GB Seagate
Display(s) 22" Samsung T220HD & 19" Acer X193W
Case Corsair Obsidian 750D
Power Supply Corsair HX650W
#10
I couldn't find those registry entries, I'm using CCC 9.3 on Vista Ultimate x64 with a Sapphire X1950 Pro.
SGTDRE
16 (0.01/day)
Likes
0
East Coast NJ
Case Lian Li V1200
#11
That is a good Question Troy.
Also I did a short Video of the HSF I just installed, not the best it is a little dark but for those that have not seen it and how big it really is once installed.
Here is a link to files, in two formats, 3GP and Quick Time
http://hosted.filefront.com/JaiQwan
Dre
Wish I could help but Im using XP 32bit, All I can say is try again and just copy and paste from OP when you search the Reg. that is what I did.
Try looking for this Key String or similar that is on your system
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ati2mtag\Device0 & 1 & 2 & 3
I Attatched a pic to give ya an idea where to look
1,129 (0.34/day)
Likes
128
Case NZXT Lexa
#12
Dre
looks good mate, what card is that, you should post your system specs
SGTDRE
16 (0.01/day)
Likes
0
East Coast NJ
Case Lian Li V1200
#13
1,129 (0.34/day)
Likes
128
Case NZXT Lexa
#14
