Fans -- Speed -- Case
113 (0.06/day)
Hello,
I would like to take this case Meshify C Mini - Dark TG
https://www.fractal-design.com/home/...meshify-c-mini
already has 2 fans included (FRONT-REAR)
I would like to know which additional fans would be better considering
- little noise
- good airflow
- speed
I've read that you can run at different speeds for better cooling
_ At what speed do you turn them (FRONT-REAR)?
_What to consider and how to choose them when you buy?
Thanks
Greetings
1,025 (0.37/day)
Croatistan
System Name 1.21 gigawatts!
Processor Intel Core i7 6700K
Motherboard MSI Z170A Krait Gaming 3X
Cooling Be Quiet! Shadow Rock Slim with Arctic MX-4
Memory 16GB G.Skill Ripjaws V DDR4 3000 MHz
Video Card(s) Palit GTX 1080 Game Rock
Storage Mushkin Triactor 240GB + Toshiba X300 4TB + Team L3 EVO 480GB
Display(s) Philips 237E7QDSB/00 23" FHD AH-IPS
Case Aerocool Aero-1000 white + 4 Arctic F12 PWM Rev.2 fans
Audio Device(s) Onboard Audio Boost 3 with Nahimic Audio Enhancer
Power Supply FSP Hydro G 650W
Mouse Cougar 700M eSports white
Keyboard E-Blue Cobra II
Software Windows 8.1 Pro x64
Benchmark Scores Cinebench R15: 948 (stock) / 1044 (4,7 GHz) FarCry 5 1080p Ultra: min 100, avg 116, max 133 FPS
I recommend Arctic F9 PWM, F12 PWM or F14 PWM fans. They are durable, quiet, have excellent airflow and are twice cheaper than some other hyped fans like Corsair AF/SF or NZXT Aer (with better airflow than both :D).
Speed depends on your preference. I set my fans according to the temperature and front fans are set to spin slightly faster than rear ones.
FreedomEclipse
~Technological Technocrat~
23,348 (3.76/day)
London,UK
Display(s) LG GP850-B
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G900
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
Just pick up the fastest pwm fans from the Noctua Redux line. thats how I always roll for client builds. They are fairly cheap and pretty good and don't have RGB
113 (0.06/day)
thanks
thanks
