fitting a 92mm AIO in a case with no 92mm fan mount
2,304 (0.39/day)
Calgary Alberta, Canada
System Name PCGR
Processor Intel 10500 ES
Motherboard MSI Z490 Gaming Plus
Cooling Snowman MT4 Dual Fan
Memory 2x8GB DDR4 3600 Corsair Vengeance
Video Card(s) Gigabyte RX 6800XT Gaming OC
Storage 1x 1tb ADATA XPG 8200 Pro NVME | 1x 1TB WD Blue HDD
Display(s) BenQ 24" 1080P
Case MSI MPG 110M
Power Supply Cooler Master 550W MWE 80+ Gold
Software Windows 10 64bit Pro
So I am in a bind.
Got a GTX 980 TI that wont fit in an HP PC case. So now I will have to move the motherboard and all to another case. Issue is, the HP AIO that comes with it is a 92mm one, and not 120mm.
Any ideas on mounting it or should I just say to heck with it and not bother?
FreedomEclipse
~Technological Technocrat~
21,827 (4.14/day)
London,UK
Processor Intel 8600k@4.8Ghz
Video Card(s) Gigabyte 1080Ti Gaming OC|Accelero Xtreme IV
Storage Samsung 970Evo 512GB SSD (Boot)|WD Blue 1TB SSD|2x 3TB Toshiba DT01ACA300
Display(s) Asus PB278Q 27"
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G900/G502
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
sneekypeet
Retired Super Moderator
28,945 (5.13/day)
System Name His
Processor Intel i9 7920X
Motherboard Asus Prime X299 Deluxe
Cooling Corsair H115i RGB Platinum
Memory Crucial Ballistix 3200MHz 64GB
Video Card(s) nVidia RTX 2080ti
Storage Samsung 960 Pro / Crucial MX300 750GB / Seagate 1TB Spinner
Display(s) Samsung 55" 4K 60hz
Case Cooler Master Cosmos C700P (Inverted Layout)
Audio Device(s) Realtek on board > Sony Receiver > Cerwin Vega's
Power Supply Thermaltake TPSG 1050W
Mouse Always Changing
Keyboard Always Changing
Software Windows 10 Pro 64
Ziptie it to the chassis using the venting cut in the 120mm fan location.
2,304 (0.39/day)
System Name PCGR
Case MSI MPG 110M
Another option.
I found some cases where the fan mounts can actually fit more than 120mm fans. So I presume the 92mm may fit there. But yeah, the brackets that freedom mentioned may work if I can find them.
187 (0.23/day)
The Heart of Dixie
System Name Forgal
Processor Ryzen 7 5800X
Motherboard Asus RoG Strix X570-E Gaming
Cooling Arctic Liquid Freezer II 280
Memory 4x16 GiB Crucial Ballistix PC4-28800, 16-18-18-38
Video Card(s) EVGA GeForce RTX 3080 FTW3 Ultra 10G-P5-3897-KR
Storage 2 TB ADATA XPG SX8200Pro + 2 TB Crucial MX500 + NAS
Display(s) Dell S3220DGF + LG 32UD99-W
Case Fractal Design Define 7 Compact
Audio Device(s) Audioengine HD3 + S8
Power Supply SeaSonic Focus PX-850
Mouse Razer DeathAdder Chroma
Keyboard Leopold FC900R OE mx-brown
I have a 3½" hole saw in the bottom of my tool kit that I used to cut blow-holes in the side panels of several cases back when most weren't designed for much cooling. Start by drilling the four holes for the mounting screws, mark the center for the hole saw and go to town making some noise. Once you've got the hole drilled, clean up the swarf, slap on a fan grill of your favorite design, and Bob's your uncle.
If that sounds too adventuresome and you have a 120mm mounting location free, you could just use a $7 mounting adapter.
2,304 (0.39/day)
System Name PCGR
Case MSI MPG 110M
I have been thinking of doing this solution. Last time I did that was about 20 years ago with old cases where you can pimp them out with the custom fan grills you could find out and about. Did that on my old Athlon XP machine (last time).
I got no problem doing that.
12,540 (4.97/day)
Sunshine Coast
System Name Black Box
Processor Intel i5-9600KF
Motherboard NZXT N7 Z370 Black
Cooling Cooler Master 240 RGB AIO / Stock
Memory Thermaltake Toughram 16GB 4400MHz DDR4 or Gigabyte 16GB 3600MHz DDR4 or Adata 8GB 2133Mhz DDR4
Video Card(s) Asus Dual 1060 6GB
Audio Device(s) No need.
Power Supply FSP Aurum 650W
Mouse Yes
Keyboard Of course
Software W10 Pro 64 bit
Unless you have a large hole on the rear of the case where the 120mm fan goes, mount it there and no need to drill, place the screws through the rear mesh.
2,304 (0.39/day)
System Name PCGR
Case MSI MPG 110M
I figured too. Maybe add in washers to the screws so it would hold better.
Last option is saying screw it, put my GTX 1070 in the system and put the GTX 980 to in my system. Since the 980ti isn't far off in performance to my 1070
2,895 (1.00/day)
Left @Booneys Ave, go 22.96 miles then right 2 mi.
System Name The Big RED One
Processor i9-9900k, oc'd to 5.2 ghz
Motherboard Asus ROG Maximus Hero Wifi Z390
Cooling Corsair H115i pro AIO 560mm push/pull, 11x Corsair 140mm ML RGB Fans, 5 in a modded rack config
Memory 64GB Corsair Vengance RBG pro DDR4-3200 (4x 16GB) in XMP2
Video Card(s) Evga RTX 3080 w/15% O/C
Storage 2x WD Black SN750 1TB m.2 + 4TB Crucial SSD + WD 12TB external HDD
Display(s) 2x Samsung 43" LCD's @4k-1440p
Case Thermaltake TT900 Supertower
Audio Device(s) On-board Intel AC9260 wireless, JBL Studio Pro Bluetooth Speakers
Power Supply EVGA G2 SuperNova 850W Modular
Mouse Logitech MX Master 2
Benchmark Scores Quicker than flies on a dung pile
Ah, zip ties to the rescue, AGAIN, and possibly assisted by a dremel tool.....hahaha :)
This only works if the mesh openings match up close enough to the fan's corner mounts....which again, zip ties and/or a dremel tool can help alleviate this issue :)
2,304 (0.39/day)
System Name PCGR
Case MSI MPG 110M
well, since the case of this HP Envy machine has the antenna's for the wifi card on the top, I really do not feel like trying to strip that out. I tried the GTX 980 ti in my T3500 and it itself cannot fit in that case. LOL. So, I am back at square one. Either I just try to continue with this or look for another GPU.
