GeForce RTX 2080TI Artefacting under load
revex666
1 (0.00/day)
Good day all,
My name is Joris and I'm new to this Forum.
Lately, I try to learn more about troubleshooting hardware issues on motherboards and GPU's. However, since I'm new to this complex world I run into some issues.
I Just bought an RTX 2080ti and the seller told me it stopped working on him sometimes. After plugging it into my PC it was working fine and running smoothly until I started with a benchmark test (Heaven). When starting up some artifacts appeared in the benchmark and it started to freeze, after a few seconds, it was running again followed by freezing, and so on.
attached I added the log of GPU-Z, does someone see some odd things in the results that cause these artifacts? I compared the results with another log I found somewhere around here and though there were some differences in the voltages, maybe the previous owner did some monkey buisniss. I always thought, most likely wrong, that these artifacts are there always or only when the chip is getting hot, however, neither is the case.
I searched online but did not find any more specific information about this problem. I hope my post is conform the standards.
Hope someone can help!
  • GPU-Z Sensor Log.txt
tonycstech
11 (0.04/day)
Bad memory module
Run MATS.
If no errors, heat up memory banks and run MATS again. It should tell you which banks are bad once warmed up.
This is only happening when they are warmed up.
4,614 (0.86/day)
where everyone wants to be
System Name Everchanging
Processor AMD Ryzen 9 5900X
Motherboard ASUS ROG Crosshair Hero VIII Wi-Fi
Cooling Arctic Cooling Liquid Freezer 2 420mm
Memory 2x8GB Zadak Spark DDR4 4133MHz 19-21-21-42 Samsung B-die Running 3600MHz 14-14-14-28 1T
Video Card(s) Powercolor 6800 Fighter
Storage Samsung 980 Pro 256GB, Samsung 980 Pro 2TB
Display(s) LG 43" 4k UHD HDR
Case Fractal Meshify 2 XL
Power Supply Seasonic Prime TX 850w
Mouse Roccat Kova AIMO
Keyboard PNY Hyper X Cherry MX Blue
Software Windows 11 x64
Who makes the card?
867 (0.75/day)
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
Welcome to the forum Joris, enjoy your stay and hope you fix your issue soon.
1,151 (0.29/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 5 5600X
Motherboard ASRock B550 PG Velocita
Memory 32 GB G.Skill Trident Z Neo F4-3600C18D-32GTZN
Video Card(s) Sapphire Nitro+ Radeon RX 6750 XT
Display(s) Asus VG278QR
Case Corsair 275R
Mouse Logitech Pro (Hero)
Software Windows 11 Pro x64 22H2
Extreme lagging, is one of the known symptoms of unstable VRAM, especially with no error being reported.
37,418 (6.71/day)
RTX 2000 series are prone to memory failures which seem to have appeared on RTX 3000 series too
