Gigabyte 3060ti Eagle OC Low Max fan speed
13 (0.00/day)
Hi All,
I recently purchased this card and the card is kinda running hot, 77 c at full load with undervolting I am at 74 c with 1905mhz, I am still researching to see if any improvement can be done and I found a video which could help. basically the max fan speed on these cards are very lower when compared to FE cards, mine maxes at 2085 RPM at 100%. is this correct RPM for this card ?, I have checked for any new vbios, nothing is available
so in the video I found, this guy flashed a palit 3060 ti dual oc vbios and now his speeds are around 2500 RPM at 75% itself and the temps are very good now. Also I have checked many other videos where the fan rpm of 3060ti FE, zotac, palit, gainward (similar dual fan variants) all reaches around 2800 at 100%
I just want to discuss here to understand if its a gigabyte bios issue or gigabyte specifically reduced the speeds because this cards fans cant handle that speed , I feel if the fans run faster it can easily help with the temp problems and I don't mind the fans running loud
I can try to flash the palit vbios but it only has 1 hdmi vs 2 hdmi in gigabyte eagle and also it will be safer if i can use the same card vbios, Can anyone help with modding the vbios(attached here) to allow more fan speed
Video reference
  • GA104.rom
Tigger
I'm the only one
13,835 (2.39/day)
System Name Dirty Fecker
Processor Intel I7 12700K 5ghz-P 3.9ghz-E 1.25vcore
Motherboard Asus Rog Strix Z690-A WiFi D4
Cooling EK 360 PE+EK 280 CE, FLT 240 D5, EK supremacy classic, Generic GPU block
Memory Teamgroup 8 Pack Edition T-Force Dark Pro 2x16gb 3735 16-16-16-38 Bdie
Video Card(s) MSI GTX980TI Gaming 6gb, 1475/8000 water cooled
Storage Silicon Power Gen3x4 256gb M.2, WD SN850 1TB M.2 NVME Gen4x4
Display(s) MSI 32" Optix AG32CV 1080p 165hz 1ms
Case Lian Li o11 Dynamic XL Rog
Audio Device(s) onboard/Logitech Z4
Power Supply Corsair TX750M 80% Gold
Mouse Razer Viper
Keyboard Anne pro II
Software Win 11 Pro x64
Benchmark Scores do they matter
Do NOT flash the palit bios on your card.
There might be someone here who can edit your bios for you.
13 (0.00/day)
Thanks, that's what I am hoping for , I have already attached my vbios from gpu z in above post itself
115 (0.03/day)
System Name Mixed Bag of OC
Processor AMD Ryzen 5900X
Motherboard Maxsun MS-iCraft B550M WIFI
Cooling CPU+GPU on Water with 3 X 420 Rad´s
Memory 32GB Patriot Viper RGB @ 3800 Mhz CL14
Video Card(s) AMD RX 6900 XTXH flashed with AMD LC Bios
Storage 2TB Samsung OEM PCIe 4 NVME
Display(s) Philips 48OLED806
Case Selfmade Huuuuuge *Case* :)
Audio Device(s) ifi Zen DAC + Monoprice M1060C & Burmester Replica AMP + Selfmade Huuuuuge Speakers :)
Power Supply EVGA SuperNOVA 1300 G2
Mouse Gameball Trackball (main device) + Razer Basilisk V3 (for FPS)
Keyboard Sharkoon PureWriter RGB, Kailh Blue switches
VR HMD None
Benchmark Scores do not matter, my PC is fast :)
Hello, just use MSI Afterburner and set a custom Fan Curve to suit your needs. Gigabyte has set the BIOS Profile to be more quiet i think.
13 (0.00/day)
I have set the custom fan curve already, issue is not that , my 100% fan speed is low (2080 rpm) whereas all other similar spec cards have the max fan rpm as 2800 (I don't know if gigabyte had a typo when setting the max value to 2080 instead of 2800)
6,081 (1.01/day)
Whatever my internet protocol shows I guess O.o
System Name Lynni The Dragon
Processor Intel Core i7-11700K "Rocket Lake"
Motherboard Gigabyte Z590 Vision G Bios F7 (Originally shipped with Bios F2)
Cooling Fractal Design Celsius S24
Memory Geil Dragon 4x8GB@3000mhz 15-17-17-35 (GWW416GB3000C15DC)
Video Card(s) Asus GeForce ROG STRIX RTX 3070 O8G-GAMING | Sapphire Radeon RX 590 Nitro+ Special Edition 8GB
Storage OS/Games:Samsung 970 EVO 1TB|Sabrent Rocket 2TB|Data: 850EVO 1TB, 3xWD 4TB, 1xWD 10TB & WD 1TB
Display(s) Asus ROG Strix XG27UQ 4K@144hz | LG 55UK6100PLB IPS 4K HDR | LG 48CX OLED 4K HDR
Case Fractal Design Meshify 2 Tempered Glass White/Black
Power Supply Seasonic Prime 1200 watt 80Plus Platinum
Mouse Logitech G305 Lightspeedy Wireless
Keyboard Razer Blackwidow Chroma X UK
VR HMD No not gonna sell myself to FB!i!i!
Software Win11 Pro 21H2 UK (Build 22000.376)
Benchmark Scores Not benchmarking anymore only Gaming. GPU-Z: https://www.techpowerup.com/gpuz/details/h93ag
Usually the manufacture knows the parts they use on your cards, but it could be that the fans was swapped out later en manufacture and Gigabyte didn't bother to change the speed.
But as @Gruffalo.Soldier says get something to mod a bios to you or save your original bios and get something to check this if there is any that should hold the fans back.
1,107 (1.65/day)
The temps that you mentioned are nowhere near critical, so I don't think you have to worry that much. Even if you can ramp the fan speed up, are you able to tolerate the increase in noise level?
13 (0.00/day)
I need help with modding the bios, i don't have the knowledge as such, that's why i thought some expert here can help
Yes i dont mind the increase in noise level at all, i have been using a gaming laptop and gotten used to loud noise so dont mind at all the additional noise
adg2484
1 (0.01/day)
I flashed this card and got great results with the gigabyte pro oc 3060ti vbios from techpowerup. Temps never go over 69c full load and it's hitting 220w now.
Flashing vbios is very unsafe but if done correctly it's not but do you any questions lmk.
33,548 (6.30/day)
I wouldnt flash any 3000 series card
211 (0.16/day)
Australia
77°C is great at full load.
I'd leave it alone.
