Gigabyte Aorus Xtreme WaterForce RTX 2080 Appears, Features AIO Liquid Cooling
crazyeyesreaper
Not a Moderator
9,536 (2.24/day)
System Name Old reliable
Processor Intel 8700K @ 4.8 GHz
Motherboard MSI Z370 Gaming Pro Carbon AC
Cooling Custom Water
Memory 32 GB Crucial Ballistix 3666 MHz
Video Card(s) MSI GTX 1080 Ti Gaming X
Storage 3x SSDs 2x HDDs
Display(s) Dell U2412M + Samsung TA350
Case Thermaltake Core P3 TG
Audio Device(s) Samson Meteor Mic / Generic 2.1 / KRK KNS 6400 headset
Power Supply Zalman EBT-1000
Mouse Mionix NAOS 7000
Keyboard Mionix
Gigabyte is now readying a new hybrid cooled graphics card, based on NVIDIA's GeForce RTX 2080. Dubbed the Aorus Xtreme WaterForce (GV-N2080AORUSX W-8GC). It uses an all-in-one liquid cooler based design that makes use of a 240 mm radiator. The copper baseplate is quite large and receives heat from the cards VRM via a copper heat pipe, thus cooling all major components. The fans are of course RGB LED-equipped, which goes with the illuminated translucent wing on the shroud. Overall it is an attractive card if you have the extra space for its cooling solution.
This model isn't just a standard offering with a fancy cooler, Gigabyte has equipped it with a sizable overclock, pushing the card to 1890 MHz the same core clocks as the Aorus Xtreme air and the waterblock equipped WaterForce WB. Memory speeds see a speed bump as well of 140 MHz which pushes the overall memory clock speed up to 14140 MHz. The board design is also based on the Aorus Xtreme and Aorus Xtreme Waterforce WB cards and comes with a 12+2 phase design and dual 8-pin power connectors. Display connectivity is also the same as the other models and includes; 3x DisplayPort, 3x HDMI, and a single USB TypeC.
2,337 (0.90/day)
If I tellz ya, I gotzta, you know the deal....
System Name The Big RED One
Processor i9-9900k, oc'd to 5.2 ghz
Motherboard Asus ROG Maximus Hero Wifi Z390
Cooling Corsair H115i pro AIO 560mm push/pull, 11x Corsair 140mm ML RGB Fans (front, top, sides, rear)
Memory 32GB Corsair Vengence RBG pro DDR4-3200 (4x 8GB) in XMP2
Video Card(s) Evga 2080ti w/15% O/C
Storage 2x WD Black SN750 1TB m.2 + 4TB Crucial SSD + WD 12TB external HDD
Display(s) 2x Samsung 43" LCD's @4k-1440p
Case Thermaltake TT900 Supertower
Audio Device(s) On-board Intel AC9260 wireless, JBL Studio Pro Bluetooth Speakers
Power Supply EVGA G2 SuperNova 850W Modular
Mouse Logitech MX Master 2
Software Windows 10 pro 64 bit, with all the unnecessary background shiite turned OFF !
Benchmark Scores Quicker than flies on a dung pile
yummy...gimmee pleeze :)
84 (0.03/day)
I have the 1080Ti version, which is a 120 rad, not a 240. I'm looking forward to a 2080Ti version since the one I have is boss, huge over clock and runs perfect.
405 (0.26/day)
Not sure how I feel about the 240mm Rad; on one hand there's more heat dissipation and potentially a quieter fan curve while on the other you severely limit mounting options, particularly in Mid-tower and ITX builds.
One of the advantages of water is that it has the ability to be extremely low profile while maintaining performance.
4,979 (1.72/day)
Jyväskylä, Finland
Processor AMD Ryzen 5 3600 @ 4.3GHz
Motherboard MSI B450 Mortar Max
Cooling Modified Alphacool Eisbaer 240
Memory 16GB DDR4-2400
Video Card(s) EVGA GeForce GTX 980 Ti
Storage 3x Kingston A400 480GB SSD + WD Green 2TB HDD
Display(s) Viewsonic 24" 1080p & HP 23" 1080p w/ Arctic Z2 gen3
Case Fractal Design Define Mini C Window
Audio Device(s) Onboard Realtek ALC892
Mouse Logitech G400s
Keyboard Dell Multimedia Pro keyboard
Software Windows 10 Pro English
1. Can RGB be turned off ?
2. Rad material is ?
I'm sure that the rad is aluminium like on almost every closed-loop AIO. Expandable ones can be copper.
