Gigabyte RX570 not running at max clock speed
Milerciten
3 (0.00/day)
Buenos Aires
Hi, so i have an rx 570 wich should to run at 1244mhz, but when gaming or running benchmarks like superposition, the gpu runs between 1060 to 1180mhz.
If i set the power limit in wattman to 135%, it runs at 1244mhz with no issues.
No thermal issues, my cpu is a R5 3600 and the PSU is an EVGA 600B.
Is this normal?:confused:
1,741 (0.60/day)
System Name BOX
Display(s) LG 27GP950-B
Mouse Logitech RX-250
Keyboard HP KB-9970
Yup, it's power limit.
You can either mod vBIOS to lower vGPU (lower voltage = lower TDP/power + lower temps) or increase TDP/Power Limits in it.
8,943 (3.36/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Technically it's normal, hard to tell. What games are you running and how do you play them, v-sync on or off ?
Milerciten
3 (0.00/day)
Buenos Aires
I have a Freesync monitor running at 72hz, but in Mass Efect Andromeda for example, the gpu can't handle 72 fps constantly and even then the clock speed is around 1130 mhz.
1,856 (1.05/day)
Hungary
Processor i3-12100F 'power limit removed/-130mV undervolt'
Video Card(s) Asus TuF V2 RTX 3060 Ti @1920 MHz Core/950mV Undervolt
Display(s) 29" 2560x1080 75 Hz / LG 29WK600-W
Mouse Canyon Puncher GM-20
I had the same 'issue' with my RX 570 and undervolting in wattman fixed this for me.
In my case 950mV 'State 7' with +20% power limit is stable but every card is a bit different so you might need to find out what works for you.
Milerciten
3 (0.00/day)
Buenos Aires
So, nothing to worry then? That's good news, thanks guys:).
