Gigabyte Z390 mobo - adding heatkiller water blocks - advise/help needed
347 (0.09/day)
Oztralia down under
System Name K9
Processor i9 9900K @ 5.1Ghz and 32deg C - delid + Grizzly Conductonaught LM
Motherboard Gigabyte Aorus Z390 Gaming X
Cooling Custom water cooling loop - GPU + mobo (+VRM's) + CPU
Memory G Skill - Trident Z RGB DDR4 - 3866Mhz x 32Gb @ 3800Mhz
Video Card(s) Gigabyte Aorus 11Gb GTX 1080 Ti Waterforce Extreme @ 2250Mhz
Storage Samsung 500Gb M2 970 EVO + Samsung 850 Pro SSD + ADATA 512Gb SSD + Samsung 1Tb & 3T + WD 1Tb + 3Tb
Display(s) ASUS 27" ROG Swift 1440p @ 165Hz & BenQ 27" LED
Case Thermaltake Core P7 - Open frame
Audio Device(s) Logitech Z906 - 5.1ch
Power Supply EVGA 1200W
Mouse Roccat LeadR + Razer Nagar V2 Pro
Keyboard Corsair K70 LUX with Cherry Red switches
Software Win 10 Pro 64bit
Benchmark Scores v/fast
hi all,
Just about to do an upgrade to my current setup going from a Gigabyte Z270X Gaming 9 to a Gigabyte Z390 Gaming X.
Unlike my Z270 mobo, the Z390 doesn't come with a mobo standard waterblock.
I'm thinking of using 2 x Heatkiller Copper waterblocks on the mobo heat sinks near the cpu socket.
My question is = What would be the best approach as far as securing the water block to the heat sinks = thermal pads, TIM paste (Arctic, etc) or straight metal to metal ??
regards and thanks in advance
9,340 (6.15/day)
Louisiana
Keyboard G710+x3
HI,
Doubt you nee one stock vrm coolers are sufficient
But like all stock coolers they're attached with screws/ bolts through the back of the board.
347 (0.09/day)
Oztralia down under
System Name K9
HI,
hi m8,
I'm not going to remove the stock heat sinks = I'm going to add the new copper w/b's to the top of the existing vrm coolers.
BTW = my case is a Thermaltake P5 open case with NO fans anywhere = everything is watercooled.
9,340 (6.15/day)
Louisiana
Keyboard G710+x3
HI,
Use self tapping screws they don't need to be very long 3/4"
Pre-drill into the stock coolers.
347 (0.09/day)
Oztralia down under
System Name K9
hi m8,
Thanks 4 the reply.
That's exactly how I was going to do it.
But my original question was = What would be the best approach as far as securing the water block to the heat sinks = thermal pads, TIM paste (Arctic, etc) or straight metal to metal ?? edit = TIM or no TIM between the components.
regards
9,340 (6.15/day)
Louisiana
Keyboard G710+x3
Little bit of paste a pad would be too thick.
347 (0.09/day)
Oztralia down under
System Name K9
1,248 (0.30/day)
Motherboard MXI APEX
Storage 660P 1TB, 860 QVO 2TB
Case Open Benchtable V2
Audio Device(s) SB X-Fi
Power Supply MSI A1000G
Mouse G502
Keyboard G815
Software Gentoo/Windows 10
This is interesting. I see up to around 100C on my Gigabyte Z390M Gaming board also. Were you planning to file the stock heatsinks to a flat profile for mating with the waterblocks?
Outback Bronze
1,890 (0.41/day)
Walkabout Creek
System Name Raptor Baked
Processor 14900k w.c.
Motherboard Z790 Hero
Cooling w.c.
Memory 32GB Hynix
Video Card(s) Zotac 4080 w.c.
Storage 2TB Kingston kc3k
Display(s) Gigabyte 34" Curved
Case Corsair 460X
Power Supply PCIe5 850w
Mouse Asus
Keyboard Corsair
Software Win 11
Is it possible to just put those Heatkillers straight on the VRM's once/if you take off the original heatsinks?
You can Trim the Heatkillers to size each end and drill a hole through where the holes need to be then place a screw and nut that fits no?
I Suppose once you get the Heatkillers you will be able to have a better look see at what would be possible.
Trying to get them on top of the heatsinks would not be very effective (plus look awkward) TBH but each there own ;)
347 (0.09/day)
Oztralia down under
System Name K9
hi m8,
I've had a closer look at the existing mobo heat sinks and it would be quite easy to remove them and mount the Heatkiller blocks straight onto the VRM's = with some slight modifications - drilling & cutting.
thanks for all the replies.
I'll update this thread with pics at a latter date.
9,340 (6.15/day)
Louisiana
Keyboard G710+x3
Yep warranty would be gone the other way thought that was a given :)
