- Oct 21, 2005
- 6,880 (1.02/day)
- USA
- Heatware
- 8 0 0
System Name | Computer of Theseus |
Processor | Intel i9-12900KS: 50x Pcore multi @ 1.18Vcore (target 1.275V -100mv offset) |
Motherboard | EVGA Z690 Classified |
Cooling | Noctua NH-D15S, 2xThermalRight TY-143, 4xNoctua NF-A12x25,3xNF-A12x15, 2xAquacomputer Splitty9Active |
Memory | G-Skill Trident Z5 (32GB) DDR5-6000 C36 F5-6000J3636F16GX2-TZ5RK |
Video Card(s) | EVGA Geforce 3060 XC Black Gaming 12GB |
Storage | 1x Samsung 970 Pro 512GB NVMe (OS), 2x Samsung 970 Evo Plus 2TB (data 1 and 2), ASUS BW-16D1HT |
Display(s) | Dell S3220DGF 32" 2560x1440 165Hz Primary, Dell P2017H 19.5" 1600x900 Secondary, Ergotron LX arms. |
Case | Lian Li O11 Air Mini |
Audio Device(s) | Audiotechnica ATR2100X-USB, El Gato Wave XLR Mic Preamp, ATH M50X Headphones, Behringer 302USB Mixer |
Power Supply | Super Flower Leadex Platinum SE 1000W 80+ Platinum White |
Mouse | Zowie EC3-C |
Keyboard | Vortex Multix 87 Winter TKL (Gateron G Pro Yellow) |
Software | Win 10 LTSC 21H2 |
Edit: Power Supply has been sent to stinger808!
This came with a computer case I bought. The power supply is used. I tested it with a multimeter and it registered: 11.78V 12V, 3.33V+ on 3V, 4.97V on 5V. Seems to be a perfectly operational unit but I have not used it with a motherboard so it would be as is.The cable grommet appears to be missing and the cables are held with a zip tie, doesn't seem to change performance. You can see that in a picture.
edit: Actually it came this way according to review.
This is a give away. The unit weighs just under 5 lbs so all I am asking is the cost for a medium flat rate box to ship it to you, $14. Again the item is AS IS. No Guarantees.
I don't want you guys expecting a mint power supply and blowing up your rig, but it does seem to be an okay unit with my limited testing ability.
You could give me your zipcode and I could see if there was a cheaper way of getting it to you such as fedex smart post or parcel select. US only. If you live locally we could arrange a pickup, my location is Baltimore MD.
Thanks guys.
Heres a TPU review of the unit:
https://www.techpowerup.com/reviews/LianLi/PC-A05N/5.html
Lian Li Maxima Force PS-A 470GB
General
Thanks guys.
General
- Specification Compliance
ATX12V 2.3/ EPS12V - Manufacturer
Lian Li
- Input Voltage Range
AC 100 - 240 V - Power Output Connectors Details
1 x power 24 pin ATX with detachable 4 pin section
2 x 6 pin PCI Express power
4 x 4 pin internal power
1 x 4 pin mini-power connector
4 x 15 pin Serial ATA power - Output Voltage
+3.3, +5, ±12 V - Power Capacity
470 Watt - Frequency Required
50 - 60 Hz - Specification Compliance
ATX12V 2.3/ EPS12V - Power Provided
470 Watt - 80 PLUS Certification
80 PLUS
- Type
none
- Compliant Standards
UL, TUV, BSMI, NEMKO, FCC - Features
Overheat protection, overcurrent protection, overvoltage protection, overpower protection, overload protection, undervoltage protection, short-circuit protection - Cooling System
120 mm fan
- Min Operating Temperature
32 °F - Max Operating Temperature
104 °F
- Brand
Lian Li - Product Line
Lian Li MAXIMA Force - Model
PS-A470GB - Packaged Quantity
1 - Compatibility
PC
- Manufacturer
Lian Li
