JackyNoTouchy
- Dec 29, 2018
- 12 (0.01/day)
- Ireland
Hi! I'm new here
I have a weird problem. I bought an powercolor rx 460 4gb off ebay. The card booted first time I installed the drivers and restarted had no output or no display.
I uninstalled drivers and it still didn't boot. Eventually it worked again after a few hours of rebooting drivers installed and I restarted gpu worked flawlessly for a few hours I ran game benchmarks and FurMark with zero issues. I restarted and got another black screen it wasn't recognized in device manager either. I restarted the pc multiple times until it was recognized in device manager but had errors, I looked at it in gpu-z and the gpu and memory clocks were at 0MHZ . I figured that its previous owner flashed the card with a modified bios and bricked the card. I found the original bios eventually. I jumped pin 1 and 8 on the bios pin to get it recognized I used my igpu and eventually I flashed the original bios onto it using ati flash I swapped back to pci express graphics in the mobo and the card booted the gpu clock (1212MHz) and memory core(1750+MHz) were correct again and the card was working with zero issues. I thought it was fixed. I benched it again with no errors or instability it was perfect. I restarted and its gone again!
I have tested it in 2 pcs and it has the same issues on both. I am really confused to why its not being recognized in device manager every time. I have checked all the card hardware and its all ok no dead mosfets the voltages are correct ect. I originally thought the core was dead but its still working perfectly so it must be something else.
If anyone has any idea what could be causing this I would be grateful. Please don't just comment and say its dead because the core is definitely still working.
Also heres the gpu screenshot when it was working.
Pc Specs:
CPU: Core i5 4570
GPU: Powercolor RX 460 4gb https://www.techpowerup.com/gpu-specs/powercolor-red-dragon-rx-460-4-gb.b3771
Ram: 8gb
PSU: Corsair VS 450
Pc Specs:
CPU: Core i5 4570
Ram: 8gb
PSU: Corsair VS 450
