haswell input power problem?
80 (0.15/day)
Likes
11
System Name Lightning
Processor 4790K
Motherboard asrock z87 extreme 3
Cooling hwlabs black ice 20 fpi radiator, cpu mosfet blocks, MCW60 cpu block, full cover on 780Ti's
Memory corsair dominator platinum 2400C10, 32 giga, DDR3
Video Card(s) 2x780Ti
Storage intel S3700 400GB, samsung 850 pro 120 GB, a cheep intel MLC 120GB, an another even cheeper 120GB
Display(s) eizo foris fg2421
Case 700D
Audio Device(s) ESI Juli@
Power Supply seasonic platinum 1000
Mouse mx518
Software Lightning v2.0a
#1
hello fellas, I've been trying to increase the frequency of my haswell, but something funky is going on (I think)
all the way up to 4600 mhz for every voltage I increase the core the same increase in vIN stabilizes it.
but here is the problem, I think: while for 4600 mhz I manage to get along with 1.67 vIN, for 4700 mhz even 1.9 appears to be insufficient
the mobo is far from steallar (asrock z87 e3, it use 3pin mosfets for cpu power) but the whole thing is on water so mosfets on water (50 C) cpu on water (at 4700 1.35v could get to 80C)
what do you think ? limit of the power system ?
I try increase/decrease the vcore but here is what is hapen: when decrease below 1.34 it BSOD verry fast (interrupt was not received within the necessary time on the secondary processor). when increase above 1.35 is also BSOD fast with the same message. it managed to last for about an hour or two at 1.34/1.35.
I try 1.36v with 2.0v input, it BSOD in 50 minutes
im testing with old version of prime95 which is without AVX using the small FFT mode
2,931 (0.86/day)
Likes
2,010
Denmark
System Name The work PC / X58 Linux cruncher/4790 folder&cruncher /2700x on/of folder/2700x full time WCG
Processor W3670 3.7 GHz/ W3670 3.875 / 4790K 4.4/2x2700x stock
Motherboard Gigabyte GA-X58A-UD5/UD7/Maximum Hero/2xMSI X470 M7 AC
Cooling Custom WC/Noctua NH-D14/Noctua NH-D15/ 2xNH-U12S SE
Memory 6 GB A-Data/6 GB Mushkin /8 GB Corsair Vengance/2x16 GB XSkill Flare
Video Card(s) 2060 Z MSI/ 1070ti MSI / 2x2070 Z MSI/1070 X + 2060 Z MSI/GTX 970
Storage 480 GB SSD / 480 GB SSD /480 GB SSD/2x250 GB SSD
Display(s) Dell UltraSharp U2518D/2408WFP
Case Corsair 800D / Fractel R4 /none/Lian test bench/NZXT 500 crap
Power Supply Enermax 87+ 600 W/ 700 W / AX 860/AX 860i/AX 760
Software WIN7 64 bit/Linux for AMD and
Benchmark Scores Cherry pie at one point ;)
#2
The first thing that the boffins will ask you is to fill this out - System spec.
80 (0.15/day)
Likes
11
Processor 4790K
Case 700D
Mouse mx518
#3
done, thank :)
80 (0.15/day)
Likes
11
Processor 4790K
Case 700D
Mouse mx518
#4
I think it's a cooling limit, I had it running for some time on prime small up to 74 C no problem (4600 mhz, 1.3v), started a game the card heated the loop flipped him into 80 C and BSOD :x it also explain whay 4700 mhz take time to BSOD after 50 minutes
im out of liquid metal, if I remove the water block from the cpu the pressure will damage the ultra won't it ? even if the lid is still closed
do you think if I replace MX4 between ihs and block with kryonaut 12.5 it will give a significant improvement ?
525 (2.00/day)
Likes
195
Haswell, USA
System Name Matrexx 55 | AW 17 R1 | Tornado F5 | MBP 2015 |(The lads)
Processor i7 8700K 5GHZ 1.35v | 4900MQ 4.1GHZ 1.2V | 7700K 4.5GHZ -50mv | 4980HQ 3.5ghz -110mv
Motherboard Z390 Gaming X | Dell AW 17 R1 | MSI 16L1 | Apple 2015 MBP
Cooling Macho Rev B | Laptop heatsinks
Memory 64GB | 32GB | 32GB | 16GB
Video Card(s) Vega 56 | GTX 1070 | GTX 1080 | M370X/Vega 56
Storage 512GB SSD/1.5/3TB HDD | 512GB MSATA | 240GB M.2+ 480GB SATA | 512GB "NVME"
Display(s) 1080P 144HZ/1600P 75HZ | 1080P 120HZ 17.3" | 1080P 120HZ 15.4" | 15.4" 2880x1800
Case Matrexx 55 | Laptop shells
Audio Device(s) Various sound cards
Power Supply 750W | 330W for both | 85W
Mouse too many
Keyboard K552 | Acer and Dell OEM KB's |
Software Windows 8.1/Windows 10/OSX "Mojave"
#5
The CPU just isn't binned high enough, you're hitting a voltage wall. An example of this would be like trying to OC a Ryzen, no matter how much voltage you throw at it won't go over 4.2-4.3
