I've been working with the CCC Profile-Fan-Hack for a while now and have been updating the instructions regularly on some other Forums that I belong to. So if anyone still prefers to control their fan speed old school
like me see below. I love Rivatuner myself and have used it for my past two Nvidia Cards, but I figured why have another program like Rivatuner running in the system tray when I don't have to as my HD4870 needs only a single fan-speed to operate stabily. Anyway, I know this is a little late to the party but here ya go .....
First of all, many thanks to Bretware on Guru3D who originally came up with the concept for this. See link below. Great little fix, single Card users only need to make two changes in the XML file created by your ATI Profile. I tried this and it worked perfectly using a fan-speed of 38%.
http://forums.guru3d.com/showpost.php?p=2751569&postcount=8
First Enable Overdrive in the Catalyst Control Center.
Then Create a new Profile using the Profiles Manager in the CCC and make sure Save All Catalyst Control Center Settings is selected.
For Vista
Open any Folder, goto Organize Menu --> Folder and Search Options --> Select View Tab ---> Select "Show Hidden Files and Folders".
Then goto the following location and open the following file for editing "C:\Users\Your Windows ID\AppData\Local\ATI\ACE\Profiles\Your CCC Profile.XML. The xml file will have the same name as the Catalyst Profile you saved. right click and hit edit.
For XP
Open any Folder, goto Tools Menu --> Folder Options --> Select View Tab ---> Select "Show Hidden Files and Folders".
Then goto the following location and open the following file for editing "C:\Documents and Settings\Your Windows ID\Local Settings\Application Data\ATI\ACE\Profiles\Your CCC Profile.XML. The xml file will have the same name as the Catalyst Profile you saved. right click and hit edit.
HD 4850/HD4870 Users - should change the values below
Bolded in Red within the Profile XML file.
<Feature name="FanSpeedAlgorithm_0">
<Property name="FanSpeedAlgorithm" value="Automatic" />
</Feature>
<Feature name="FanSpeedRPMTarget_0">
<Property name="Want" value="0" />
</Feature>
<Feature name="FanSpeedPercentTarget_0">
<Property name="Want" value="23" />
Crossfire Users - must also make identical changes to the section labeled <Feature name="FanSpeedAlgorithm_1">
</Feature>
<Feature name="FanSpeedRPMTarget_1">
</Feature>
<Feature name="FanSpeedPercentTarget_1">
HD HD4870X2 Users - should change the values below
Bolded in Red within the Profile XML file. Note if changing the section beginning FanSpeedAlgorithm_1 does not work, try making your changes in the section for FanSpeedAlgorithm_0. It seems results vary between brands of the X2.
</Feature>
</Feature>
Change the "Property name="FanSpeedAlgorithm" value=" from "Automatic" to "Manual"
Then under "FanSpeedPercentTarget_x", change "Property name="Want" value=" from "23" to your desired fan speed.
Save the file then reload the Profile you just edited in the CCC. Done.
Edit 1:
After experimenting with my HIS HD4870 I found a fan-speed of 39% works best for me. My temps went from 79C at idle to 48C.
Edit 2:
Contrary to instructions posted on Guru3D by Bretware, most people are able to set their fan speed to "Automatic" rather than "Manual". Having it set to "Automatic" should allow the fan speed to ramp-up if needed beyond the fan-speed you entered. This doesn't work for me however and I must use "Manual".
Edit 3:
If you're using Catalyst Drivers 8.6 Hotfix there is no "Profiles" Sub-Folder in the Path and your Profiles will be created in C:\Documents and Settings\Your Windows ID\Local Settings\Application Data\ATI\ACE\Your CCC Profile.XML
