Help!!!!! Building a PC for the first time what does these things do
david li
18 (0.01/day)
So right now I'm building my very first PC and I have almost all the part I needed, at least I think. So I was told that I need a network adapter so I did try to look it up but Than I found out I need a pci express card. What does these two card actually do? They look exactly the same.
CAPSLOCKSTUCK
Spaced Out Lunar Tick
8,578 (2.11/day)
llaregguB...WALES
System Name Party On
Processor Xeon w 3520
Motherboard DFI Lanparty
Cooling Big tower thing
Memory 6 gb Ballistix Tracer
Video Card(s) HD 7970
Case a plank of wood
Audio Device(s) seperate amp and 6 big speakers
Power Supply Corsair
Mouse cheap
Keyboard under going restoration
qubit
Overclocked quantum bit
17,865 (2.99/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
The network card is built into every modern motherboard, so you don't need one of those.
List the make and model of everything you've bought so we can help you better. I see others have beaten me to it. :D
Welcome to TPU. :)
sneekypeet
Retired Super Moderator
29,409 (4.47/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
From his I cant install my cooler thread, he states he has an X99 motherboard. I am going to guess it is built in ;) This one: https://www.asus.com/us/Motherboards/X99-A-II/ and specs say it has an Intel® I218V, 1 x Gigabit LAN Controller(s)
Right there is the critter you are looking for...
736 (0.18/day)
Kolkata, India
System Name barely hangin on...
Processor Intel I5 4670K @stock
Motherboard Asus H81m-cs (nothing else available now)
Cooling CM Hyper 212X (in push-pull)
Memory 16GB Corsair Vengeance Dual Channel 1866MHz
Video Card(s) Asus RX 580 4GB Dual
Storage WD Blue 1TB, WD Black 2TB, Samsung 850 Evo 250GB
Display(s) Acer KG241QP 144Hz
Case Cooler Master CM 690 III (Transparent side panel) - illuminated with NZXT HUE RGB
Audio Device(s) FiiO E10K>Boom 3D>ATH M50/Samson SR850/HD599SE
Power Supply Corsair RM 850
Mouse Redragon M901 PERDITION 16400 DPI Laser Gaming Mouse
Keyboard HyperX Alloy FPS Mechanical Gaming Keyboard (Cherry MX Brown)
Software 7-64bit MBR, 10-64bit UEFI (Not Multi-boot), VBox guests...
Dude has no idea about computers and he bought a high-end system. Someone is giving him really bad advice.
david li
18 (0.01/day)
Welcome to TPU. :)
I have Asus x99 a-ll motherboard, so what's a pci-express card ???? Do I really need it.
40,435 (6.59/day)
Read your motherboard manual for all features on the board itself. If you have a motherboard that came with a Killer Lan card follow instructions in your motherboard manual to determine what slot to insert it into.
Reading/knowledge is power.
david li
18 (0.01/day)
Alright thanks
40,435 (6.59/day)
There are videos that help with building computers this day and age, when I started I read books.
20,758 (3.41/day)
System Name Pioneer
Processor Ryzen R9 7950X
Case Thermaltake Core X31
Keyboard WASD Code v3 with Cherry Green keyswitches
Software Windows 11 Enterprise (legit), Gentoo Linux x64
PCI Express is a slot built into your motherboard for add-on cards, these are not typically needed unless you have a reason.
rtwjunkie
PC Gaming Enthusiast
13,909 (2.42/day)
System Name Bayou Phantom
Power Supply Seasonic X-850
Look at the picture above by @sneekypeet. Unless your network adapter is broken, you don't need a pci express network adapter.
101 (0.04/day)
Germany
Processor AMD Ryzen 5 1600
Motherboard ASRock AB350 Pro4
Cooling Cryorig H7 via Noctua NF-F12
Memory Crucial Ballistix Sport LT white 2x8GB, DDR4-2400
Video Card(s) Gigabyte R9 390 G1 Gaming via Arctic Accelero Xtreme III
Storage Samsung 840 250GB (OS), Crucial MX300 750GB
Display(s) Samsung 40" LED 1080p TV
Case Fractal Design Define S - Front: 3x Noctua NF-P14s redux-1500, Back: Noctua NF-P14s redux-1500
Power Supply Corsair Vengeance 650M
Software Windows 10 Home
PCI Express (PCIe) 3.0 - Everything you Need to Know As Fast As Possible
Beginners Guide to Motherboards
53 (0.02/day)
Spain
Processor AMD Ryzen 3700X
Motherboard Gigabyte AB350N-Gaming
Memory 16 GB Corsair Vengeance 3200
Video Card(s) Nvidia RTX 2080
Storage Samsung 850 EVO 512 GB
Display(s) 1 x ASUS Predator 3440x1440 | 2 x HPZR24w 1920x1200
Case Corsair Obsidian 800D
Power Supply EVGA 600B
He should have bought a Mac, the expensive computer for those who know little about computers :[]
Hugis
819 (0.16/day)
Spain(Living) / UK(Born)
System Name Office / Gamer Mk IV
Processor i5 - 12500
Motherboard TUF GAMING B660-PLUS WIFI D4
Cooling Themalright Peerless Assassin 120 RGB
Memory 32GB (2x16) Corsair CMK32GX4M2D3600C18 "micron B die"
Video Card(s) UHD770 / PNY 4060Ti (www.techpowerup.com/review/pny-geforce-rtx-4060-ti-verto)
Storage P41Plat - SN770 - 980Pro - BX500
Display(s) Philips 246E9Q 75Hz @ 1920 * 1080
Case Corsair Carbide 200R
Audio Device(s) Realtek ALC897 (On Board)
Power Supply Cooler Master V750 Gold v2
Mouse Rii M01(3360Sensor)
Keyboard Logitech S530 - mac
Not helpful dude , we are a community that helps, with sage advice from time served tech peeps....
