HELP!! Confusion on PWM Y-Cable
3 (0.00/day)
Likes
0
#1
Hi everyone! I am the beginner of playing DIY on my own computer. I have searched the PWM Y-Cable in the market, they are only using in the mainboard. The PWM signal input from the mainboard is used to control a series of connected PWM fans for optimal performance in noise and cooling.
Now I come up some questions that need someone can fixed my confusion.
1) Why the PWM Y-Cable just used in mainboard, not in graphic card?
2) Is it necessary to input the signal from the GPU and make the RPM of VGA cooler and case fan at the same speed?
3) If it makes sense, why I cannot find the PWM Y-cable for graphic card?
That’s all I want to know. Thanks~
952 (0.27/day)
Likes
403
Processor i7 5820K
Motherboard ASRock X99 Extreme4
Cooling Swiftech ApogeeXT + EK-FC R9-290X DCII (2) + 3x120mm Rad + 1x120mm Rad + 2xDDC1T W/XSPC Dual pumpto
Memory 16GB Gskill DDR4
Video Card(s) ASUS R9290X-DC2OC-4GD5 + ASUS R9290X-4GD5
Storage Corsair ForceGT 120GB + Samsung 840 EVO 250GB + 3TB Seagate + MediaSonic Raid array (4x 3TB WDRED)
Display(s) Benq XL2730Z (1440P 144Hz, TN, Freesync) & 2x ASUS VE248
Case Corsair Obsidian 750D
Audio Device(s) Aune T1/Fiio E17/Realtek, SE535, TH-X00, ATH-M50 modded w/ V-Moda Boompro
Power Supply Corsair HX1000i
Mouse Sharkoon Fireglider optical
Keyboard Corsair K95 RGB
Benchmark Scores Thrustmaster HOTAS Warthog CH Pro Pedals
#2
1) Generally speaking, graphics card coolers have their own attached fans, which are wired to plug directly into the graphics card, and don't usually support adding more fans (As always, there are some exceptions to the rule). Computer cases usually have many spots for fans, some of which may be left to be added later (spots on the case which support adding a fan, but does not include one)
2) No. You want the graphics card's fan speed to be set based on the GPU temperature, and the case fans to be set based on either the CPU or "system" temperature.
3) See #1. A GPU PWM Y-Cable would be a very rarely used cable. That said, it is technically possible to make one.
This leads me to wonder why you are asking. What is it you are trying to do?
1,484 (0.57/day)
Likes
544
System Name My Surround PC
Processor Intel Core i7 4770K @ 4.2 GHz (1.15 V)
Motherboard ASRock Z87 Extreme6
Cooling Swiftech MCP35X / XSPC Rasa CPU / Swiftech MCW82 / Koolance HX-1320 w/ 8 Scythe Fans
Memory 16GB (2 x 8 GB) Mushkin Blackline DDR3-2400 CL11-13-13-31
Video Card(s) MSI Nvidia GeForce GTX 980 Ti Armor 2X
Storage Samsung SSD 850 Pro 256GB, 2 x 4TB HGST NAS HDD in RAID 1
Display(s) 3 x Acer K272HUL 27" in Surround 7860x1440
Case NZXT Source 530
Audio Device(s) Integrated ALC1150 + Logitech Z-5500 5.1
Power Supply Seasonic X-1250 1.25kW
Mouse Gigabyte Aivia Krypton
Keyboard Logitech G15
Software Windows 8.1 Pro x64
#3
I can see the need for such a cable, but I agree its use is rare. I, for example, have a 120mm fan pointed directly on my graphics cards, so I can see myself wanting to have its speed controlled by the graphics cards' temperatures rather than the system temperature.
That said, there are very almost no situations where graphics are being taxed but the CPU is idle, whereas the reverse is very common, so using the CPU PWM signal is a good compromise since you likely wouldn't have a situation with inadequate GPU cooling.
609 (0.13/day)
Likes
76
London, UK
System Name this_is_so_leet_it_needs_no_name
Processor Intel I5 2500k @ 4.5Ghz
Motherboard Asus P8 P67-M Pro
Cooling MUX-120 with Dual Fan
Memory Samsung Memory DDR3 2133 Overclocked (non LP)
Video Card(s) XFX ATI/AMD 5870 1gb @ [tbc]
Storage 2*2tb Samsung Raid 0 + 64gb Kingston SSD
Display(s) BenQ G2420HDBL LED monitor
Case Lian Li PC-60 old skool alu case
Audio Device(s) Asus Xonar DX/XD PCI-Express (great)
Power Supply Corsair 650 TX
Software Win 7 64bit
#4
I think the main use for one of these is when you have one mobo CPU fan socket and 2 CPU fans. That's what I use mine for. GPU can handle its own fan speeds.
Beware when you do get one though, the signal wire should only be connected to one fan, if both are connected you get double the RPM reported which is no good. I had to mod my splitter cable.
140 (0.05/day)
Likes
47
Finland
Processor i7-2500K @ 4.5 GHz
Motherboard Gigabyte GA-Z68XP-UD4
Cooling EK Supreme HF
Memory Kingston HyperX Genesis 2 * 4 GB
Video Card(s) Radeon HD 7950
Storage OCZ Agility 3
Case Bitfenix Shinobi XL
Power Supply Super Flower SF-700P14XE
