Help ! Gigabyte Rtx 2080 super white led blinking no fans and display
poskelele
12 (0.38/day)
germany
Hello guys and girls,
I need your help as I didnt find anything like this exactly.
Befere I sold my it was working fine.Then I sold it on ebay and on the first day the buyer received the card he said the led over the pcie connectors are blinking white and no display.
Ofcourse I am an idiot and have no proof that the card was working so he won and sent the card back.
Now I tried the card and same problem with 500w Pure power 11 von be quiet and 1000w Dark power pro 10 also bequiet. White leds blinking over the power connector and no fans spinning.
The card was working on the 1000w dark power pro before so the abnormal power supply problem is out of question.
So my question is, should i dissasamble the card and look for some damage and post the pictures here or could this be still a psu problem ?
no warranty on the card bought it from someone it was from a prebuild.
thanks in advance !
32,828 (6.28/day)
You can pay for an RMA.
268 (1.69/day)
Processor Ryzen 5 3600
Motherboard B550 Elite
Cooling Hyperx 212
Memory Hyperx fury 16Gb DDR4 3333Mhz
Video Card(s) 3060 ti gaming oc pro
Storage Samsung 970 Evo 1Tb plus some HDDs
Power Supply MSI 750w
Mouse G502
poskelele
12 (0.38/day)
germany
abnormal power supply, right on their website
I literally wrote this in my post that I know what it is....
The question is why it is reporting abnormal power it WAS working and now isnt.
The psu didnt change.
You mean contacting gigabyte and asking them for repair ?
268 (1.69/day)
Cooling Hyperx 212
Mouse G502
did you changed the cables when you swapt the PSU's?
poskelele
12 (0.38/day)
germany
did you changed the cables when you swapt the PSU's ?
What do you mean by Changed cables ? I used The same Mainboard with The Card in two different Cases.
should I try with a different motherboard ?
1,795 (0.40/day)
MN
System Name Personal / HTPC
Processor Ryzen 5900x / i5-4460
Motherboard Asrock x570 Phantom Gaming 4 /ASRock Z87 Extreme4
Cooling Noctua NH-U9S / stock HSF
Memory 16GB DDR4 3200 / 8GB DDR3 1600
Video Card(s) EVGA RTX 3060Ti XC / EVGA RTX 3060 XC
Storage 500GB Samsung Pro 970, 250 GB Crucial SSD MX200, 1TB & 500GB Western Digital / 2x 4TB WD Red
Display(s) Dell - S3220DGF 32" LED Curved QHD FreeSync Monitor / 50" LCD TV
Mouse Zephyr Gaming Mouse
Keyboard Microsoft Natural Elite Keyboard
Software Windows 10 Pro 64 / Windows 10 Home 64
Did the buyer send back the same GPU as you shipped to them?
Shady folks out there do shady things.....I wouldn't put it past someone to swap GPUs on you. Buy a working card to replace their same make/model card and send back their bad card to the seller. I'm not saying this happened, but you never know.
poskelele
12 (0.38/day)
germany
Yeah I considered it but forgot to check. Thanks !
Nope its my gpu
Tried different Motherboard same problem.
The debug Led is glowing Red on VGA do Something is wrong
Those two Look suspicous to me.
Tigger
I'm the only one
12,848 (2.26/day)
System Name Nothing new
Processor Ryzen 5 2600x
Motherboard Asus TUF B450 Pro s
Cooling Custom loop,
Memory 2x8gb 2400
Video Card(s) MSI GTX980TI Gaming 6gb, water cooled
Storage WD blue 256gb M2, WD blue 4tb HDD
Display(s) MSI 32" Optix AG32CV 1080p 165hz
Case Thermaltake V21
Audio Device(s) onboard/Logitech Z4
Power Supply Corsair TX750M
Mouse Razer Viper
Keyboard Corsair k65
Software Win 11 Home x64
Benchmark Scores do they matter
Did it have any sort of tamper seal on it?
Possibility he has switched it. you should have noted the serial number down, and possibly security marked it.
poskelele
12 (0.38/day)
germany
There wasnt any but on my old Photos there werent any either.
But on the right of the PCI e pins there is a V Number it is the same and i checked other Cards on zhe internet and all Had a different Number so it seems Like It really is my Card.
268 (1.69/day)
Cooling Hyperx 212
Mouse G502
you said you tried 2 different be quiet PSU's, did you also use different cables or just used ones for both?
poskelele
12 (0.38/day)
germany
Two different as Said, one psu is the same as it was before i sold the Card and IT was Wirkung. The other one isn't modular.
I would say its not the PSU.
268 (1.69/day)
Cooling Hyperx 212
Mouse G502
the card is clearly telling you it has a power issue, if it isn't the PSU and i believe you then it's the card, the 8pin and 6 pin connectors
poskelele
12 (0.38/day)
germany
Yes did you See the Photo with the solder its under the 6 pin I believe
268 (1.69/day)
Cooling Hyperx 212
Mouse G502
i hadn't seen the photos, then it's explained i was talking out of my ass then. sorry.
32,828 (6.28/day)
Yes
poskelele
12 (0.38/day)
germany
it seems he really sent me a different card. I found a photo where you can see the SN number not clearly but enough to see that it is different to what I got now.
I contacted ebay but they cant do anything, I am going to confront the buyer through ebay and see what he will answer.
thanks for your help till now guys.
3,056 (3.14/day)
Poland
Processor Ryzen 7 3700X
Cooling BeQuiet Dark Rock 4
Memory 2x16 GB Crucial Ballistix 3600 CL16 Rev E
Video Card(s) EVGA 1060 6GB SSC
Display(s) Acer XB273GP
Mouse SteelSeries Rival 300
Keyboard MK Typist (Kailh Box White)
Isn't the serial number located on the backplate:
If dude was smart he should have swapped the backplate. The only way to prevent this would be to put identifiers on backplate and pcb itself.
268 (1.69/day)
Cooling Hyperx 212
Mouse G502
There's been a lot of talk about ebay, they are all about customer satisfaction and don't care about sellers, you can check the subreddit for ebay. You are screwed.
I almost put my old card on ebay when i read all the stuff there, lot's of sellers scammed, and just put on a local website for sale.
Tigger
I'm the only one
12,848 (2.26/day)
Memory 2x8gb 2400
Mouse Razer Viper
I would have not accepted returns, if you show proof of the card working, you don't have to. If you mark the sale as no returns, they are accepting the terms by buying the item. I see loads marked as no returns.
I guessed by the condition of the card it was different, that's why i said are you sure it's your card.
He has got your card and his money back now, so he will not even reply to your messages i bet.
poskelele
12 (0.38/day)
germany
Im sorry mit the serial Number on the Backplate.
i meant some Number that on the pcb.
The first Photo is my Card where IT hard to read but you can der that on the new Card adter
I have no return on my eBay listing, It doesnt matter for eBay if you have no Proof you Always loose
I meant the Number on zhe pcb itself.
In the first Photo ist really shit But i Changed zhe colors and sharpening you can. See that my Number is 20581 and now 00561
Tigger
I'm the only one
12,848 (2.26/day)
Memory 2x8gb 2400
Mouse Razer Viper
No return, i would not have accepted the card back. I have 2 bank accounts, 1 separate for ebay, so they can't rob my personal account in case of disputes.
poskelele
12 (0.38/day)
germany
here you can see it better that the first and second last numbers are different my card 1/a2/JGA790 20581 and now 1/A2/JGA790 00561.
Atleast in germany you dont pay to the seller itself anymore, you pay to ebay, ebay holds the money until the the buyer gets his package and then after 2 days they send you your money.
So I didnt even receive the money, so 2 bank account wouldnt do much.
3,056 (3.14/day)
Poland
Have you tried reporting fraud to ebay?
268 (1.69/day)
Cooling Hyperx 212
Mouse G502
