HELP HELP HELP - Phenom Dead?
Discussion in 'General Hardware' started by dotWdot, May 16, 2008.
  1. dotWdot New Member
    May 16, 2008
    4 (0.00/day)
    0
    Hello all,
    Have literally always managed to fix my own build problems but this one has me unsure...
    New Build with the following:
    [bullet]AMD Phenom Black Edition 9600
    Gigabyte MA790X-DS4 AMD 790X
    8gb gskill 1066 ram
    500gb sata hd
    pioneer blue ray optical
    HIS ATI radeon HD 3870 X2 1gb Graphics card
    All booted with a 1000watt jeantech psu[/bullet]
    All seemed to work fine at first, first power up ok - despite the problems i had with my last high end graphics card build, formatted hd, installed windows (xp :p) - all great - running xp for like 5 mins - started installing mobo drivers, restarted as software asked, but then when it rebooted it would hang while "continuing to install drivers" - for so long that first time I had to hard power off and reboot - then it did it again, after which it is now acting strange:
    it does the 1/2 second thing - where you press power on and it will, for about 1/2 a second - the fans run and the orange light goes on on the mobo - then it cuts out and thats that.
    Things to note:
    when u turn the main power switch on the psu on, keyboard lights come on like normal
    tested psu seperate - works fine with pins green+black shorted
    moved graphics card to seperate slot, reconnected everything several times, checked cpu, no apparent mobo shorting, moved ram, reset bios all with NO JOY!
    whatever i try it just does the same - its like the cpu has died?!?!? but literally it was running windows one minute and the next it cuts out and wont start again?
    Any ideas Dudes - pulling out my hair here...(well drinking wine)?!?!?
  2. dotWdot New Member
    May 16, 2008
    4 (0.00/day)
    0
    was mobo
    Hi all - thought Id share my solution with you incase anyones having same issue.
    The motherboard was dead - I rma'd it and the new one works perfectly!!
  3. infrared
    infrared Moderator Staff Member
    May 28, 2005
    3,972 (0.89/day)
    1,431
    Southampton, UK
    Glad to hear it all worked out :)
    10 Year Member at TPU Crunching for Team TPU More than 25k PPD
  4. dotWdot New Member
    May 16, 2008
    4 (0.00/day)
    0
    thanks - new system is great!!
