• We've upgraded our forums. Please post any issues/requests in this thread.
Help me decide on a cooling solution
1,745 (0.41/day)
Likes
176
The Nevada Wasteland
System Name 9th Level
Processor AMD Phenom II 940 BE @3.4Ghz
Motherboard GIGABYTE MA790FX-UD5P
Cooling Corsair H100, x2 250mm, x1 140mm, x3 120mm fans.
Memory 8GB Patriot DDR2
Video Card(s) EVGA GTX480 (800/1600/2000/@1.0v)
Storage x1 80GB, x2 1TB.
Display(s) Acer 24" 2ms 1920x1200
Case HAF 932
Audio Device(s) Sound Blaster Fatal1ty Xtreme gamer 64mb Xram
Power Supply Corsair HX850W
Software Windows 7 Ultimate 64bit
#1
I live in the desert, "Las Vegas" to be precise. In the summer the average temperature is 110-115F and 90F in the shade(thats 43-47C and 32C in the shade).
Right now I'm using an Xigmatek HDT S1283, and its the best air cooler I've ever had.
I'm open to Water cooling suggestions and aircooler suggestions. I had a crappy WCing kit at one point but my Xig beat it.
I mostly just want to know if there is any cooling solution that is better than what I have right now.
kiriakost
1,054 (0.32/day)
Likes
69
Volos, Greece
System Name ATLAS
Processor Q6600 QUAD
Motherboard ASUS P5QC
Cooling ProlimaTech Armageddon
Memory HYPER-X KHX1600C8D3T1K2 /4GX PC3-12800 1600MHz
Video Card(s) Sapphire HD 5770 VAPOR-X
Storage Raptors 73Gb - Raid1
Display(s) DELL U2311H
Case HEC Special moded ..
Audio Device(s) X-Fi Music + mods Audigy front Panel (full working)
Power Supply HIPER 4M780 PE 980W Peak
Software XP PRO SP3
#2
I will disappoint you , the totally best from the medium cooler on air, is about 5C deference.
Is this what you looking for ?
Water ... a true productive water cooling , will help but not as a magic solution, and its very costly , and hard to maintenance .
One simple mistake , can cause damage.
Do you like to spent most of your time looking for trapped air bubbles ?
3,626 (1.09/day)
Likes
938
Vietnam
System Name Gaming System / Laptop / HTPC
Processor i5 8600K @4.6Ghz / i5 540m / i7 970
Motherboard Z370 Aorus Ultra Gaming / Acer / Shuttle sx58j3
Cooling CM Seidon 120 XL / Laptop Cooling / SE-903
Memory T Group Nighthawk (3000 MHz)/ 4GB DDR3 / 12gb DDR3
Video Card(s) Colorful 1080Ti / G210m / 7870XT
Storage 750G MX300 + 3TB HDDs / 250G Ultra II /250G 850 EVO
Display(s) Dell U2515H + Asus VX239H/ 15.6" Laptop Screen / 720p 42" Plasma TV
Case Cooler master HAF 922 / Laptop Case / Corsair Air 240
Audio Device(s) On Board Realtek
Power Supply Andyson N700 Titanium / Laptop Power / ACBell 700 W
Mouse Logitech G700s
Keyboard CM Quickfire XT (Cherry MX Reds)
Benchmark Scores 3DMark Firestrike = xxxxx Timespy = 9097 Heaven = xxxx
#3
Go for the Coolermaster V8. I live with similar temps, only more humid. 32 in the shade aint too bad. Invest in greater airflow for your case and you should be fine.
1,477 (0.36/day)
Likes
95
Orange County, CA
System Name Battle Station
Processor AMD Ryzen 1700x
Motherboard ASRock X370 Taichi
Cooling Thermaltake Water 2.0 Pro
Memory GSkill Tridentz DDR4-3200 16 GB
Video Card(s) 1 x EVGA GTX 1080 Ti black edition
Storage Samsung 840 Pro 240 GB + 12TB storage
Display(s) LG 34UM94 3440x1440
Case Lian Li PC-80NB
Audio Device(s) Asus Xonar DX + Ultrasone Pro 900 + JBL SLR 308 speakers and SLR 310 subwoofer
Power Supply Corsair AX1200
Mouse Logitech G510
Keyboard Corsair K90
Software Window 10 Ultimate x64
#4
You can try TEC cooling from CoolIt. They are a bit pricey but everything comes pre-assembled. Ah Vegas, my last trip there last July, it was 117 F midnight, yikes!
1,745 (0.41/day)
Likes
176
Case HAF 932
#5
Thanks for the replys guys. TEC cooling is a bit extreme I think though.
I'll look at the CM V8 thanks.
