Help ME! flash wrong VGA Bios! help
Discussion in 'AMD / ATI' started by nc.studio, Apr 5, 2008.
  1. nc.studio New Member
    Apr 5, 2008
    7 (0.00/day)
    0
    :banghead:
    I'm new here, please help me fix my 3870X2! I was flash wrong bios, so It does not work at all:mad:
  2. triop
    triop New Member
    Mar 3, 2008
    14 (0.00/day)
    0
    Uk
    do you have onboard graphics?
  3. nc.studio New Member
    Apr 5, 2008
    7 (0.00/day)
    0
    My PC system is!
    My PC system is:
    Mainboard X38 (dual PCIe 16x) I have another VGA card (not on board), thanks you, please tell me how to fix the problem.
  4. sneekypeet
    Apr 12, 2006
    23,913 (5.89/day)
    8,577
    try using the serch function at top for blind flashing or I think it may be possible to flash with the old GFX and the 3870 in at the same time...you just need to be certain to use the right ID to flash to.
    This topic has been covered tho already for sure.
    May be quicker to search than to wait for those same few with experience in this exact endeavour!
    nc.studio says thanks.
    10 Year Member at TPU
  5. CrackerJack
    Dec 13, 2007
    2,758 (0.80/day)
    470
    use the other vga card. then flash the 3k with the factory bios. you don't have to blind flash if you have another card. PM if you need more help
  6. nc.studio New Member
    Apr 5, 2008
    7 (0.00/day)
    0
    Thank sneekypeet! after flash wrong bios, my HD 3870X2 not let my PC boot, so I have replace my old vga card to boot the PC. Right now the first PCIe 16x is the old card, the second PCIe is 3870X2 (but my pc is not show it up). any boby, help me please!
  7. CrackerJack
    Dec 13, 2007
    2,758 (0.80/day)
    470
    that's fine if it doesn't show it up. it won't if there's a bad flash. just restart and run ATIFLASH.
    run this command- atiflash -i
    and tell me if it sees your card then. IT SHOULD!!!
  8. MiST91 Guest
    or if that doesn't work, find your self a spare PCI (not express) graphics card, then try that, it can somtimes mess up flashing software having the card you dont want to flash as primary and the one you do secondary.
  9. CrackerJack
    Dec 13, 2007
    2,758 (0.80/day)
    470
    You can try this too, but it should work with pci-e. Always work for me.
    when you go to flash the card use this command.
    atiflash -p -f 1 (then the bios name)
    the one stands for the second slot, 0 is for the primary.
  10. nc.studio New Member
    Apr 5, 2008
    7 (0.00/day)
    0
    Thanks CrackerJack!
    now I'm out to fix, thanks a lot!
    thanks everybody.
