Help me pick quality 140mm case fans
672 (3.43/day)
Likes
342
Poland
Processor i7 5775c
Motherboard Z97X Gaming 5
Cooling Noctua D15S
Memory Crucial Ballistix Tactical LP DDR3L 2133MHz 9-9-9-27-1T 1.512v.
Video Card(s) GTX 1080 SuperJetstream
Storage Samsung 850 Pro 256(x2)+512GB / 3TB+1TB HDDs
Display(s) Acer XB1 24" 1440p 165Hz G-SYNC
Case Full tower
Mouse G403 wireless
Keyboard Razer Deathstalker
I need help choosing case fans. Currently I'm only running a single ML120 as rear exhaust, which is not doing a good job as far as noise since this is really a radiator fan.
I need three quiet 140mm fans to populate the rear exhaust and top exhaust of my case. My #1 would be bequiet silent wings 3 but they're expensive as hell. I need something less expensive. I'm fine with spending as much as two silent wings 3 140mm cost for three fans, so around 12-13 bucks for a piece.
are these good ?
https://www.newegg.com/Product/Product.aspx?Item=N82E16835709022
they're actually cheaper in Poland than they seem here, I can buy three for the price of two silent wings 3 140mm pwm.
6,433 (1.83/day)
Likes
8,589
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
#2
There doesn't seem to be anyone testing fans anymore, so you'll just have to go by end user reviews and some guide lines. Almost all 120 mm fans will operate quietly up to ~1200 rpm and the same can be said of 140 mm fans up to ~1000 rpm. So that Phanteks fan might have to be slowed down a bit according to how quiet you want it to be. The other fan that I'd suggest is the Fractal Design Dynamic GP-14 Also, to save some money, you don't have to replace that ML120, just slow it down until the noise it makes is acceptable.
Edit: I have a pair of these and they do quite well Fractal Design Silent Series R2
672 (3.43/day)
Likes
342
Poland
Processor i7 5775c
Cooling Noctua D15S
Case Full tower
Mouse G403 wireless
they (the ml120s) don't seem to work well with gigabyte's pwm bios options. they often get stuck at 1600rpm even at the lowest pwm setting.
7,505 (3.85/day)
Likes
9,717
Massachusetts
Processor i7 4790
Motherboard Asrock Z97 Extreme 4
Cooling Corsair H-110i GTX
Memory 16 Gb kingston Hyper X
Video Card(s) Nvidia Reference GTX 970 x2
Storage C:\Samsung 850EVO 500Gb & Samsung 850 evo 250Gb
Display(s) Dell Ultra Sharp Widescreen 24" 1200P
Case Phanteks Enthoo Pro M Acrylic
Audio Device(s) Realtech Edition X1789,Ver2.78
Power Supply EVGA 220-G2-0650-Y1
Mouse Logitech G502 spectrum
Keyboard AZIO MRGB Kaith Blue
Benchmark Scores Congrats USA!! on the Travel Ban.....
#4
i have those phanteks, and if noise is a problem, you might not like them....their not super noisy, but louder than some. I like Scythe Kaze, or Scythe Grand flex, but those are probably more expensive than anything your going to find.....sadly "good" costs big $. im sure you can find some decent corsairs, or Noctuas for not too too much...
\maybe the followin *edit* i mistook the phanteks You posted for a different type i think, those look pretty decent. i think i was thinking of the 120mm ones
https://www.newegg.com/Product/Product.aspx?Item=N82E16835352007
https://www.newegg.com/Product/Product.aspx?Item=N82E16835352020
https://www.newegg.com/Product/Product.aspx?Item=N82E16835608065
https://www.newegg.com/Product/Product.aspx?Item=9SIA68V3S01913
id bet fractals are pretty nice, and the beQuiets in the link above arent TOO pricey ($13) i dunno if its the same price in Your region.
672 (3.43/day)
Likes
342
Poland
Processor i7 5775c
Cooling Noctua D15S
Case Full tower
Mouse G403 wireless
what about noctua redux 1200rpm
wow those fractal fans have impeccable opinions, and they're cheap and quiet. I think I found my answer. thanks a thousand times.
12,719 (2.60/day)
Likes
6,060
Europe\Slovenia
System Name Dark Silence 2
Processor Intel Core i7 5820K @ 4.5 GHz (1.15V)
Motherboard MSI X99A Gaming 7
Cooling Cooler Master Nepton 120XL
Memory 32 GB DDR4 Kingston HyperX Fury 2400 MHz @ 2666 MHz
Video Card(s) AORUS GeForce GTX 1080Ti 11GB (2000/11100)
Storage Samsung 850 Pro 2TB SSD (3D V-NAND)
Display(s) ASUS VG248QE 144Hz 1ms (DisplayPort)
Case Corsair Carbide 330R Titanium
Audio Device(s) Creative Sound BlasterX AE-5 + Altec Lansing MX5021 (HiFi capacitors and OPAMP upgrade)
Power Supply BeQuiet! Dark Power Pro 11 750W
Keyboard Cherry Stream XT Black
Software Windows 10 Pro 64-bit (Fall Creators Update)
#6
Get Silent Wings 3 PWM (High Speed version). When you'll hold one, you'll know why they cost so much. The plastic is really heavy, it has rubberized everything, even the ring around the fan, dual set of mounts, one for screws, one for tool-less mounting with anti-vibration pieces.
Don't go Silent Wings 2. They aren't bad, but SW3 are more optimized and provide higher pressure and airflow at even lower noise. The rest are the usual plastic framed fans. They aren't bad, but they aren't exceptional. SW3 are.
6,196 (1.65/day)
Likes
1,687
Austin Texas
System Name TimeDumpster
Processor Intel i7 7820X Delidded @ 4.75Ghz / 3.1Ghz Mesh
Motherboard MSI X299 Tomahawk
Cooling 240mm Corsair H105 Intake
Memory 32 GB Quad 3434Mhz DDR4 15-16-16-38-300-1T
Video Card(s) Gigabyte GTX 1080 Ti Gaming
Storage 1Tb Samsung 960 Pro m2, 1TB Samsung 850 Pro SSD
Display(s) Dell 24" 2560x1440 144hz, G-Sync @ 165Hz
Case NZXT S340 Elite Black
Audio Device(s) Arctis 7
Power Supply FSP HydroG 750W
Mouse zowie ec-2
Keyboard corsair k65 tenkeyless
Software Windows 10 64 Bit
Benchmark Scores Cb: 2103 Multi, 209 Single, 10450 Timespy - 10150 GPU/11900 CPU, superpi 1M - 7.71s
#7
i have those same phanteks in 120mm factor... they are silent low speed rad fans but i would not recommend them as exhaust case fans.
672 (3.43/day)
Likes
342
Poland
Processor i7 5775c
Cooling Noctua D15S
Case Full tower
Mouse G403 wireless
I'm torn now. SW3 have excellent specs, they move lots of air at decent pressure, and are only rated at 15.5dB :eek: Fractal Design GP14X2 are less impressive but still very good, and they cost half what SW3 cost. The main difference is air pressure, 0.71 on FD vs 1.08 on SW3. Does air pressure matter for case exhaust ?
I just remembered I bought LP ddr3 like two months ago and I can put another NF-A15 on my D15S too. RIP my wallet, but it's better to do the cooling well once and for all times, especially when my D15S is gonna serve me a long time, definitely though any future CPU upgrades.
1,696 (1.29/day)
Likes
835
SE Michigan
System Name Dumbass
Processor AMD-9370BE @4.6
Motherboard ASUS SABERTOOTH 990FX R2.0 +SB950
Cooling CM Nepton 280L
Memory G.Skill Sniper 16gb DDR3 2400
Video Card(s) GreenTeam 1080 Gaming X 8GB
Storage C:\SSD (240GB), D:\Seagate (2TB), E:\Western Digital (1TB)
Display(s) 2x Dell S2440L (16:9)
Audio Device(s) onboard (realtek?) SPKRS:Logitech Z623 200w 2.1
Power Supply Corsair HX1000i
Mouse Logitech G700s
Keyboard Logitech G910 Orion Spark
Software windows 10
Benchmark Scores http://i.imgur.com/gYkHqxU.jpg new pic soon.
#9
Not really, air pressure matters more if you use a radiator. although I have use SP fans for intake and non static pressure fans for exhaust and it worked out well for noise.
iirc, noctua and scythe used to be the quietest fans at mid-curve range speeds.
Still, the hands down best way to control noise with with a good fan controller, you can tame the high speed noisy-as-hell fans easy.
12,719 (2.60/day)
Likes
6,060
Europe\Slovenia
#10
Also, fans don't ever become outdated and they are all standard dimensions. Meaning you pay really expensive fans once and you have them for years. So, don't skimp on them. You'll be able to move them from build to build, "saving" on fans is really the worst thing one can do. I'm not sure why no one thinks this way that this is a very long term investment and not something for 1 year.
Btw, Corsair also has really good fans that are usually well priced, check those out as well.
672 (3.43/day)
Likes
342
Poland
Processor i7 5775c
Cooling Noctua D15S
Case Full tower
Mouse G403 wireless
OK, I made my wish list
and I'm also bidding this great 200mm fan.
http://allegro.pl/show_item.php?item=6937251538&isPostBid=true&msg=Twoja+oferta+jest+w+tej+chwili+najwyższa!+Gratulujemy!&isBidValid=yes&msgtoken=2f4347ccb1c3c52b059c8864ea0f32ef38294f4a81a6d309b35aa1537440cb14
I think it's one of the few 200mm fans that doesn't suck. Others have lousy air pressure, 0.3-0.4, the one I have now barely pushes the air, when you put your hand behind the hdd case you barely feel anything, I think it rated of 0.25 static pressure.
12,719 (2.60/day)
Likes
6,060
Europe\Slovenia
#12
I suggest you take High Speed version of Silent Wings 3 PWM 140mm. The reason for this is because in price, I think it's basically no difference, I think it was 1€ in my case, however with HS version, you can make some really high ventilation at 1600 RPM of HS version. But the fan is still capable of running at really low RPM without any problems making it inaudible (roughly 600-700 RPM), so you have option for best of both worlds. Really high airflow or really quiet operation in the same fan. Where with normal version, it might be lacking if you want to push a lot of air.
Btw, the HS version at top speed makes some noise, but the noise "profile" is really good, the noise is really not the annoying kind which is really nice.
672 (3.43/day)
Likes
342
Poland
Processor i7 5775c
Cooling Noctua D15S
Case Full tower
Mouse G403 wireless
I'd take your advice if only gigabyte was capable of making a bios pwm option capable of not sucking balls. Only way I can make it work is buy a silent 1000rpm fan and run it full speed. My current fans run at 1100-1200rpm when windows loads and they're pretty quiet, when I load a game they go to 1600-1700rpm (loud as hell) for no apparent reason, and to make it even worse they don't go back to 1200 rpm when I go back to idle. CPU fan works well though, it's sys_fan 1-3 that are flawed.
12,719 (2.60/day)
Likes
6,060
Europe\Slovenia
#14
I can't say for Gigabyte, but ASUS and MSI both have good fan controls. ASUS had excellent presets of Full Speed, Normal and Quiet where MSI only has full user controlled curve, but has option to control the input temperature. I can set it to adjust all fans per CPU temperature or per SYS temperature. Difference being, CPU temp fluctuates much more. When full load, it can spin fans fast and when load is gone, fans will drop in speed instantly. Where with SYS temperature, readings come from case internals. Which means it'll ramp up slowly and run for longer until temps inside case go down. You have to compensate for lower temperatures, so the curve needs to be adjusted at a lot lower temperatures (usually only up to 50°C where CPU curve goes up to 85°C in my case). Check if Gigabyte by any chance offers this. Or if SYS 1-3 are automatically run by SYS temp and not CPU (or is controllable and you have to adjust it).
I find this useful because all my heat is generated on the intake, meaning all the heat is dumped inside the case. SYS sensor allows me to ramp up fans only when case internal temp raises and is independent of the CPU heat. Which is pretty neat.
672 (3.43/day)
Likes
342
Poland
Processor i7 5775c
Cooling Noctua D15S
Case Full tower
Mouse G403 wireless
I got one more question. If I replace my ML120 rear exhaust with other fan, it means it'll be unused. The second ML120 will stay as bottom intake on noctua LNA adapter. Is there a benefit from "sandwiching" intake fans, I mean placing one on top of the other ?
FreedomEclipse
~Technological Technocrat~
17,262 (4.36/day)
Likes
5,466
London,UK
System Name Codename: Rapture X Mk.VI {Still....MoonPig Edition}
Processor Intel 3930k@4.5Ghz
Motherboard Asus P9X79 PRO
Cooling Corsair H105 {2x Corsair ML 120 Pro}|VRM: Antec Spotcool 100
Memory 32GB DDR3 Kingston HyperX Beast 2400Mhz {8x4GB}
Video Card(s) MSI 1070 Gaming X (Samsung)
Storage 512GB Samsung 850 Pro (Boot)|1x 512GB Crucial MX100|2x 3TB Toshiba DT01ACA300
Display(s) Asus PB278Q 27"
Case Corsair 760T (White) {1x140mm NB PK-3, 2x Corsair AF140}
Audio Device(s) Creative SB Z {Speakers: Logitech Z-5500 }
Power Supply Corsair AX760
Mouse Logitech G900 Chaos Spectrum
Software Windows 7 7600 x64
Benchmark Scores ( ͡°( ͡° ͜ʖ( ͡° ͜ʖ ͡°)ʖ ͡°) ͡°)
#16
Any medium speed Yate Loon fans, any 140mm by Noiseblocker or silverstone AP fans though they might be a little noisey at full speed.
Get a fan controller to keep the fans quiet but fast enough to move decent amounts of air. I do this with my ML140 Pro's
13 (0.01/day)
Likes
12
#17
If you have the clearance and the radiator has the holes or mounting clips, you might consider using the now "spare" 120mm on the
other side of your radiator to create a "push/pull" air flow through the radiator. May not be quieter, but might enhance cooling enough
that they can run at lower rpms.
12,719 (2.60/day)
Likes
6,060
Europe\Slovenia
#18
It usually makes things worse because of vortexes and turbulences created in between. Stacking fans only makes sense when there is radiator in between which essentially kills the before mentioned vortexes and turbulences as it guides air between the radiator fins, so one is pushing air inside fin stack and another one is sucking air out, slightly improving performance.
7,505 (3.85/day)
Likes
9,717
Massachusetts
Processor i7 4790
#19
the "pure Wings 2" are 50 of whatever the Polish monetary unit is....thats apparently around $13usd, thats fairly decent
672 (3.43/day)
Likes
342
Poland
Processor i7 5775c
Cooling Noctua D15S
Case Full tower
Mouse G403 wireless
On paper they're euqal to Fractal's GP-14 X2 but cost 10 monetary units /zloty,PLN/ more :laugh:
I'll decide on the exhaust fans when I have darkforce 200mm already installed, but thanks for providing me with many options, having a wider choice is always good.
I'll have to see how loud the darkforce fan is, then it's either the 15.5db silentwings or the cheaper but louder fractal gp14. I think I'm gonna end up with fractals, there's no point in buying 15.5db fans if the front intake is rated for 20db. Still, darkforce 200mm is a very underrated fan as 200/230mm's are generally regarded as weak with their lousy air pressure. It's brand new and the bidding starts at 1PLN /0.28 your American monetary units/, no one else seems interested so I hope I might end up paying next to nothing for it and that would leave more cash for other fans making my choice wider.
7,505 (3.85/day)
Likes
9,717
Massachusetts
Processor i7 4790
#21
thats likely the brand name expense ;) even though in my mind, fractal is a nicer brand than BeQuiet.... i dunno, the Fractal DP's i linked above were 12 or so dollars, so thats something like 40 Polish monetary credits. afaik
btw, the Fractal fans default to white on My Newegg page, but the black ones are also availabler, and cost the same (i like black over white Personally)
672 (3.43/day)
Likes
342
Poland
Processor i7 5775c
Cooling Noctua D15S
Case Full tower
Mouse G403 wireless
7,505 (3.85/day)
Likes
9,717
Massachusetts
Processor i7 4790
#23
12,719 (2.60/day)
Likes
6,060
Europe\Slovenia
#24
People need to realize that dB's mean very little actually. Noise profile however is important. The type of noise output. Low frequencies tend to be less annoying than high. Only problem here is, there is no standard way to measure this and pour it into text form. This is where all the grommets, ribs, bumps, cuts, rubberized surfaces and so forth shape the noise. Only way to really know it is to try it out. There is frankly no other easy way around this.
I think only way would be to create a "standardized" test of a fan frame with switchable restrictions. So you'd mount a fan inside a holding stand and run it at certain speeds without restrictions and with restrictions (normal case mesh, high restriction like HDD cages and heavy restriction like a cooling radiator). Then profile them by ear and maybe using audio spectrometer to map the frequencies. But to do that you'd need an anechoic chamber. Or at least proper studio room to do all this. This way you could test fans under identical conditions.
1,714 (0.91/day)
Likes
1,387
Finland
System Name SER
Processor Intel Core i5-7600K @ 4.7GHz
Motherboard Asus Z170 Pro Gaming
Cooling Alphacool Eisbaer 240 + 4x Corsair ML120
Memory 16GB Corsair Vengeance LPX DDR4-2400 @ 2666MHz
Video Card(s) Asus GeForce GTX 980 Strix @ 1500/2000MHz
Storage 2x 256GB, 2x 250GB, 240GB & 120GB SSD
Display(s) 2x 1920x1080
Case Phanteks Eclipse P400S Windowed
Power Supply Super Flower Golden Green 500W
Mouse Logitech G400s
Keyboard Logitech G410
Software Windows 10 Pro EN
#25
Totally agree. My last three MB's have been Asus, and their fan controls are just great. Though I like more creating my own fan profiles, but like you said, those presets are great in most cases.
