Processor | 5800X3D | 5700G |
Motherboard | ROG Impact | B550I Aorus AX |
Memory | 32GB 3733CL14 | 16GB 4333CL16 |
Video Card(s) | RTX 4070 Ti Eagle | Vega 8 |
Storage | 8TB of SSDs | SN550 |
Case | Caselabs S3 | Lone Industries L5 |
Audio Device(s) | FiiO K7 + DT770 |
Power Supply | Corsair HX1000 | HDPlex 200W |
got it today!
8810B
okay here it is. out of the box. im looking into what i can do now
Now that's what I'm talkin' bout'.got it today!
8810B
I'm running tm5 tests now (anta777 extreme) so far no issues but the DIMM temps were 50c it seems while running the test , i did notice while installing the kit that it was a bit tight between the two rams.Now that's what I'm talkin' bout'.
Crank em up. 3800mhz, psshhh no problem CL16. 1.45v.
Limit Dimm load temp 40-45c.
yea volcano seriously. today it was 116 F...Living inside a volcano, I seehow long did you run TM5 for? DIMM temp should take the better part of an hour to actually reach equilibrium.
45C in TM5 at just 1.38V is still warm. My ambient temp isn't much cooler than yours in the summer. Also not even taking into account the amount of heat the 6900XT will dump on the DIMMs when you fire up a game. You don't have to do anything more than stand up a small 92mm fan on the backplate of your GPU and point it at your RAM. When I was running a loop just that 92mm fan alone dropped DIMM temps by close to 10 degrees.
Though, with only a 120mm top exhaust, and basically no helpful intake fans I was able to get down to about 43C @ 1.43V. How slow are you running your fans?
I’m curious about the “higher you go v-dimm and frequency, the lower they like to run temp wise. Helps keep stability.”You won't need to spend a lot of time beating on this set. They'll probably be fine at 50c, but the higher you go v-dimm and frequency, the lower they like to run temp wise. Helps keep stability.
Nice thing is that this kit will top off your Infinity Fabric. Nothing wrong with experimenting high frequency either. B-Die is not impartial to odd memory timings such as 17-17-17 or 19-19-19 4000mhz and faster while keeping v-dimm reasonable 1.40-1.45v should be of no problem. Even do 4200mhz at CL19's 1.45v all day I'd be willing to bet. Depends on that memory controller.
Processor | AMD R7 1700X @ 4100Mhz |
Motherboard | MSI B450M MORTAR MAX (MS-7B89) |
Cooling | Phanteks PH-TC14PE |
Memory | Crucial Technology 16GB DR (DDR4-3600) - C9BLM:045M:E BL16G36C16U4W.M16FE1 X2 @ CL14 |
Video Card(s) | XFX RX480 GTR 8GB @ 1408Mhz (AMD Auto OC) |
Storage | Samsung SSD 850 EVO 250GB |
Display(s) | Acer KG271 1080p @ 81Hz |
Power Supply | SuperFlower Leadex II 750W 80+ Gold |
Keyboard | Redragon Devarajas RGB |
Software | Microsoft Windows 10 (10.0) Professional 64-bit |
Benchmark Scores | https://valid.x86.fr/mvvj3a |
Well, I'd be aiming for as close to 4000mhz at CL14-14-14-34 and Start at 1.60v and work my way down. My set, single ranked 2 x 8gb is rated 4267mhz CL-19 1.450v. They have much more capability however. CL16's around 1.50v seems pretty good with mine. I could NOT run these at 60c. They'll start producing errors despite seemingly stable with the everyday tasks. (that's where the testing comes in with tweaking)good shit guys!
No boot at either 272 or 266Temps on B-die is something to look out for but some sticks have more tolerants to heat than others.
My sticks have no issues going above 60C. this was with no case. If you have decent airflow in you case then it should not be a problem.
Try
RRDL 4
WTRS 3
WTRL 8
RTP should be 6 not 8. Your aida latency is abit high should be around 54-55ns <---Make this change first and test Aida again before testing above settings
Also try lowering TRFC 272 or 266
Open up Thaiphoon Burner and get a read. I'm curious what PCB these sticks are, something I've never thought about in the last few dozen suggestions or so. With a big please! of course!No boot at either 272 or 266
Yeah, that's a bit too tight.No boot at either 272 or 266
no problemOpen up Thaiphoon Burner and get a read. I'm curious what PCB these sticks are, something I've never thought about in the last few dozen suggestions or so. With a big please! of course!
16-16-16-36 (up to 4000mhz) tRFC in the 400's area. I turned mine out (for Benchmarking not daily) at 444 clocks. Was stable enough to run 3Dmark a bunch of times to produce a decent score. With a 2T command rate (typical for A2 PCB dimms) any ways.
1.38V could be the cause of that I would personally go back to 1.45V. Which is perfectly fine for 24/7 on Samsung B-die.No boot at either 272 or 266
i ran for quite a bit, will run more over the weekend. i forgot to mention i do have 2x 120 on top with the liquid cooler kit., and one 120 under the GPU blowing air up. just loose in the floor . im gonna try that right now ... good freaking tip.
i been having a new motherboard on the back of my head since this build started from a transfer from mini tower and i end up keeping the board..
Right on B1s.Worked on
RRDL 4
WTRS 3
WTRL 8
no problem
F4-3600C16D-32GTZN
8810b
Right on B1s.
I'd be surpassing the idea of daily clocks at suck low frequencies though.... But hey everyone is different.
4200mhz CL-19-19-19-19-39 Enable the memory training (if board is equipped) and leave everything else on auto. 1.45v and Uncouple the Infinity Fabric. command rate 2T. Curious if it would just post right up. Compare your numbers linked lower frequency VS Unlinked higher frequency.
BUT Man!! - You've got B-Die!!!!! You are either going to just set this up and go gaming OR you have weeks of tweaking to do. HAHA!!!
So many people jam B-Die and so many configurations.... just how deep is that rabit hole?
Oh and enable "Gear Down mode" in the timings menu as well. You can do Power Down mode disabled, but they might run warmer from it.
Vote #3 for a fan directly on them sticks. (enables spank dimm mode) View attachment 261119
Going above 2000 is great for bragging rights and if you dont get WHEA 19s or other issues. Since he does have a 2 DIMM mobo it should in theory OC RAM very wellRight on B1s.
Yeah, you're right. My ROG B450-I is a monster.spank dimm mode lol
That's why I'll always have a soft spot for Comet Lake. 4600, 4733, 4800 B-die daily setups...then everyone moved to 1:1 and Gear 1 and we never saw practical OCs again
Once you break 1:1 the bandwidth numbers still go up, but basically it'd be like 4533+ before you can even think about reaching parity in performance again. Sad.
If @noobzin 's 5600X can do 4000 1:1 though at 1.2V VSOC, a 4000CL16 setup could still be worth pursuing. ITX Strix should have no trouble.
You're right really. Even on my 8700K 4000mhz CL16 just seems to be spot on efficiency and performance.Going above 2000 is great for bragging rights and if you dont get WHEA 19s or other issues. Since he does have a 2 DIMM mobo it should in theory OC RAM very well
and 4200 should be attainable.
Perosnally prefer 1:1:1 has performance hit when its uncouple is really bad.
I agree I would also push to see how high the RAM could go. Some of the guys got 4200 1:1:1 to run using 2 DIMM boardsBut what good are bragging rights if there was nothing accomplished??
1.20v SOC may carry the IF (hyper transport link rebrand?) get up to like 3933mhz.... Maybe 1.250v .. 1.30v.. 4000mhz+ ? ?
Ah? No comment on the "rebranded HT" part though? I was curious your thoughts... hoping... something might spark.Chances are it shouldn't need that many volts. King's got a great sample there but 1.2V for 4000 is quite alright for samples that can do it without WHEAs.
Though, problem with these 5000 CPUs remains that the VSOC scaling is all over the map......some barely make it to 3800 at 1.2V...
APUs are a different story. As long as I don't dip below 1.11V at any time, my 5700G does 4333 1:1 all day, all while holding up an OC'd iGPU on its shoulders
That's a sweet ride man. Many are jealous for sure. When I refreshed there was nothing. excuse the original smiley thing.I agree I would also push to see how high the RAM could go. Some of the guys got 4200 1:1:1 to run using 2 DIMM boards
Not recommeding the OP to try these settings. Veii is an expert at this also this was done with 2 X8GB single rank sticks it would be much harder
to get using 16GB dual rank sticks.
