xXcalvin54Xx
- Sep 15, 2022
- 1 (0.00/day)
Hello everyone,
i am new to the world of overclocking and was wondering if it is possible to push my CMH32GX4M2D3600C18 sticks any further even if it is just tightening the timings of XMP if that is even possible?
my rating for xmp is 18-22-22-42 for 3,600myhz at 1.35v
ive been playing around, I have XMP Disabled and set the Frequency to 3,866. (highest i could boot into windows with was 4,300mhz)
I have enabled Round Trip Latency, Disabled Power Down Mode and and set CPU SA and IO to 1.350 (max for now so i can lower later on after finding timings right?)
my DRAM Voltage is set to 1.50 also (Will lower this to) I am able to boot into windows with these settings, used Testmem5 on these ratings and passed.
18-20-20-40 3,866mhz passed on testmem5
17-20-20-39 3,866mhz passed on testmem5
16-20-20-38 3,866mhz passed on testmem5
Is what im doing on the right track? any direction would be most appreciated.
I only use my PC Gaming and sometimes stream also with OBS.
My pc Specs are
MOBO - MSI MAG TOMAHAWK z490
CPU - i9 10850k
PSU - GameMax 1000w gold rated
GPU - RTX 3060 ti oc edition gigabyte
RAM - Corsair Vengeance RGB PRO SL 32gb 3,600mhz 18-22-22-42
COOLER - Corsair h115i Platinum 280mm
Two Corsair LL120 Fans as Exhaust Fans.
AIO Is mounted to top of case
4 Fans at front of case also.
These are benchmarks from Aida64
These are my benchmarks for 16-20-20-38 (lowest i could get them down without BSOD) boots into windows and is passing on TestMem5.
Two Tests was with and with out TRFC and TREFI set.
Once with Auto
then TRFC ive set to 580 (500 or lowest wont boot)
then TRFEI ive set to 65535
Im trying to lower my TRFC now as much as possible and testing on TestMem5 for Errors.
So this is the lowest I can get all my settings with passes on testmem5 and 10 mins stress on aida64.
All passed and works.
Will leave my pc on tonight to do a over night test on memtest aswell.
But does this look right and have I followed the correct way of doing everything? Each time I lowered the volts or timings id boot back to Windows and run testmem5 wait for a pass then benchmark of aida64.
My pc Specs are
CPU - i9 10850k
Once with Auto
17-20-20-39 Passed TestMem5 ( high volts need lowering for stablity).jpg51.5 KB · Views: 412
