[Help] Power-draw figures
171 (1.46/day)
Likes
374
Germany
System Name Athlon Dragon
Processor AMD Threadripper 1950X
Motherboard Modified ASUS ROG-STRIX-X399
Cooling Dual custom-loop watercooling
Memory 32GB (4x8GB)
Video Card(s) RX Vega 64
Storage Samsung 860 EVO
Display(s) 24", 1440p, freesync, 144hz
Case Thermaltake Core X9
Audio Device(s) beyerdynamic MMX 300
Power Supply EVGA Supernova T2 1600W
Mouse OG steelseries Sensei
Keyboard steelseries 6Gv2
Benchmark Scores GPUPI 1B GPU - 13.637s
#1
Aye ye fine lads and lasses!
I got something started when I joined our WCG-team and decided I finally need to know what my monster machine is pulling from the wall and my wallet each week.
So I got myself a power-meter, this one to be precise, and wanted to see what I get at idle, 100% CPU-load and while benchmarking the Vega 64.
Specs of the meter thingy:
Measured range current: 0.01 - 16 A
Measuring accuracy current: +/-1% or +/-0.01 A
Measuring range power: 0.2 - 3600 W
Measuring accuracy power: +/-1% or +/-0.2 W
The numbers I got are high, but I kinda expected this. Then again I looked at what my parts are supposed to draw and that got me thinking.
Idle 243W // CPU 100% load 643W // Running Heaven benchmark 910W.
I know a Threadripper (1950X) build with Vega is power hungry, but what got me thinking is, at 643W CPU-load my Vega was in idle and that would mean the CPU alone gobbles 400W+ total. This is at 1.25V and 3.675GHz. A slight OC and not 4+GHz suicide runs. The Vega is under water but I run it in my CS:GO profile which is stock power limit! I can´t believe a single stock Vega can make a 1000W PSU sweat. Sure someone like @buildzoid might see that, but not with stock power limit?!
I can rule out that the additional power has to do with the cooling system, because the pumps are a seperate plug that is currently in a completly different phase and the fan speeds are fixed by a fan controller and do not change between idle or load. This system has no HDD, no optical drive. Just an M.2 SSD, the mobo, GPU and CPU.
So I got to think my tool of measurement must read bs. Which is why I plugged it with my 1800x system. It features the same voltage and clock (e.g. it is basically half of the TR), aio watercooling. RM850i PSU from Corsair. And the power meter reads exactly the same as the PSUs build-in stuff does. 105W idle power draw and 200W total system draw on 100% CPU load. That is with multiple HDDs, an optical drive and a fan controller with multiple 140mm fans + the two fans from the rad.
After that I now think that either my little monster has a hunger that starts to frighten me (if one day I stop posting pls send help) or that something messes up the figures. Either some build in protection or filter from the PSU or god knows what.
My question would be, to anyone who knows how power meters work: How do these devices work, and what could possibly upset it?
3,256 (4.82/day)
Likes
2,409
System Name Good enough
Processor AMD Ryzen R7 1700X - 4.0 Ghz / 1.350V
Motherboard ASRock B450M Pro4
Cooling Scythe Katana 4 - 3x 120mm case fans
Memory 16GB - Corsair Vengeance LPX
Video Card(s) ASUS GTX 1060 Turbo 6GB ~ 2139 Mhz / 9.4 Gbps
Storage 1x Samsung 850 EVO 250GB , 1x Samsung 860 EVO 500GB
Display(s) 4K TV
Case Zalman R1
Power Supply 500W
#2
16 cores use a lot of power, even at idle. Especially if overclocked. Vega 64 is also very power hungry.
That being said 900W does seem exaggerated.
323 (2.39/day)
Likes
101
System Name Custom Build/M6700/Clevo P870TM1/Dell T3600/Clevo P377SMA
Processor i7 8700K/i7 3920XM/i7 8700k/E5 2658/i7 4930MX
Motherboard Z370 MSI Gaming/M6700/Z370 Clevo/C600 Dell/HM87 Clevo
Cooling EVGA AIO/ Built in heatsinks
Memory 16GB
Video Card(s) 1080 ti/980M/1080 SLI/R9 Fury X/1070 SLI
Storage 500GB SSD RAID0 500GB HDD RAID 0 & 1.5TB HHD/500GB SSD & 1TB HDD/250GB SSD/500GB HDD
Display(s) 1080p 144HZ/1080p 120HZ & 1080P 60HZ & 1200P 75HZ/1440P 120HZ/720p 60HZ/1080P 120hz
Case H500/Laptop/Laptop/OEM Dell/Laptop
Power Supply 750W/240W/330Wx2/500W/330x2
#3
I'd think that 800-850 @ max load would be reasonable, perhaps you have a lot of accessories?
692 (1.06/day)
Likes
245
Processor i7-6700k
Motherboard asus z170i pro gaming
Cooling ekwb custom loop for cpu/gpu running on d5 and 480 rad
Memory 2*16gb ddr4-2400
Video Card(s) msi geforce gtx 1080 ti aero
Storage 250gb 950 pro, 2*500gb samsung 850 evo
Display(s) asus pg279q, eizo ev2736w
Case thermaltake core p5
Power Supply seasonic platinum 660
Mouse logitech g700
Keyboard corsair k60
#4
1950X is specced to 180W at 3.4GHz. On the good old Summit Ridge this is already in a not very nice part of the efficiency curve.
Stock Vega runs at 300W and is pretty well stuck to that.
When measuring from the wall, you also need to account for the PSU efficiency.
Over 100W is very common but 243W idle sounds like an awful lot. What other devices do you have in that machine?
Btw, what does software monitoring report for power figures?
2,411 (0.89/day)
Likes
3,009
Bridgwater, Somerset
System Name Not so complete or overkill
Processor 5960X @ 4.20Ghz @ 1.06v - For Crunching!!
Motherboard MSI X99 Titanium Gaming
Cooling Custom loop with old bits and pieces that I need to replace
Memory G Skill TridentX 3466 non RGB..
Video Card(s) 2 x EVGA GTX 1080 Ti SC Black Edition
Storage Sandisk 120Gb SSD, 2 x 2Tb Sammy 3.5" drives - Need more drives!!
Display(s) 3 x 23" LG IPS panels (can't remember model!!)
Case 10mm thick MDF on plastic risers.. It's kinda a case??
Power Supply EVGA T2 1200w
Mouse Corsair thingy
Keyboard Corsair thingy
Benchmark Scores It's not to bad.. More importantly, it works!!
#5
@Dinnercore I'd run it stock and see what the difference is, if it's already high then you know it's not a problem. If that's not the case, then you can look into what the overclock is doing when you bump up the vcore, I noticed it with the 5960X (a few less cores but...) add some vcore and the wattage did increase at idle and load (I don't use the C1 states etc) I'll see if I can dig out my results for you just to give an example :)
6,602 (4.34/day)
Likes
5,459
Duiven, Netherlands
Processor i7 8700k 4.8Ghz @ 1.31v
Video Card(s) MSI GTX 1080 Gaming X @ 2100/5500
Display(s) Eizo Foris FG2421
Case Fractal Design Define C TG
Power Supply EVGA G2 750w
Mouse Logitech G502 Protheus Spectrum
Keyboard Sharkoon MK80 (Brown)
Software W10 x64
#6
Not sure if these are such incredible numbers. I mean, consider you actually have two 8c/16t Ryzen CPUs in there and the most power hungry consumer GPU on the planet right now, next to the incoming 2080ti that is.
AsRock
TPU addict
15,763 (3.79/day)
Likes
5,090
UK\US
Processor 2500k \ 3770k
Motherboard ASRock Z68 \ Z77
Memory Samsung low profile 1600
Video Card(s) eVga GTX1060 SSC \ XFX R9 390X
Storage Intel 80Gb (SATA2) WD 250Gb \ Team SSD+Samsung Evo 250Gb+500Gb+ 2xCorsair Force+WD250GbHDD
Display(s) Samsung 1080P \ Toshiba HDTV 1080P
Case HTPC400 \ Thermaltake Armor case ( original ), With Zalman fan controller ( wattage usage ).
Audio Device(s) Yamaha RX-A820 \ Yamaha CX-830+Yamaha MX630 Tannoy Mercury MKII Paradigm 5SE + Tannoy Mercury F4
Power Supply PC&Power 750w \ Seasonic 750w MKII
Mouse MS intelimouse \ Logitech G700s + Steelseries Sensei wireless
Keyboard Logitech K120 \ ROCCAT MK Pro ( modded amber leds )
#7
Sorry cannot really help much but by overclocking the CPU maybe disabling the power saving for the CPU\Mobo ?.
Alll so reminds me of a ASUS 775 mobo i had which would run the system at idle 200w were as other mobo's would be down around 90w.
171 (1.46/day)
Likes
374
Germany
Memory 32GB (4x8GB)
#8
I think I need to clear some things up, to point out what I´m wondering about:
Specs you can find under my avatar!
Accessories or other devices, yes there are many fans in my case, controlled by 2 fan controllers. That will explain the high idle, which btw is not what bothers me!
Other then that I have no HDD, only 1 SSD, no USB devices other then a keyboard and mouse. WLAN and any wireless connections are off via bios.
I know my PC can pull those numbers if pushed to the max. but think about that:
Idle power 240W, CPU load 640W! My Vega is in idle at this moment, not consuming any more then before. That is a 400W increase ONLY on the CPU. My PSU is 80+ Titanium with 230V input, so 95-96% efficiency. If I account for that loss, then my CPU would suddenly pull 380W more then it already is at idle. How on earth would this be coolable if true? My temps sit in the 40s!
Software is telling me this about GPU and CPU @ idle:
So if those are somewhat correct, I´m looking after losses at 100W for CPU and GPU, and the other 140W must be my fans and the SSD....
See why I question this?
And for load, I have a screen from a slightly higher Vcore setting:
My meter was showing 700+ W from the wall here.
692 (1.06/day)
Likes
245
Processor i7-6700k
Mouse logitech g700
#9
Idle numbers actually check out well enough. 100W from motherboard is not usual but with the HPDT motherboards is not unheard of.
Load does not make sense though. 240W on the CPU at load that the CPU reports itself sounds about right.
Power delivery losses cannot be that high, can they? :D
63 (0.12/day)
Likes
25
System Name BEst AMD Computer
Processor R5 2600
Motherboard As Rock Tachi X470
Cooling Alphacool Eisbaer 420
Memory Gskill RIpjaws V 3600 MHZ 16 GB (2x8)
Video Card(s) Sapphire Vega 64 Nitro, Gigabyte Vega 64 Gaming OC
Storage 4 x NVME 480 GB
Display(s) Acer 49Qok 4K monitor
Case THermaltake Core X9
Audio Device(s) Corsair Void Pro
Power Supply Corsair HX1200!
Keyboard Logitech G510
Software Windows 10 Pro 64 Steam. GOG, Uplay, Origin
Benchmark Scores Firestrike: 24955 Time Spy: 13500
#10
That definitely sounds high. Especially under water I also have a Vega 64 and I don't ever see the system pull no more than 650W under load As for the Vega card I see power at 223W when gaming. I do have a R5 2600 instead of 1950 but I also have 2 HDD, 2 SSHDs, 2 SSDs, 4 NVME drives and 10 140MM fans and 3 200MM fans in my system. I don't think there is anyway that it should be showing that much power draw do you have your meter set for 110 or 230?
2,597 (1.64/day)
Likes
1,317
SE Michigan
System Name Dumbass
Processor AMD-9370BE @4.6
Motherboard ASUS SABERTOOTH 990FX R2.0 +SB950
Cooling CM Nepton 280L
Memory G.Skill Sniper 16gb DDR3 2400
Video Card(s) GreenTeam 1080 Gaming X 8GB
Storage C:\SSD (240GB), D:\Seagate (2TB), E:\Western Digital (1TB)
Audio Device(s) onboard (realtek?) SPKRS:Logitech Z623 200w 2.1
Power Supply Corsair HX1000i
Mouse Logitech G700s
Keyboard Logitech G910 Orion Spark
Software windows 10
#11
overclocking the 1950 will draw double or even triple the watts, im sure you can search for specifics. the vega cards are easily undervolted while keeping frames with speed increase to offset the undervolt.
3,256 (4.82/day)
Likes
2,409
Display(s) 4K TV
Case Zalman R1
Power Supply 500W
#12
640W for CPU alone is incredibly high, not even the new 2990X eats up that much power, granted this number is for whole system draw + PSU.
171 (1.46/day)
Likes
374
Germany
Memory 32GB (4x8GB)
#13
@Dinnercore I'd run it stock and see what the difference is, [...]
I´ve done that now (see below), since I agree with you all that OC does bring so many variables into this that it´s hard to tell what´s going on. But my sense for basic physics is telling me that something is very wrong. 900W power draw (aka mostly heat loss) will show in temps, be it on the VRM, PSU or CPU/GPU. I can´t isolate the part and that has me worried. I still highly believe the power meter reads out wrong, but in case it does not (since it works fine on my 1800x system!) there is something in my system that has a high power loss and the only thing I can not monitor temp wise is the PSU... If that thing has a failure I would rather like to know it.
I do partly agree, the numbers are not crazy but my Vega is running in stock power limit and with slightly reduced voltage, the CPU is not on 4GHz all core, but far below with plenty of headroom. I have not heard of a 1950x that blows up 1000W PSUs yet. That sounds more like a 7980XE.
I do have effectivly 2 1800x in there, yes. But my 1800x takes 200W full load for the whole system, if I double that up I´m still at only 400W.
I put it to default settings now, see the lower half of this post. And triple the power? Maybe if you let it rip on 1.45V, I´m running 1,21V.
So I went for stock settings on the board and CPU. Just to see what changes:
stock1.JPG stock2.JPG This is my current GPU profile: stock3.JPG stock4.JPG
Now I took 3 measurements. One at idle, nothing running, one at CPU 75% threads on 100% and one with CPU load running + Heaven benchmark.
Results:
Idle 202W // CPU load 591W // max out 1187W
This is on stock bios settings, 180W TDP on the CPU. I can not really believe these load figures. And I can not see that power turning into heat anywhere in my system, only the PSU does get hot quickly, but I have no sensor to test it and my hand sadly does not come with a build-in thermometer.
EDIT: @kapone32 the power meter is for 230 input.
63 (0.12/day)
Likes
25
Processor R5 2600
#14
View attachment 107677 View attachment 107678 This is my current GPU profile: View attachment 107679 View attachment 107680
Results:
View attachment 107681 View attachment 107682 View attachment 107683
What is the wattage of your PSU? Unless you have a 1600W PSU your PC would automatically shutdown at the draw of 1187 W
newtekie1
Semi-Retired Folder
25,547 (5.39/day)
Likes
11,855
Indiana, USA
Processor Intel Core i7 8700K@4.8GHz(Quick and dirty)
Motherboard AsRock Z370 Taichi
Cooling Corsair H110i GTX w/ Noctua NF-A14 Fans
Memory 32GB Corsair DDR4-3000
Video Card(s) ASUS Strix GTX 1080Ti
Storage 500GB Crucial MX500 + 2TB Seagate Solid State Hybrid Drive with 480GB MX200 SSD Cache
Display(s) QNIX QX2710 1440p@120Hz
Case Fractal Design Define S
Power Supply Corsair HX850
He in fact does have a 1600w PSU.
The fact that the PSU is getting hot quickly kind of leads me to believe these numbers are accurate. A 1600w PSU shouldn't be getting hot unless the load is 800w or more.
3,256 (4.82/day)
Likes
2,409
Display(s) 4K TV
Case Zalman R1
Power Supply 500W
#16
1187W at stock ? So it went up ? Yeah something is not right, either the meter is wrong or there is something wrong with the PSU.
cadaveca
My name is Dave
17,062 (3.71/day)
Likes
11,473
#17
Not sure how many 1950X users there are here, but I am one. guess how much mine pulls at idle with a GTX1080? NOT THAT MUCH!!!
At idle, from the wall, I get 81W, with 3 SSDs, and two mechanical, as well as an external mechanical USB drive. I also have a USB-power lamp, my keyboard and mouse, and my headphones and XBONE controller. This is on aircooling, with a Artic Freezer33TR, using two 1.2A fans. Nearly everything is RGB, too. Memory is at 2933 MHz.
running Timespy, max power draw recorded is 351W. This is the highest I can get on stock, since my ASRock X399M Taichi does what it is supposed to do. CPU-only load is actually far less, around 208W.
Since your system specs list a modified ASUS Strix X399 board, I'll say that the board is garbage, and you should get a new one. At stock it should hold that 180W for CPU maximum power draw, and drop clocks as low as needed to maintain that. I can do hard AVX loading, and see my CPU clocks drop to 1600 MHz on all cores as it maintains that 180W figure. I think your board is the culprit here, and somehow it is doubling the power used, which should not be possible at stock settings. It is possible there is something wrong with that PSU as well, but my own 1950X is working exactly as you'd expect. I can OC everything when I put the CPU under water and get higher power use, but nothing near 1000W.
2,597 (1.64/day)
Likes
1,317
SE Michigan
System Name Dumbass
Software windows 10
#18
thats still part of overclocking.
171 (1.46/day)
Likes
374
Germany
Memory 32GB (4x8GB)
#19
I´m thinking about the board being an issue. Still, the VRM sensor never shows more then 35°C (the point I set the fan to turn on). Could be broken, the 'modified' relates to the changes I made on the VRM-Cooling. I replaced the tiny fan with one that can move more air and removed any aesthetic garbage that blocks airflow on the VRM-heatsink and around the DDR modules.
I wrote it like that as a reminder that the standard version of this board is no longer comparable to my temperature figures. I did not yet e-Power it :D
3,256 (4.82/day)
Likes
2,409
Display(s) 4K TV
Case Zalman R1
Power Supply 500W
#20
Unlikely that the VRMs really do run at just 35c.
cadaveca
My name is Dave
17,062 (3.71/day)
Likes
11,473
#21
OK, well thanks for that information as that does help suss out what's going on here. Is there any chance you have a clamp-on current meter, or can access one? That would really help sort this, since you can measure actual VRM power use via that. Then you could pinpoint either the board or PSU being the problem.
Ther can be no doubt that these AMD TR chips can pull a tonne of power, and you can get 500W of power draw quite easily, but that is also not going to happen (well, it is not supposed to) over a single 8-pin connector. Do you have a supplementary 4-pin plug connected to the board's VRM? The 8-pin should not allow for more than ~374 W of power draw, by design. It could be that the system is drawing a lot, but the PSU isn't capable of shutting down parts of itself, leading to the increased draw at idle.
I'm on a 120V power plug here in Canada, but what the systems pulls in this situation should be fairly identical for us, and even then, @ 220V, you should see better efficiency than I do.
6,528 (4.40/day)
Likes
3,880
Sunshine Coast
System Name Black Box
Processor Intel Xeon E5-2680 10c/20t 2.8GHz @ 3.0GHz
Motherboard Asrock X79 Extreme 11
Cooling Coolermaster 240 RGB A.I.O.
Memory G. Skill 16Gb (4x4Gb) 2133Mhz
Video Card(s) Nvidia GTX 710
Storage Sandisk X 400 256Gb
Display(s) AOC 22" Freesync 1m.s. 75Hz
Audio Device(s) No need.
Power Supply FSP Aurum 650W
Software W10 Home Premium 64 bit
#22
Have you got the function set to KW/h?
If It is set to Watts, it is cumulative and adds up the longer you run it.
171 (1.46/day)
Likes
374
Germany
Memory 32GB (4x8GB)
#23
[...] Is there any chance you have a clamp-on current meter, or can access one? [...]
Do you have a supplementary 4-pin plug connected to the board's VRM? [...]
No clamp yet, and I do not know anyone I could lend one from. In the end I might just buy one, if there is something wrong I want to know it.
And yes I do have that additional 4-Pin plugged in.
I get why you think that, but you are wrong in 2 ways. One, this is not the calculated average per hour that builds up! It is the current Watt figure. It drops back to 200 after the load test. And 2nd, if what you think is true, then the accumulation to 1187W after 5 minutes would hint at a power consumption of 14.244 W! My mains fuse would say no to that already around the 3KW mark (each room has a limit of 3KW, only kitchen can pull more).
2,411 (0.89/day)
Likes
3,009
#24
Results:
I'm unsure on the specifics of a 1950X but I do think that the voltage on the VCore is too high.. 1.5?? I would reset everything in the bios and start again.. Backup everything on your drives BEFORE you do this just in case something has a fit, but I'm thinking that's too high for a start.. This is possibly were the CPU is chewing up so many watts :) Give that a go and let us know your results :) I'll see if the guy I know can send me a few pics of his 1950X under CPU load and go from there... :)
171 (1.46/day)
Likes
374
Germany
Memory 32GB (4x8GB)
#25
Nah those numbers are normal for Ryzen CPUs, it´s the voltage they apply for very short bursts to boost up to 4.2GHz. This is why I don´t like running stock, it does stay within 180W TDP, but jumps up and down with clocks and voltages every splitsecond. While 2 or 4 cores are @ 1.5V, the others are much lower and then they switch, this is why HWMonitor records 1.5V on all cores as this was the max. they reached, but not at the same time.
The high voltages are more often applied in idle, when it does not hit the power limit, under load I see ~1.2V on the non boosting cores.
But I would like to hear from you what your friend/colleague/guy said. Every input from other 1950x owners is helpful.
