[Help] Power supply surges detected during the previous power on
17 (0.03/day)
System Name Setup PC Master Race
Processor Intel® Core™ i7-4790 CPU @ 4.00GHz
Motherboard Asus Z87-PRO
Cooling Cooler Master Hyper 212 EVO
Memory 2x8GB Patriot Viper III DDR3 1600Mhz = 16GB
Video Card(s) Asus ROG STRIX RX 480 8GB GAMING
Storage 1: SK Hynix Gold S31 500GB; 2: Barracuda ST2000DM008 2TB 3: WD Blue 500GB
Display(s) ViewSonic VX2263 Series (VSC692F)
Case Iceberg GLACIUS ATX (Black)
Audio Device(s) Realtek ALC662 (5.1 CH HD Audio)
Power Supply EVGA 600BQ 80+ Bronze
Mouse Logitech G602 Wireless Gaming Mouse
Keyboard Standard Keyboard RGB
Software Windows 10 Pro x64 (21H1)
Benchmark Scores https://valid.x86.fr/pm7e9i
Hello guys!
I need help! this morning i woke up and power on the pc but i does not boot normaly like always it just starts pushing and trying to boot over and over. i scare and turned it off via pressing the off button of the psu then i calm down and start again trying to turn on the pc but the problem persit but this time after somes attempts to start it show me a message "power supply surges detected during the previous power on"
I dont kown what happens... yesterday was fine, at night i finish to play and then put the pc in sleep mode and i went to bed i remember i make a mistake and touched the mouse and pc turn on again but when enter in the os in the log screen i just click again to sleep and that was all... was very rude and quick but in the past i do the same and was ok the next time i try to turn it on...
Video #1: what happens when i try to boot
Video #2: when i enter in bios its visible the red font in the voltaje...
Video #3: In bios > monitor > the voltajes are fking mess
Image #1: i try to put the default settings but the problem persis
Image #2: The message
Image #3: I notice the TPU LED its permantly turned on but the switch is in "off" mod
Notes:
> At the begining the two fans under the gpu they were spinning but after somes reboot they stop working
> I try to clear de CMOS but does not work
> the code in the led panel says "A2"
8,644 (1.59/day)
Nebraska, USA
Memory 16GB (2 x 8GB) DDR4 3000 Corsair Vengeance
Case Fractal Design Define R4
Mouse Microsoft Wireless 5000
Software W10 Pro 64-bit
Swap in another known good power supply and see what happens.
106 (0.49/day)
USA
System Name Testing lots of stuff always
Processor i9-10900x / i5-8600k/Ryzen 5 2400g/ FX 6100
Motherboard Evga x299 Dark/ Evga x299 FTW-K / z370 ITX/ x570 Extreme 4/ B350 tomahawk/ a320-M/Gigabyte AM3+
Cooling EK-AIO 240 D-RGB / Noctua NH-D15S /Noctua Low Profile AM4/Shadow Rock 3/Random tower cooler
Memory LPX 4x8 2666 / 2x16 Crucial 3200 Mhz
Video Card(s) NVIDIA GeForce RTX 2080 Super Founders / 5500xt 4gb Pulse /Windforce R9 270x
Storage 500 GB WD SN750/ 1TB WD Blue M.2/ 870 Evo 500 GB/ Kingston 480 GB SSD/ HDDs Everywhere
Display(s) Alienware 34 aw3418dw / ROG Swift pg27q
Case Phanteks 719 / NZXT 210/ DIY case/Open Air test Benches
Power Supply Seasonic Focus Plus Platinum 750w / Evga 600w Gold GD
Mouse Model O/ Logitech G203
Keyboard Frozen Llama Ducky One 2 Mini MX Silvers / Ducky One 2 Mini MX Reds/ Evga Z15 Kalih Bronze
If you do not have another PSU to test with move the system to a different outlet on a different circuit. That way you can eliminate a potential electrical issue. Make sure you have a surge protector too!
17 (0.03/day)
I forgot the current PSU I have its
Ok i will try to find another psu to test it
