HELP, Ryzen 5 3600, MSI b450 tomahawk max memory issue
96 (0.35/day)
Italy
System Name Main rig
Processor Ryzen 5 3600
Motherboard MSI b450 Tomahawk max
Cooling Arctic Freezer 33 eSport One
Memory 16Gb DDR4 3200 Mhz Corsair vengeance lpx
Video Card(s) Gigabyte gtx 1660 Ti OC @2100 core and 7501 memory
Storage 2x 250Gb Samsung 850 Evo, 3TB HDD
Display(s) Asus mx259q
Case Corsair Spec Alpha
Power Supply CoolerMaster G750M
Mouse Razer Deathadder Chroma
Keyboard Gamdias Hermes e2
Software W10 64bit, Manjaro Linux
Hi guys, as title I just updated my rig with a new mobo and cpu and updated the bios to the latest version. My ram is 2 dimms of samsung at 2400 mhz, the other 2 are crucial ballistix at the same speed. In my previous config I pushed all 4 dimms at 3000 mhz, now I they aren't stable even at 2933.
The problem is that when I oc the ram sometimes it boots up and it's ok, then when I shut down and power off again it refuses to boot or even it did not post.
Please help me
29,006 (6.32/day)
Stop mixing ram
1,861 (1.93/day)
System Name Best AMD Computer
Processor AMD TR4 1920X
Motherboard MSI X399 SLI Plus
Cooling Alphacool Eisbaer 420 x2 Noctua NHU-14S TR4
Memory Gskill RIpjaws 4 3000MHZ 48GB
Video Card(s) Sapphire Vega 64 Nitro, Gigabyte Vega 64 Gaming OC
Storage 6 x NVME 480 GB, 2 x SSD 2TB, 5TB HDD, 2 TB HDD, 2x 2TB SSHD
Display(s) Acer 49BQ0k 4K monitor
Case Thermaltake Core X9
Power Supply Corsair HX1200!
Keyboard Logitech G510
Software Windows 10 Pro 64 Steam. GOG, Uplay, Origin
Benchmark Scores Firestrike: 24955 Time Spy: 13500
+ 1 from eidairaman1 every MB manual recommends using the exact same RAM.
96 (0.35/day)
Italy
478 (0.15/day)
System Name Smooth-Operator
Processor AMD Ryzen 7 3800x
Motherboard Asrock x570 Taichi
Cooling AMD Wraith Prism
Memory 2x16GB 3200MHz CL16 DDR4
Video Card(s) Sapphire Radeon RX 580 8GB NITRO+
Storage JBOD: 2+1+1TB 7200RPM HDD
Display(s) Samsung S24E370DL 24" IPS Freesync 75Hz
Case Fractal Design Focus G Window Blue
Audio Device(s) Creative X-Fi Titanium PCIe x1
Power Supply Corsair HX850 80+ Platinum
Mouse Gigabyte Aorus M3
Keyboard Zalman ZM-K300M
Software Windows 10 x64 Enterprise/Ubuntu Budgie amd64
If you already have updated bios to latest version there is not much more you can do. Unfortunately am4 platform is very sensitive to anything related to memory and that's huge downside of that platform. Since i build PCs which is almost 20 years none platform before wasn't that sensitive to memory mismatching and so strict on memory compatibility.
IMO there are only two things you can try with current set of sticks. First is to put them in correct order like for dual channel: one set to A slots and other one to B slots or whatever ram slots are labeled on that board. Second thing, if xmp profiles are not stable try to manually set frequencies, timings and infinity fabric clock.
96 (0.35/day)
Italy
Yeah I resolved temporarily pulling out samsung's dimms. Now with only crucial ballisitx semms really solid.
QUESTION:
I overclocked them to 2800 mhz, stable
Should I buy ohter 2 dimms that are the same or should I go with a new set of ram?
748 (1.49/day)
California
System Name His & Hers
Processor i9 9900k @5ghz/ R9 3900X Stock
Motherboard Asus Maximus XI Code/ X570 Aorus Master
Cooling Corsair h150i Pro Push/Pull. 5x Corsair ML120 + 4x Corsair LL120/ Corsair h115i Platinum
Memory 32 GB 4x8GB 3600mhz Corsair RGB Pro/ 32 GB 3200 CL14 @3800 CL16
Video Card(s) Asus ROG Strix 2080 ti/ Titan XP
Storage lots of SSD.
Display(s) Asus ROG PG278QR / MSI 27 inch VA panel.
Case Corsair 500D SE RGB/ Phanteks Evolv X
Audio Device(s) Arctis Pro + gaming Dac/ Corsair sp 2500/ Logitech Z 625
Power Supply Seasonic Ultra Prime Titanium 850w x2
Mouse Logitech G903 Lightspeed/ Logitech G Pro Hero.
Keyboard Corsair K95 RGB Platinum/ Logitech G Pro
QUESTION:
not when you can get a better performing set like this on your qvl.
or step up to a decent 3600 kit.
you're in Italy so it would all depend on what ram prices run there.
not sure how this converts over there or how your taxes are.
29,006 (6.32/day)
I know it's not a good idea, but what I can do?
Either sell that samsung ram for more of the exact same crucial, or vice versa or get a better motherboard.
748 (1.49/day)
California
29,006 (6.32/day)
