Help w/ HP Pavilion Case
75 (0.04/day)
System Name hp pavilion 690-0020
Processor AMD Ryzen5-2400G (Raven Ridge)
Motherboard Sunflower
Memory 16gb ddr4
Video Card(s) AMD Radeon RX 580
Storage 128 GB PCIe NVMe TLC M.2 Solid State, 1 TB
Power Supply Internal 400 W PSU
is it hard changing cases? as i said im realllly new and so is my family as you can tell lol
4,355 (0.99/day)
St. Paul, MN
System Name Bay2- Lowerbay/ HP 3770/T3500-2+T3500-3+T3500-4/ Opti-Con/Orange/White/Grey
Processor i3 2120's/ i7 3770/ x5670's/ i5 2400/Ryzen 2700/Ryzen 2700/R7 3700x
Motherboard HP UltraSlim's/ HP mid size/ Dell T3500 workstation's/ Dell 390/B450 AorusM/B450 AorusM/B550 AorusM
Cooling All stock coolers/Grey has an H-60
Memory 2GB/ 4GB/ 12 GB 3 chan/ 4GB sammy/T-Force 16GB 3200/XPG 16GB 3000/Ballistic 3600 16GB
Video Card(s) HD2000's/ HD 2000/ 1 MSI GT710,2x MSI R7 240's/ HD4000/ Red Dragon 580/Sapphire 580/Sapphire 580
Storage ?HDD's/ 500 GB-er's/ 500 GB/2.5 Samsung 500GB HDD+WD Black 1TB/ WD Black 500GB M.2/Corsair MP600 M.2
Display(s) 1920x1080/ ViewSonic VX24568 between the rest/1080p TV-Grey
Case HP 8200 UltraSlim's/ HP 8200 mid tower/Dell T3500's/ Dell 390/SilverStone Kublai KL06/NZXT H510 W x2
Audio Device(s) Sonic Master/ onboard's/ Beeper's!
Power Supply 19.5 volt bricks/ Dell PSU/ 525W sumptin/ same/Seasonic 750 80+Gold/EVGA 500 80+/Antec 650 80+Gold
Mouse cheap GigaWire930, CMStorm Havoc + Logitech M510 wireless/iGear usb x2/MX 900 wireless kit 4 Grey
Keyboard Dynex, 2 no name, SYX and a Logitech. All full sized and USB. MX900 kit for Grey
Software Mint 18 Sylvia/ Opti-Con Mint KDE/ T3500's on Kubuntu/HP 3770 is Win 10/Win 10 Pro/Win 10 Pro/Win10
Benchmark Scores World Community Grid is my benchmark!!
I am sure there is a small computer shop somewhere near you that will be happy to swap cases for you, on the cheap. Almost any case, will have more airflow than that HP, maybe even one the shop has and will give to you. Find an independent shop owner and ask nicely.
Google local computer shops, good luck!:toast:
3,984 (1.20/day)
System Name Wut?
Processor 3900X
Motherboard ASRock Taichi X570
Cooling Water
Memory 32GB GSkill CL16 3600mhz
Video Card(s) Vega 56
Storage 2 x AData XPG 8200 Pro 1TB
Display(s) 3440 x 1440
Case Thermaltake Tower 900
Power Supply Seasonic Prime Ultra Platinum
Go buy a soft blow hammer and a couple pieces of 2x4. Put one piece under the case and bang on the top side until it is flat. While your are getting the 2x4' get as fine mesh screen as you can find and glue that to the inside of the panel. Hell, duct tape would work. So would old mail. It's not even that bad.
Also, sign up for shop class if you are still in school. If not, find an adult ed class. :)
hat
Enthusiast
21,731 (3.42/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Okay, so a new case will not work. Check out that motherboard...
I'm immediately noticing:
•Weird part of the motherboard with front panel stuff soldered to it which lines up with holes in the front, in much the same way the back panel is usually done
•No 20+4 pin ATX connector! Instead, there appears to be a funky proprietary 4 pin connector?
•Those mounting holes are all over the place. No hope of putting it in any standard ATX case without some modding.
That motherboard and chassis were a match made in silicon hell...
10,232 (1.70/day)
Austin Texas
Motherboard MSI 690-I PRO
Video Card(s) RTX 4090 FE
Case SLIGER S620
Audio Device(s) Yes
Power Supply Corsair SF750
Mouse Xlite V2
Keyboard RoyalAxe
just get a piece of acryllic from home depot and drill it in... easy.
Mindweaver
Moderato®™
8,194 (1.49/day)
Charleston, SC
System Name Tower of Power / Sechs
Processor i7 14700K / i7 5820k @ 4.5ghz
Motherboard ASUS ROG Strix Z690-A Gaming WiFi D4 / X99S GAMING 7
Cooling CM MasterLiquid ML360 Mirror ARGB Close-Loop AIO / CORSAIR Hydro Series H100i Extreme
Memory CORSAIR Vengeance LPX 32GB (2 x 16GB) DDR4 3600 / G.Skill DDR4 2800 16GB 4x4GB
Video Card(s) ASUS TUF Gaming GeForce RTX 4070 Ti / ASUS TUF Gaming GeForce RTX 3070 V2 OC Edition
Storage 4x Samsung 980 Pro 1TB M.2, 2x Crucial 1TB SSD / Samsung 870 PRO 500GB M.2
Display(s) Samsung 32" Odyssy G5 Gaming 144hz 1440p, ViewSonic 32" 72hz 1440p / 2x ViewSonic 32" 72hz 1440p
Case Phantek "400A" / Phanteks “Enthoo Pro series”
Audio Device(s) Realtek ALC4080 / Azalia Realtek ALC1150
Power Supply Corsair RM Series RM750 / Corsair CXM CX600M
Mouse Glorious Gaming Model D Wireless / Razer DeathAdder Chroma
Keyboard Glorious GMMK with box-white switches / Keychron K6 pro with blue swithes
VR HMD Quest 3 (128gb) + Rift S + HTC Vive + DK1
Software Windows 11 Pro x64 / Windows 10 Pro x64
Benchmark Scores Yes
Hey, those holes aren't bad just put the side back on it. If anything just straighten the case with a hammer and a small piece of wood. Just lay the side on the wood and hit it with a hammer to straighten the holes. Once the holes are flat then just put some big vinyl stickers on the side to cover them. :toast:
887 (0.24/day)
somewhere
Oh jeeze, you sure it was a drill? Not a shotgun? XD But honestly you could probably as Arjai and Mindweaver said, get it back into shape and put it back on. If anything, the holes will add more ventilation~
Not sure about putting in a new case as the motherboard looks built into that chassis, maybe it will work but you probably won't have an I/O Shield..
Edit: saw hat's post. Good point.
40,435 (6.59/day)
I could get that panel back on the case fine.
449 (0.14/day)
System Name Specs Last Update: 8/April/2024
Processor Intel Core i5 9400f 2.9GHz/4.0 Turbo (NoOC)
Motherboard Gigabyte Z370M D3H rev. 1.0
Cooling be quite! Dark Rock Slim 180W TDP (The Silent Wings 3 120mm Fan)
Memory Corsair Red Line 8x2 16GB 3000MHz (NoOC) DDR4-3000 15-17-17-35 (CMK16GX4M2B3000C15R) V1.35 ver 4.24
Video Card(s) NVIDIA GeForce MSI 980 Ti Golden Edition (NoOC)| Spare: GTX 650 Ti 1 GB
Storage Samsung 870 EVO 4 TB | Samsung 860 EVO 1 TB | Cold Backup: WDC Black 930 GiB WD1003FZEX
Display(s) Asus VG248QZ 1920x1080 144hz 24" (Current: 60hz)
Case Corsair Air 540
Power Supply Corsair 850W RMi
Mouse Logitech M187 wireless (First day of use 30-9-2021)
Keyboard Logitech K270 wireless
Software Windows 10 21H2 LTSC 2021 / Linux: Candidates: Bazzite - Linux MX - Tuxedo - Kubuntu
This is a job for..................................................Duck Tape Man!
You can either use Flex Seal or Flex Tape :D
silentbogo
5,473 (1.44/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 3800X
Memory 4x8GB Samsung DDR4 ECC UDIMM
Video Card(s) Inno3D RTX 3070 Ti iChill
Storage ADATA Legend 2TB + ADATA SX8200 Pro 1TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
Software Windows 11, Ubuntu 20.04 LTS
Ha-ha-ha!!! :roll:
You, guys, drilled the shit out of it. Further modding will be futile, so the only thing I can suggest is take some arts and crafts lessons, practice aerography a bit, and stylize the remainder of that case to look like it's been damaged by bullet holes and shrapnel )))
Regarding the actual case:
1) It's HP's in-house design, so no aftermarket parts will be available on the market
2) Someone suggested getting "used" case, but I doubt that will be possible for such a new machine
3) Replacing the case with an aftermarket model is also not an option, since your motherboard has non-standard size, shape, and power connectors.
So, pretty much you have to ignore everything that's been suggested earlier in the thread, with the exception of "use it as is". Nothing bad is gonna happen if you have a few holes in the case.
13,210 (3.81/day)
Sunshine Coast
System Name Black Box
Memory G.Skill 16GB 3600 C18
Audio Device(s) No need.
Power Supply FSP Aurum 650W
Mouse Yes
Keyboard Of course
Software W10 Pro 64 bit
Toothless
Tech, Games, and TPU!
9,269 (2.52/day)
Washington, USA
System Name Veral
Processor 5950x
Motherboard MSI MEG x570 Ace
Memory 4x16GB G.Skill TridentZ
Display(s) Acer Nitro XZ342CK Pbmiiphx + 2x AOC 2425W
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
So after seeing that board..
Just get a new motherboard and case at this point.
75 (0.04/day)
Memory 16gb ddr4
I just need to find something to use as a side panel or just cover up the hole the sticker strat sounds pretty good not gonna lie but i really dont have that kind of money to spend on a motherboard case and power supply, i do appreciate the help
3,984 (1.20/day)
System Name Wut?
Processor 3900X
Cooling Water
Flatten in back out and using previously described methods and sticker it to death.
75 (0.04/day)
Memory 16gb ddr4
sticker death
Mindweaver
Moderato®™
8,194 (1.49/day)
Charleston, SC
sticker death
Nice! Now you have just modded your first case! Well done! Modding is like building pc's once you start you can't stop. :toast:
3,984 (1.20/day)
System Name Wut?
Processor 3900X
Cooling Water
Next time you want to drill some flimsy metal, put a large block of wood under it and drill into the wood. This will help prevent deforming the thin flimsy thing by keeping support underneath it.
4,994 (0.72/day)
South of England
System Name Box of Distraction
Processor Ryzen 7 1800X
Motherboard Crosshair VI Hero
Cooling Custom watercooling
Memory G.Skill TridentZ 2x8GB @ 3466MHz CL14 1T
Video Card(s) EVGA 1080Ti FE. WC'd & TDP limit increased to 360W.
Storage Samsung 960 Evo 500GB & WD Black 2TB storage drive.
Display(s) Asus ROG Swift PG278QR 27" 1440P 165hz Gsync
Case Phanteks Enthoo Pro M
Audio Device(s) Phillips Fidelio X2 headphones / basic Bose speakers
Power Supply EVGA Supernova 750W G3
Keyboard Cherry MX Board 6.0 (mx red switches)
Software Win 10 & Linux Mint
Benchmark Scores https://hwbot.org/user/infrared
Good tip, it's also a good idea to start off with a smaller pilot hole and work up rather than going straight for the large bit. Or those stepped drill bits are ideal for this kind of thing.
3,984 (1.20/day)
System Name Wut?
Processor 3900X
Cooling Water
stepped drill bits
Those are great. The big take away from all this is to:
  • Practice before using spray paint to touch up the Mona Lisa.
  • Mistakes are going to happen
  • Don't panic, there is always a way out.
  • Practice.
  • Practice.
  • Be careful with things that aren't replaceable.
  • Practice.
75 (0.04/day)
Memory 16gb ddr4
So i went to go get some tape and this is what i was able to do
2,097 (0.51/day)
Spencerport NY
System Name Master
Motherboard SR-2 Classified
Video Card(s) EVGA GTX680
Fancy.
PapyrusGamer124
1 (0.00/day)
Hey Dirty Gromp, I doubt you do, but if you still need a new case panel or any other case parts, let me know I've got a whole case and even the motherboard from where I upgraded.
freeagent
7,508 (3.68/day)
Winnipeg, Canada
Processor AMD R9 5900X
Display(s) LG 50UP7100
VR HMD Oculus 3
Software Yes
