Help with bubbles in AIO water cooler
Migzk
12 (0.23/day)
So i got my coolermaster masterliquid 240 lite for almost 2 months and i think i have some bubbles in my pump cause i keep hearing a noise comming from the pump.I already tried some solutions that i found like turning the computer but with no success.I need to know if this can damage my WC and if possible a solution for this that works. Someone can help please?
sneekypeet
Retired Super Moderator
28,678 (5.31/day)
System Name His
Processor Intel i9 7920X
Motherboard Asus Prime X299 Deluxe
Cooling Corsair H115i RGB Platinum
Memory G.Skill TridentZ RGB 32GB @ 3600MHz
Video Card(s) nVidia RTX 2080ti
Storage Samsung 960 Pro / Crucial MX300 750GB / Seagate 1TB Spinner
Display(s) Samsung 55" 4K 60hz
Case Cooler Master Cosmos C700P (Inverted Layout)
Audio Device(s) Realtek on board > Sony Receiver > Cerwin Vega's
Power Supply Thermaltake TPSG 1050W
Mouse Always Changing
Keyboard Always Changing
Software Windows 10 Pro 64
Did you lay the PC flat on the right side of it? That should move air out of just about any orientation of AIO installation.
Second, those are low grade (lite) models where pump noise was more prevalent that a typical AIO. Maybe a video with good audio will help?
Migzk
12 (0.23/day)
yeah i did it and stopped but when i flipped it back the noise returned
sneekypeet
28,678 (5.31/day)
System Name His
It mat not be completely full, and where you have the radiator installed might be causing the air to be able to move.
Could also be the impeller hitting the side of the housing, but that has a different sound to it.
Migzk
12 (0.23/day)
its installed in this way i will send a video
sneekypeet
28,678 (5.31/day)
System Name His
Put the tubes at the bottom of that rad and see if it goes away. With it as you have it, the air is at the top, and gets pushed right through the tubing into the pump.
Migzk
12 (0.23/day)
here is the video
sneekypeet
28,678 (5.31/day)
System Name His
Ya, reverse the radiator orientation. In any loop, the highest point is where air tends to migrate. Right now air is in a bad spot in your AIO.
Migzk
12 (0.23/day)
i will do it i didint installed it but i think i can do it by my own thanks
sneekypeet
28,678 (5.31/day)
System Name His
Should be four screws at the back of the case. Be sure to follow the fan power wire, and either unplug it now, and reroute when the rad gets flipped, or be damn sure there is enough slack in the line first.
Migzk
12 (0.23/day)
do you thinks this air in the pump can damage my WC? i dont know when im going to flip it
sneekypeet
28,678 (5.31/day)
System Name His
Over time, running air through the impeller is bad for the cooler. However, temperature of the CPU will increase to unsafe levels without coolant to transfer heat away from it. I think it is well worth the effort to get the radiator installed to trap air over leaving it like it is.
Feel free to ask any questions you may have. It isn't hard, just ensure the fan wire is free so you don't tear away a fan header or break the wires on accident. Otherwise, if you can turn a Phillips #2 screwdriver and unplug and replug a fan, you are good to go.
Migzk
12 (0.23/day)
okay thanks
10,795 (4.72/day)
Sunshine Coast
System Name Black Box
Processor Intel i5-9600KF
Motherboard NZXT N7 Z370 Black
Cooling Cooler Master 240 RGB AIO / Stock
Memory Thermaltake Toughram 16GB 4400MHz DDR4 or Gigabyte 16GB 3600MHz DDR4 or Adata 8GB 2133Mhz DDR4
Video Card(s) Asus Dual 1060 6GB
Audio Device(s) No need.
Power Supply FSP Aurum 650W
Mouse Yes
Keyboard Of course
Software W10 Pro 64 bit
If you can't invert the Radiator so the hoses are at the bottom, mount it at the top of your case if possible.
Migzk
12 (0.23/day)
do you think like a week can already damage my WC? I looked my temps and they are fine for now.
sneekypeet
28,678 (5.31/day)
System Name His
Hard to say. If when it's on its back and works properly without noise, that is a good sign in my opinion. I would keep an eye on things for a while after solving the air issue. Monitor CPU temperatures and verify the pump is running as it should and it's not losing RPM.
Migzk
12 (0.23/day)
i dont think im going to be able to solve this until the next weekend and now im a bit scared of my WC diyng
sneekypeet
28,678 (5.31/day)
System Name His
Lay the PC on its side if you have room. Won't hurt anything.
sneekypeet
28,678 (5.31/day)
System Name His
I'd say hit up cooler master for an RMA. My only guess is that the impeller bearing is toast.
sneekypeet
28,678 (5.31/day)
System Name His
If it is still grinding, it is not going to get better. Dangerous, not really, but if it fails you might see your CPU take advantage of its built in thermal protection features.
Migzk
12 (0.23/day)
okay thanks i keep an eye in my temps all the time but i will look with more attention
316 (0.77/day)
Loose in space
System Name "The black one in the dining room"
Processor Intel i7 5960X @4.6GHz
Motherboard Asus X99 Deluxe
Cooling Corsair H105 w/4 Silverstone FM121 fans @110cfm ea on the radiator
Memory 64GB G.Skill Ripjaws V DDR4 2600 (8x8)
Video Card(s) XFX R9 Fury X
Storage 960GB MyDigital NVMe. 480GB MyDigital NVMe, 1TB Samsung 860, 4 Western Digital 2TB Black
Display(s) 40" Samsung 8000 series 4K
Case Modded Corsair Carbide 500R
Power Supply Corsair AX1200i
Mouse Logitech Performance MX
Keyboard Logitech K750 Solar, DiNovo Edge
Software Win 10 Enterprise LTSC
Turn the radiator so the hoses are at the bottom and the noise should stop.
