Help with FX-9590 undervolting
1,069 (2.22/day)
Chicago Land
Processor Lidless PGA 2700X
Motherboard Asus B450-I Gaming
Cooling Stock Air
Memory Corsair 3000nhz 13-15-15-15-32-53 2T
Video Card(s) Asus strix GTX 980 OC
Storage SSD
Display(s) 21" - 55"
Case None
Power Supply Antec CP series 850w
Mouse Razar Mamba Tournament Edition
Keyboard Logitech G910
Software W7
Benchmark Scores Max Cpu clock 7685Mhz FX-8300 WPrime 32m 2.886 seconds AMD 2700x
Ohh an FX thread!!! Heck ya!!!
Rule of thumb for ALL FX processors.
Higher temps = use more voltage = leaking more.
Lower temps = use less voltage = leaking less.
That is the only challenge you're having is temps. Lower = better in all cases.
These processors are not voltage limited. You give cooling lots of attention and will be the largest benefit.
Do what it takes, buying top TIM, lapping IHS plate, additional cooling on the water loop (chiller) and sky is the lmits.
sjball6988
3 (0.02/day)
It has taken a few years worth of reading, testing settings, and getting over my ego to find the ideal speed and stability of my rig. But one of the biggest things I have figured out along the way is that, regardless of tested stability of any memory speeds, you should NEVER set your memory above the specified Memory Bandwidth of the CPU unless you want some bottlenecking from your Memory Controller. And all of AMD FX-series CPUs have a Memory Bandwidth of 29.9GB/s, so...
29.9GB/s = 30,617.6MB/s
30,617.6 / 32 = 956.8MHz (DDR)
What this means is that the Max Memory Speed on all AMD FX-series CPUs is DDR3-1913.6, which is why they have a specified Native Memory Speed of 1866MHz. So, even if you have DDR3-2400 or higher memory, and it's supported by your motherboard, always remember to consider the actual bandwidth of the Memory Controller on the CPU--or the Motherboard for older systems. After figuring this out and tweaking my rig, I finally have MUCH smoother performance all-around. Here's my specs and setup...
MY RIG:
ASUS Crosshair V Formula-Z (AMD 990FX; SB950)
AMD FX-9590 Black Edition (Vishera; 8-Core; 220W) @ 4720MHz
AMD Radeon R9 Gamer Series 16GB (2x8GB) PC3-19200/DDR3-2400 @ 1800 [8-10-10-24 1T]
EVGA Geforce GTX 1080 Ti SC2 11GB GDDR5X
Creative Sound Blaster X-FI Titanium Fata1ity Professional 64MB X-RAM
(2) Seagate IronWolf Pro 2TB (128MB Cache; 7200RPM; SATA 6.0Gb/s)
Frequencies:
CPU Bus Frequency: 224MHz (~224.75MHz in OS)
CPU Multiplier: 21x (4720MHz)
CPU/NB Multiplier: 12x (2697MHz)
HTT Multiplier: 12x (2697MHz)
Memory Multiplier: 8x (1798MHz)
Voltages:
CPU Voltage: 1.425v
CPU/NB Voltage: 1.325v
DRAM Voltage: 1.665v
NB HT Voltage: 1.25v
Power:
CPU Load Line Calibration: ULTRA HIGH
CPU Current Capability: DISABLED
CPU Power Phase Control: EXTREME
CPU Power Switching Frequency: MANUAL
VRM Fixed Frequency Mode: 550KHz
CPU Power Duty Control: EXTREME
CPU Power Response Control: ULTRA FAST
CPU Power Thermal Control: 151
CPU/NB Load Line Calibration: REGULAR
CPU/NB Current Capability: 130%
CPU/NB Power Response Control: ULTRA FAST
DRAM Current Capability: 130%
DRAM Power Phase Control: EXTREME
DRAM Power Switching Frequency: 500KHz
I did a little further testing since my previous post and found an even sweeter spot with faster response and smoother gameplay...
MY RIG:
AMD FX-9590 Black Edition (Vishera; 8-Core; 220W) @ 4792MHz
AMD Radeon R9 Gamer Series 16GB (2x8GB) PC3-19200/DDR3-2400 @ 1864 [9-10-10-24 1T]
Frequencies:
CPU Bus Frequency: 199MHz (~199.66MHz in OS)
CPU Multiplier: 24x (4792MHz)
CPU/NB Multiplier: 11x (2196MHz)
HTT Multiplier: 13x (2596MHz)
Memory Multiplier: 9.33x (1864MHz)
Voltages:
CPU Voltage: 1.43125v (1.428-1.456v)
CPU/NB Voltage: 1.20v (1.204-1.25v)
DRAM Voltage: 1.655v (1.647-1.654v)
NB HT Voltage: 1.20v (1.217v)
Power:
30,443 (6.46/day)
MY RIG:
Frequencies:
Voltages:
Power:
My 8350 is 5.0 across all cores 1.467Vcore,
sjball6988
3 (0.02/day)
Nice. What cooling do you use?
My biggest problems are that I'm just using a closed-loop Corsair H105 240mm AIO Liquid Cooling Kit with a couple Delta 120mm FFB1212EH [150CFM] fans that are rigged to be controlled by my motherboard, and that these FX-9590s are unpredictable and notorious for drawing lots of power, thus causing a lot of extra heat, which makes it very difficult to find stable speeds, voltages, and power settings. Hell, it's hard enough to just find a motherboard that will support its power draw of 220W, much less finding stability. I WOULD buy an 8350 to replace it, but then I wouldn't want this $230--price when purchased--CPU to go to waste while I spend another $100 for an 8350; I'd rather just keep saving all that money up to put toward buying a MUCH better Ryzen 7 or Core i7...lol.
30,443 (6.46/day)
I am fortunate to have the chip i do, 5.1 is unstable, could be a limit on board cooling or not enough volts beyond 1.524 or another setting.
This is multiplier clocked only.
Scythe Ashura, yes the 9370 and 9590 are ultra leaky chips, look at Shrimp Brime's message.
1,460 (0.62/day)
Alabama
Processor Ryzen 2700X
Cooling Scythe Big Shuriken 3
Memory C.R.S.
Video Card(s) Radeon VII
Software Win 7
It's good to see the OP continuing to experiment and find ways to get the most from their chip.
I've always used the top Asus boards for mine, the Sabertooth 2.0 and 3.0 along with the Crosshair V and Crosshair V-Z. Those are proven to handle the full wattage draw of a 9xxx series board if anything can reliably.
I see you've been running one as well, personally there isn't anything else I'd run with my 9xxx chips and that's the truth of it.
30,443 (6.46/day)
I still want a R1.0 board to experiment and learn how to do custom bios to try and get core unlocker in 2.0/3.0 boards
1,460 (0.62/day)
Alabama
Memory C.R.S.
Software Win 7
I don't believe it can be done - If not mistaken here there is a special chip/component on the board that allows for unlocking, switched on in the BIOS via the ACC function.
Could be wrong but that's what I've heard about it before.
