Help with high cpu temps. Ryzen 2600x
65 (1.25/day)
Likes
4
Processor Ryzen 5 2600x
Motherboard B450 MSI Carbon AC PRO
Cooling Stock Wraith Spire Cooler
Memory 16gb 3200 cl16
Video Card(s) Sapphire pulse Vega 56
Storage SSD and HDD
Display(s) LG24gm79-B
Case Fractal Meshify C
Power Supply BitFenix Whisper M 650W 80+ Gold
Software Windows10
#1
This days I have been monitoring my temps. Everything was running fine but was just checking it by curiosity and noticed was getting like 98cº max while playing apex and streaming in obs.
Today I crashed playing pubg without streaming. My pc just turn off and was a few minutes without turning on until it got back like after 2 minutes between me turning off and on the ac cabble and the button behind the case.
This was yesterday. the day before I actually saw a max spike of 98.2 after playing for like 2 hours.
I have a Meshify C with 2 default stock fans, I already bought 2 noctua 140mm that will arrive in a few days. I will install in the front panel and transfer the default 120mm to the back top of the case.
B450 MSI Carbon ac pro, Ryzen 2600x and Vega56 Sapphire Pulse. PSU is new, it´s a BitFenix Whisper M 650W 80+ Gold
Today I changed the smart fan bios profile to a more aggressive one in the last stats. It helped a bit but I still get a lot of high temps while the funs are running close to maximum as you can see in the next picture.
My 2600x has an off set voltage of -0.1000v in the bios and has PBO on.
After the fans arrive I will probably know better if the problem is only the airflow or if I have a problem in the cpu cooler which btw is the default one.
Can someone please check my values and see if anything is wrong in terms of voltage etc ?
474 (0.28/day)
Likes
280
Processor ryzen 5 1600 @ 4.05ghz smt off / 4.025ghz smt on
Motherboard asrock b350m pro4 with asrock x370m pro4 bio
Cooling arctic cooler 240mm
Memory Super Talent F3200UA8G x2 (16gbs total) @ 3200mhz cl16-17-17-17-34 1.40v
Video Card(s) PNY XLR gtx1060 3gb
Storage Mushkin Enhanced Triactor 128gb ssd/3TB HDD
Display(s) Lenovo 21.5'' 1920x1080p ips
Case Rosewill CULLINAN
Power Supply corsair 750w
Mouse Best Buy Insignia
Keyboard Best Buy Insignia
Software Win 10 pro
#2
is the cooler mounted securely? was there thermal paste underneath it? you need to check these things first. also make sure to bolt the cooler down all the way, until the bolts stop. also check to make sure the fan is spinning and responding to thermal loads. finally, check the bottom of the cooler with a straight edge to insure its flat.
25,500 (5.96/day)
Likes
8,677
#3
What heatsink are you using.
What are the ambient temperatures this computer is running in?
Do you have the front fan blowing in and the back one blowing out?
Clean all filters and vents out, dust the heatsink too
Please fill out your complete system specs here.
https://www.techpowerup.com/forums/account/specs
65 (1.25/day)
Likes
4
Storage SSD and HDD
Software Windows10
#4
I installed the cooler, there was thermal paste underneath it, I struggled a bit to install it at the time since was my first total build but I think I managed to bolt the cooler down all the way. Can´t really remember now but there is a chance it might be something wrong with my instalation. I remember I had a struggle to install it even in the 4 corners. Maybe because that were was too much thermal paste? Like the cooler already came with that ammount of thermal paste, I just instaled the cpu in the board.
You can see in my second picture the rpm of all my fans. I dont know whats the max of the cpu cooler but it normally shows max 2800 or something. The default case fans are fractal xg2 which are suposely max rpm 1200. The pump as it shows is at 1331 rpm at max load. The "system1" I supose is the exhaust one and it shows only max 986 rpm.
In the bios settings I noticed that the smart fan graph for the system1 it onlly showed voltage and was at default 7v and I turned on the smart fan control and made an aggressive curve to it that goes 12 volts at max rate.
I dont have a straight edge in this house but will try to check it anyway.
My office is like 22 degrees, not hot, not cold.
Front is blowing, top is blowing out
The pc is super clean
Ok I updated my specs
One more thing, I installed a new psu like 2 weeks ago. I turned the fan to blow down since the pc is in a tabble and has little "legs" so I think it can blow enough under the pc. Would it be better blowing inside? Btw my idle temps browing are normally 39 to 42º
Is there a chance that my gpu is kinda sucking most of the air? Because my front intake fan is in middle which is almost all directed to the gpu.
887 (0.46/day)
Likes
886
somewhere
#5
The wraith spire is a pita to install sometimes, I usually take the mobo out of the case and place on a hard surface so the backplate support the board then press the cooler down.
Might be worth remounting the cooler this way. Your pc hit thermal shutdown so is likely cooler isn't mounted correctly.
65 (1.25/day)
Likes
4
Storage SSD and HDD
Software Windows10
#6
It´s weird because I have the pc since September and I dont remember having this temps, got a vega 56 a month ago and a new psu last week. If I remount it I should buy new thermal paste right?
Jeez I hope I dont have to remount everything again xd. Was my first build, it took me 8 hours
25,500 (5.96/day)
Likes
8,677
#7
Doesnt matter, do it right the first time.
Get some Arctic MX 4, remove your heatsink, clean thermal compound off heatsink and cpu.
Apply a half a pea size amount of compound to the center slug of the heatsink, mount heatsink correctly.
Watch video carefully.
474 (0.28/day)
Likes
280
Software Win 10 pro
#8
Remember to twist the heatsink to get it off and not try and pull it straight up. this way you wont pull the processor out of the socket.
25,500 (5.96/day)
Likes
8,677
#9
Especially with stock pad/compound.
5,245 (1.61/day)
Likes
2,440
West Midlands. UK.
System Name Ryzen Reynolds
Processor Ryzen 1600 - 4.0Ghz 1.43v
Cooling Raijintek Leto Pro
Display(s) BenQ G2420HD
Power Supply Corsair VS 550w
Mouse Zalman ZM-M401R
Keyboard Razor Lycosa
#11
Your cooler isn't seated right, clean the thermal paste off, apply a small pea sized amount of new thermal paste to the cpu and make sure you seat it correctly, even on the stock hsf you shouldn't be seeing those kind of temps and you risk damaging the cpu
887 (0.46/day)
Likes
886
somewhere
#12
My other concern would be if the Vega is dumping a lot of heat into the case it would be going straight into the CPU cooler. Open air vega needs quite a lot of negative pressure to get rid of the exhaust heat when its at full throttle (that said, your Pulse 56 is board limited to 180W at stock (I had one) so it won't be dumping the full load of heat). But you could do with at least 2x 120mm fans on exhaust IMO. This wouldn't usually result in a Temp shutdown, though, since the CPU would throttle heavily to keep itself below TJ.But if you're still having heat issues after remounting the cooler try gaming with the side panel off for a bit. See if it helps~
155 (1.30/day)
Likes
120
south wales uk
System Name 1. xtreemchaos VR gaming rig 2. intel teliscope rig
Processor 1.2700x @4.2 2. i7 7700k @5.
Motherboard 1.aorus b450 elite 2. z270 asus prime
Cooling 1.240mm AIO 2. 240mm AIO
Memory 1vengence RBG @2933 32gb 2. hyperx preditor @2933 16gb
Video Card(s) 1.MSI AERO 1080 8gb 2. sapphire nitro+ rx580 8gb @1450
Storage 1.256gb M.2,500gb ssd, 2 3tb HDs 2. 256gb ssd, 2tb
Display(s) 1.LG 50inch UHD , oculus rift VR headset with touch. 2 SONY bravia1080p flat pannel
Case 1. HAF XB evo, "the only case anyone would ever need" 2. loop
Power Supply 1.750 80+gold mod 2. thermaltake 600w rbg
Mouse some cheapo rbg thingy
Keyboard 1. dont have one use on screen 2. some old HP thingy
Software 1. win 10 enterpise 2. win10 pro
Benchmark Scores 1.1950 cb 2. 1106 cb
#13
mate your better of getting a diff cooler, AIO water with 240mm rad will cool it fine, the Stock Wraith Spire Cooler is not upto heavy gaming and streaming. charl.
5,245 (1.61/day)
Likes
2,440
West Midlands. UK.
#14
Yes it is, the problem is like I said its more than likely not seated correctly but they are more than adequate for stock settings even on 2700x
155 (1.30/day)
Likes
120
south wales uk
#15
we will see when he reseats it, i wouldnt run my 2700x when unclocked with it and game and stream and not exspect it to cook or throttle.
5,245 (1.61/day)
Likes
2,440
West Midlands. UK.
#16
There a lot better than any other stock cooler I could run 1.4v 3.9 ghz on my 1600 without it getting anywhere near 98c that's a dangerous temp and suggests the cooler is not mounted correctly as at stock even with the crapest stock hsf it should never get anywhere near those temps. No you should not expect it to cook or even throttle with the stock cooler and no oc otherwise its not for for purpose.
http://www.relaxedtech.com/reviews/amd/wraith-max-and-wraith-spire-cooler/2
155 (1.30/day)
Likes
120
south wales uk
#17
ive never been above 72c with watercooling and thats @4.3 OC, i tryed the Wraith when i first got the CPU and it was well into the 90s running cinnibench at stock, its the turbo really warms it up its like you have a OC applyed.
25,500 (5.96/day)
Likes
8,677
#18
Have you ran ryzen blender before?
155 (1.30/day)
Likes
120
south wales uk
#19
havnt tryed blender or grinder, dont like to punnish my cpus too much :).
25,500 (5.96/day)
Likes
8,677
#20
Reason saying is under that my FX 8350 reaches 75 with my Scythe Ashura cooler at 5.0GHz. So I was trying to make a comparison as Ive never ran cinebench
3,919 (4.88/day)
Likes
3,035
System Name Good enough
Processor AMD Ryzen R7 1700X - 4.0 Ghz / 1.350V
Motherboard ASRock B450M Pro4
Cooling Scythe Katana 4 - 3x 120mm case fans
Memory 16GB - Corsair Vengeance LPX
Video Card(s) OEM Dell GTX 1080
Storage 1x Samsung 850 EVO 250GB , 1x Samsung 860 EVO 500GB
Display(s) 4K Samsung TV
Case Zalman R1
Power Supply 500W
#21
That's crazy overkill, any half decent air cooler will do. The stock cooler is fine for everything at stock clocks.
155 (1.30/day)
Likes
120
south wales uk
#22
the strongist benchmarking program ive used is Cinnebench extreme and aida64 stress test both below 72c with watercooling, i have very good airflow in my hafxb which helps.
Vya Domus
we must be all wasting our money on anything else then eh :), you carnt beat overkill if it dont impact you wallet too much my AIO cost £50 new "im not saying i agree its overkill" i more put it in the just fine department.
25,500 (5.96/day)
Likes
8,677
#23
Vya Domus
I have a XPredator Blue with 4 fans, I learned I dont need 8 fans even to stay cool in that case.
You do see my specs right?
5,245 (1.61/day)
Likes
2,440
West Midlands. UK.
#24
The link I provided reviews the Wraith coolers and none got anywhere close to 90c let alone 98c as the op reported, here's another with a 2700x and 2600x with the 2600x overclocked to 4ghz on all cores and running blender for an hour https://www.techspot.com/review/1635-amd-wraith-coolers-compared/ and also my own personal experience with the Wraith spire. Not to mention countless reviews of the 2700x and Wraith coolers and not one I've read experienced 90c+ at stock settings
155 (1.30/day)
Likes
120
south wales uk
#25
i have now, i have push pull 4 fans on the 120mm rad"same aio as 2700x build" on my FX8350 too, it gets up to 70ish with cinnebench at 4.8 maybe 76ish at 5.0 but has very low idle temps in the 20s
i give in ill agree with you all if it makes you all happy :) and im happy doing so.
