- Jan 30, 2019
- 65 (0.03/day)
Processor | Ryzen 5 2600x |
Motherboard | B450 MSI Carbon AC PRO |
Cooling | Stock Wraith Spire Cooler |
Memory | 16gb 3200 cl16 |
Video Card(s) | Sapphire pulse Vega 56 |
Storage | SSD and HDD |
Display(s) | LG24gm79-B |
Case | Fractal Meshify C |
Power Supply | BitFenix Whisper M 650W 80+ Gold |
Software | Windows10 |
Doesnt matter, do it right the first time.
Get some Arctic MX 4, remove your heatsink, clean thermal compound off heatsink and cpu.
Apply a half a pea size amount of compound to the center slug of the heatsink, mount heatsink correctly.
Watch video carefully.
Is that thermal paste good enough or can I try something else if that´s no available in my countrie?
Remember to twist the heatsink to get it off and not try and pull it straight up. this way you wont pull the processor out of the socket.
I´m not sure I understood what twist means, like you mean rotate to one of the sides before pulling, like clockwork direction per example? Sorry english is not my native language. I understand what twist means but not sure in this particular subject.
My other concern would be if the Vega is dumping a lot of heat into the case it would be going straight into the CPU cooler. Open air vega needs quite a lot of negative pressure to get rid of the exhaust heat when its at full throttle (that said, your Pulse 56 is board limited to 180W at stock (I had one) so it won't be dumping the full load of heat). But you could do with at least 2x 120mm fans on exhaust IMO. This wouldn't usually result in a Temp shutdown, though, since the CPU would throttle heavily to keep itself below TJ.But if you're still having heat issues after remounting the cooler try gaming with the side panel off for a bit. See if it helps~
Ya it kinda makes sense, I have a Sapphire Pulse vega 56 and I think my temps are only this high since I got it. I only have pbo on and i´m getting constant 4249mghz in all cores. The gpu ins undervolted to 1040/1050 mv normally and I dont OC it that much, its like at 1600/1650 depending on what profile I choose.
I guess after I install the new noctua fans I can check better if it´s only a problem of air flow or if it´s the cooler too right? Until then I wont stream and will cheking my temps closely.
Yes I tend to install the 2 140mm noctua redux in front as blowers, and transfer my stock 120mm to the top back as exhaust, guess that will help. DO you think it´s worth to get a new 140mm to exhaust too or the fractal xg2 120mm are good enough?
