help with picking a new dvd burner
2,296 (1.38/day)
North East Ohio, USA
System Name My Super Computer
Processor Intel Core i7 8700K
Motherboard Gigabyte Z370 AORUS Ultra Gaming
Cooling Corsair H55 AIO
Memory 2x8GB Crucial/Micron Ballistix Sport DDR4-2400
Video Card(s) Gigabyte GeForce RTX3060 12GB (https://www.techpowerup.com/gpuz/details/d6y4u)
Storage Samsung 970 EVO 500 GB NVMe SSD (System Drive), Samsung 860 EVO 500 GB SATA SSD (Game Drive)
Display(s) Acer Nitro XV272U (DisplayPort) and HP 2311x (DVI/HDMI)
Case CoolerMaster MasterBox Lite 5 RGB
Audio Device(s) On-Board Sound
Power Supply EVGA Supernova 650 G3 Gold
Mouse Logitech M705
Keyboard Logitech Wave K350
Benchmark Scores https://valid.x86.fr/liwjs3
I still put one in all my own personal builds - which means I have to be careful when buying a case because many now no longer support external drive bays. :(
That said, while I prefer internal drives, a decent external drive is nice if you have multiple computers.
My case has no 5.25 drive bays, so I had to buy an external enclosure for my old DVD burner. All I did was take my old drive, put it in the enclosure, and I was done. Instant external DVD drive.
15,442 (5.14/day)
USA
System Name GPD-Q9
Processor Rockchip RK-3288 1.8ghz quad core
Motherboard GPD Q9_V6_150528
Cooling Passive
Memory 2GB DDR3
Video Card(s) Mali T764
Storage 16GB Samsung NAND
Display(s) IPS 1024x600
Its required to restore UHD disc playback, unlock ripping, and region locks.
Did not know that. Then again, I don't do a lot of movie playing/ripping on my PC. My drive is almost exclusively used for data backups.
8,961 (1.62/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
The laser lense gets dirty over time and just die. If you have a dusty environment (smoker or live in a desert), it dies even faster than normal.
Another reason to make sure your case has removable, washable filters and your fan setup creates a slight positive or overpressure environment. This ensures the vast majority of dirty, outside air is pulled in only through the filters. Plus the slight excess pressure causes just a little filtered air to go out through the optical drive. With under or negative pressure, dusty air is pulled in through every crack and crevice, including through the optical drive.
And that's great - if you don't mind another something sitting on your computer desk. And it is especially great if you will be using that drive on different computers. And of course, sometimes that is your only option, such with a laptop - most of which these days don't support opticals or 5.25 drives.
I'm just saying for me, I always go for decent mid-tower ATX cases. IMO, there's no reason the makers cannot make one 5.25 slot accessible from the front. They all support 5.25 bays internally. But that's just me.
2,753 (0.52/day)
louisiana
Processor Intel Core i7-4790 Haswell Quad-Core 3.6GHz LGA 1150 84W
Motherboard GIGABYTE GA-H87-D3H LGA 1150 Intel H87 HDMI
Cooling CPU - Cooler Master Hyper T4 / Case - cooler master 120mm rear case fan (Air cooling)
Memory 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Video Card(s) GTX1060 6GB
Storage Samsung 512 GB 840 PRO SSD Main Drive and Samsung 512 GB 840 EVO SSD Backup Drive
Display(s) ASUS 23" LED Monitor
Case COOLER MASTER Centurion 5 (silver & black)
Audio Device(s) (onboard audio) Realtek ALC892
Power Supply CORSAIR SU-750TX 750W ATX12V / EPS12V
Software Windows 10 Home Premium 64bit Edition
i took all of your advice to heart and decided to buy this one for $47 (Pioneer 8x Internal Blu Ray combo DVD/CD Burner Writer Drive BDR-L06+SATA Cable)
i understand it may not be the best out there, but then i dont think i need anything super high end
while i was at it i also got a new samsung 870 EVO 1TB SSD drive for $129 to replace my old samsung 512gb 840 PRO SSD drive which i will now use as a portable external drive
15,442 (5.14/day)
USA
System Name GPD-Q9
Cooling Passive
Memory 2GB DDR3
Nice. That's a good drive.
Also nice drive!
32,278 (6.21/day)
I just buy a different case
633 (0.97/day)
Loose in space
System Name "The black one in the dining room"
Processor Intel Xeon E5 2683 V4 16c/32t
Motherboard Asus X99 Deluxe
Cooling Corsair H105 w/4 Silverstone FM121 fans @110cfm ea on the radiator
Memory 64GB G.Skill Ripjaws V DDR4 2600 (8x8)
Video Card(s) XFX R9 Fury X
Storage 960GB MyDigital NVMe. 480GB MyDigital NVMe, 1TB Samsung 860, 4 Western Digital 2TB Black
Display(s) 43" Samsung 8000 series 4K
Case Modded Corsair Carbide 500R
Power Supply Corsair AX1200i
Mouse Logitech Performance MX
Keyboard Logitech K750 Solar, DiNovo Edge
Software Win 10 Enterprise LTSC
As a sidenote I have three Blu-ray burners. All are Lite-On iHBS-212's. I bought two of them new over 10+ years ago and they're still going strong. The third showed up on Ebay two years ago listed as "for parts only". I sent the seller a message asking what was wrong with it. He told me he'd only used it a few times and it burned coasters so he put it back in the box and stashed it away. I didn't ask what burning software he'd used. He then said if I wanted it and thought I may be able to fix it I could have it for $10 including shipping. Of course I jumped on the deal.
It showed up in virtually new condition in the original packaging, I put the latest firmware in it and it's been perfect using Nero and Sound Forge Pro to burn several hundred discs with since I got it. Not a single coaster so far and I've used some questionable media at times in it (like the no-name CD's I got off the local Craigslist for $20 for 400 blanks in spindles of 100).
One trick I've discovered for older optical drives that have doors that don't want to open unless you push the button several times is to leave a disc in them at all times. My experience has been they'll open every time with one push of the button as long as there's a disc in them. No idea why that happens but it's worked for me for years.
15,442 (5.14/day)
USA
System Name GPD-Q9
Cooling Passive
Memory 2GB DDR3
SCORE! Nice find.
I usually open them up and re-grease the gears. The factory grease gets dried out and sticky sometimes depending on the brand and model.
8,961 (1.62/day)
Nebraska, USA
Mouse Logitech M190
The factory grease get dry and sticky sometimes depending on the brand and model.
I've seen this often when case fans are not setup properly to provide a slight over or positive pressure. Positive pressure pushes excess "clean" air out through the optical drive's front panel - that's a good thing. Negative (too much exhausting out than being pulled in) causes "dirty" air to get pulled in through the optical drive's front panel (and every USB and other ports) - not good. That dust/dirt then gums up the lubricants - not to mention can obscure the optical lens.
Just about every optical drive has a manual release mechanism. If you look carefully, you should see a tiny hole in the front of the drive. There is no standard location for this hole, so look all over. You typically see these mentioned for stuck trays. But for trays that sometimes don't open (as described above) I have found by inserting a straightened paperclip and pushing it all the way in - not just until the tray pops open, but insert it as far as you can. This will help work loose a gummed up mechanism. Do this a few times, like working a stiff shoulder joint. No promises, but some times it works.
