How do I flash SSD's?
AllHopeIsGone1
121 (0.02/day)
Processor Q9550 @ 4.02GHz
Motherboard ASUS Rampage Formula X48
Cooling Custom water on CPU
Memory 4GB OCZ Platinum 1066
Video Card(s) 2 ASUS 4890 in CrossfireX
Storage 1 Maxtor 500GB 7200rpm, 2 OCZ Vertex 120GB SSD's
Display(s) Samsung 22" T220
Case SilverStone TJ07
Audio Device(s) X-Fi Xtreme Gamer Fatal1ty Pro
Power Supply Thermaltake Toughpower 1200w modular
Also, do I have to flash mine in a NON RAID 0 configuration?
You don't need to flash a SSD. Format it and install whatever on it.
System specs would be nice cause then we could direct to the manufacturers site which would more than likely have instructions for ya...or you can google your drives and how to flash them.
I'm sorry, I meant firmware. I want to know how to install firmware on them.
You need to go to the manufacturer's website for instructions.
One of the steps, it says this:
1. Boot your computer with your old Hard Disk Drive (HDD)
How can I boot my PC with the HDD when no OS is on it. I got my OS on my 2 SSD's. You need to have an OS installed it says to complete the firmware update.
Did you start this thread just to vent?
When you flash a SSD, it erases all the data on them. It's like reformatting a hard drive.
You need to be in Windows to flash. And Windows can't be on the SSDs. If the OS is currently on the SSDs, you need another system to flash from. Do you have a backup system that you could connect the SSDs to?
And what SSDs do you have?
