brandonwh64
- Sep 6, 2009
- 19,542 (3.67/day)
as useful as that thread is, the choice of font in the images was terrible.
I was thinking the same thing
System Name | Rainbow Sparkles (Power efficient, <350W gaming load) |
Processor | Ryzen R7 5800x3D (Undervolted, 4.45GHz all core) |
Motherboard | Asus x570-F (BIOS Modded) |
Cooling | Alphacool Apex UV - Alphacool Eisblock XPX Aurora + EK Quantum ARGB 3090 w/ active backplate |
Memory | 2x32GB DDR4 3600 Corsair Vengeance RGB @3866 C18-22-22-22-42 TRFC704 (1.4V Hynix MJR - SoC 1.15V) |
Video Card(s) | Galax RTX 3090 SG 24GB: Underclocked to 1700Mhz 0.750v (375W down to 250W)) |
Storage | 2TB WD SN850 NVME + 1TB Sasmsung 970 Pro NVME + 1TB Intel 6000P NVME USB 3.2 |
Display(s) | Phillips 32 32M1N5800A (4k144), LG 32" (4K60) | Gigabyte G32QC (2k165) | Phillips 328m6fjrmb (2K144) |
Case | Fractal Design R6 |
Audio Device(s) | Logitech G560 | Corsair Void pro RGB |Blue Yeti mic |
Power Supply | Fractal Ion+ 2 860W (Platinum) (This thing is God-tier. Silent and TINY) |
Mouse | Logitech G Pro wireless + Steelseries Prisma XL |
Keyboard | Razer Huntsman TE ( Sexy white keycaps) |
VR HMD | Oculus Rift S + Quest 2 |
Software | Windows 11 pro x64 (Yes, it's genuinely a good OS) OpenRGB - ditch the branded bloatware! |
Benchmark Scores | Nyooom. |
System Name | PC |
Processor | AMD Ryzen 3600 |
Motherboard | MSI B450 Mortar Max |
Cooling | Phanteks PH-TC12DX, 3 x NZXT FN 140mm, 1x NZXT FV V2 120mm |
Memory | 32gb DDR4 3200mhz |
Video Card(s) | ASUS R9 290 DCII-OC 4GB |
Storage | corsair mp600 1TB |
Display(s) | LG 27MB85Z 27" 1440p |
Case | NZXT Source 340 |
Power Supply | Thermaltake 675w |
Mouse | Logitech G500S |
Keyboard | Logitech G510S |
Software | Windows 8.1 64 bit |
I just use Noctua fans and that eliminates 99.9% of bearing noise
System Name | Codename: Icarus Mk.VI |
Processor | Intel 8600k@Stock -- pending tuning |
Motherboard | Asus ROG Strixx Z370-F |
Cooling | CPU: BeQuiet! Dark Rock Pro 4 {1xCorsair ML120 Pro|5xML140 Pro} |
Memory | 32GB XPG Gammix D10 {2x16GB} |
Video Card(s) | ASUS Dual Radeon™ RX 6700 XT OC Edition |
Storage | Samsung 970 Evo 512GB SSD (Boot)|WD SN770 (Gaming)|2x 3TB Toshiba DT01ACA300|2x 2TB Crucial BX500 |
Display(s) | LG GP850-B |
Case | Corsair 760T (White) |
Audio Device(s) | Yamaha RX-V573|Speakers: JBL Control One|Auna 300-CN|Wharfedale Diamond SW150 |
Power Supply | Corsair AX760 |
Mouse | Logitech G900 |
Keyboard | Duckyshine Dead LED(s) III |
Software | Windows 10 Pro |
Benchmark Scores | (ノಠ益ಠ)ノ彡┻━┻ |
System Name | Darth Obsidious |
Processor | Intel i5 2500K |
Motherboard | ASUS P8Z68-V/Gen3 |
Cooling | Cooler Master Hyper 212+ in Push Pull |
Memory | 2X4GB Corsair Vengeance DDR3 1600 |
Video Card(s) | ASUS R9 270x TOP |
Storage | 128GB Samsung 830 SSD, 1TB WD Black, 2TB WD Green |
Display(s) | LG IPS234V-PN |
Case | Corsair Obsidian 650D |
Audio Device(s) | Infrasonic Quartet |
Power Supply | Corsair HX650w |
Software | Windows 7 64bit and Windows XP Home |
Benchmark Scores | 2cm mark on bench with a razor blade. |
You oil the blades? Keep them clean to prevent dirt from sticking. 3in1 works well but I use automotive 20w50 synthetic motor oil on my fan bearings. If you use an air compressor to blow off the dust, hold the blades still. Don't let them spin up or you risk blowing the fan's drive circuit. Since the motors are PM-BLDC based, they generate a voltage when spun. I've killed them before doing so and also blew out the LEDs. -doh-
$.02
5-56 actually contains moisture, it's not good for long term protection. We've got TONS of rusted out tools down at the yard from people using 5-56. I strongly recommend you use 6-66 instead.
Processor | Intel i7 970 // Intel i7 2600K |
Motherboard | Asus Rampage III Formula // Asus P8P67 Deluxe |
Cooling | Zalman CNPS9900MaxB // Zalman CNPS11X |
Memory | GSkill 2133 12GB // Corsair V 2400 32GB |
Video Card(s) | ASUS GTX1080 // MSI GTX1070 |
Storage | Samsung 860EVO // Samsung840P |
Display(s) | HP w2207h |
Case | CoolerMaster Stacker 830se // Lian Li PC-9F |
Audio Device(s) | onboard |
Power Supply | Seasonic X 850w Gold // EVGA 850w G2 |
Mouse | Logitech G502SE HERO, G9 |
Keyboard | Dell |
Software | W10 Pro 22H2 |
System Name | micropage7 |
Processor | Intel Xeon X3470 |
Motherboard | Gigabyte Technology Co. Ltd. P55A-UD3R (Socket 1156) |
Cooling | Enermax ETS-T40F |
Memory | Samsung 8.00GB Dual-Channel DDR3 |
Video Card(s) | NVIDIA Quadro FX 1800 |
Storage | V-GEN03AS18EU120GB, Seagate 2 x 1TB and Seagate 4TB |
Display(s) | Samsung 21 inch LCD Wide Screen |
Case | Icute Super 18 |
Audio Device(s) | Auzentech X-Fi Forte |
Power Supply | Silverstone 600 Watt |
Mouse | Logitech G502 |
Keyboard | Sades Excalibur + Taihao keycaps |
Software | Win 7 64-bit |
Benchmark Scores | Classified |
I've had great success using soap and water. Just hold the fan so the housing that is covering the motor windings is down over the windings, acts like a cover. Then shake and let dry for a few days... hot car works well..not in direct sunlight. I try not to get the circut board very wet but when I do I just give the whole unit extra drying time. (Have never had a failure)
Have also used vaccum and hogs hair detailing brush. (most used method for entire pc) Brush and hold vaccum just off surface to collect dust.
Compressed air sometimes for PSUs that I don't want to open. In conjunction with vaccum.
Have never used harsh chemical cleaners.
In rare case, for lube I use: Quantum Hot Sauce Reel Oil.
Processor | i7 2600k@4.6ghz |
Motherboard | MSI z68ma-ed55 |
Cooling | Silentx Extreem 120mm |
Memory | 2x4gb XMS 7-8-7-20 1600 |
Video Card(s) | HD6870 |
Storage | 2x128gb Kingston Hyper-X (Raid0), 2x750gb RE3 (RAID1), 2x750gb RE3 (RAID1) |
Display(s) | Soyo 24", Gateway 22" |
Case | Fractal Design Arc Mini 6x120mm fans. |
Audio Device(s) | Onboard |
Power Supply | Zalman 750w |
Software | Windows 7 |
i never use soap, i just use chamois to wipe the dust and paint brush to clean it
System Name | Monke | Work Thinkpad| Old Monke |
Processor | Ryzen 5600X | Ryzen 5500U | FX8320 |
Motherboard | ASRock B550 Extreme4 | ? | Asrock 990FX Extreme 4 |
Cooling | 240mm Rad | Not needed | hyper 212 EVO |
Memory | 2x16GB DDR4 3600 Corsair RGB | 16 GB DDR4 3600 | 16GB DDR3 1600 |
Video Card(s) | Sapphire Pulse RX6700XT 12GB | Vega 8 | Sapphire Pulse RX580 8GB |
Storage | Samsung 980 nvme (Primary) | some samsung SSD |
Display(s) | Dell 2723DS | Some 14" 1080p 98%sRGB IPS | Dell 2240L |
Case | Ant Esports Tempered case | Thinkpad | Antec |
Audio Device(s) | Logitech Z333 | Jabra corpo stuff |
Power Supply | Corsair RM750e | not needed | Corsair GS 600 |
Mouse | Logitech G400 | nipple |
Keyboard | Logitech G213 | stock kb is awesome | Logitech K230 |
VR HMD | ;_; |
Software | Windows 10 Professional x3 |
Benchmark Scores | There are no marks on my bench |
3 words. check my signature.
VR HMD | ;_; |
yes, i saw, and that explains the increment in my thnaks.
sorry, i dont have a camera! its a VGA camera! what do you expect! the most i can do now is add some more pics made in autoCAD,
or someone from here can take he pictures i did, with guidance, so that i can put it in that thread?
any volunteers? it will took me 15mins to make the whole thread, wont take 5mins to take the pictures!
never mind i saw streeghtfighter posted some pics there already! i will make do with that.
VR HMD | ;_; |
System Name | The ClusterF**k |
Processor | 980X @ 4Ghz |
Motherboard | Gigabyte GA-EX58-UD5 BIOS F12 |
Cooling | MCR-320, DDC-1 pump w/Bitspower res top (1/2" fittings), Koolance CPU-360 |
Memory | 3x2GB Mushkin Redlines 1600Mhz 6-8-6-24 1T |
Video Card(s) | Evga GTX 580 |
Storage | Corsair Neutron GTX 240GB, 2xSeagate 320GB RAID0; 2xSeagate 3TB; 2xSamsung 2TB; Samsung 1.5TB |
Display(s) | HP LP2475w 24" 1920x1200 IPS |
Case | Technofront Bench Station |
Audio Device(s) | Auzentech X-Fi Forte into Onkyo SR606 and Polk TSi200's + RM6750 |
Power Supply | ENERMAX Galaxy EVO EGX1250EWT 1250W |
Software | Win7 Ultimate N x64, OSX 10.8.4 |
Carefull with a vacuum inside a PC. I never recomend it. They can make mad static. Been there, done that, bought new ram. In a pinch just use a hose and put a pen on the end to make a blow gun and start blowin'. Just don't spit on everything.
System Name | el'lappy|Cruncher | Cruncher 2 |
Processor | intel C2D T6400 | i7 3770k @4.2ghz | AII X2 220 @3.4ghz |
Motherboard | some Acer | Asus P8Z77-V Pro |Gigabyter GA-M61p-S3 |
Cooling | dual 80mm cooling fan | WC'ing ) |cheapo |
Memory | 2x2gb ddr3 | 2x2gb Ripjaws 1600 |4x512mb D9s |
Video Card(s) | onboard | 60 1GB(hd7770 ) |8800GTS |
Storage | Momuntus xt 320gb |Kingston Hyper X 120gb SATA III|500gb WD |
Display(s) | 17in | 42" 1080P HD 3D TV |
Case | lappy case | CM HAF XB |none yet |
Audio Device(s) | onboard | onboard | onboard |
Power Supply | Dell brick w/ acer end end | Antec EW 650w |Antec SP 350w(upg.soon) |
Software | Windows 7 Ult. 64bit---->-------> |
me too, i dont have at alli dont have a camera! its a VGA camera!
VR HMD | ;_; |
yeah the worst thing is it aint belong to youmines worse. its my moms camera
Did you actually read my post? lol.
System Name | MASTER |
Processor | Core i7 3930k run at 4.4ghz |
Motherboard | Asus Rampage IV extreme |
Cooling | Corsair H100i |
Memory | 4x4G kingston hyperx beast 2400mhz |
Video Card(s) | 2X EVGA GTX680 |
Storage | 2X Crusial M4 256g raid0, 1TbWD g, 2x500 WD B |
Display(s) | Samsung 27' 1080P LED 3D monitior 2ms |
Case | CoolerMaster Chosmos II |
Audio Device(s) | Creative sound blaster X-FI Titanum champion,Creative speakers 7.1 T7900 |
Power Supply | Corsair 1200i, Logitch G500 Mouse, headset Corsair vengeance 1500 |
Software | Win7 64bit Ultimate |
Benchmark Scores | 3d mark 2011: testing |
VR HMD | ;_; |
i've never oiled a single fan in my computers, nor needed to - i tested it years ago on a rattly fan and it stopped the noise problems, but it just kept needing it done more and more and more... its not worth the effort.
System Name | Sovereign // HTPC |
Processor | i7 3770k 4.2 // i7 3770k 4.2 |
Motherboard | Maximus V Gene // Sabertooth Z77 |
Cooling | Noctua D14 // Intel HSF |
Memory | 16GB Samsung // 16GB VengeanceLP |
Video Card(s) | Deciding // 660 DC2 |
Storage | OS (X25-M), Data (Seagate 1TB) // Samsung 840 120GB & bunch of drives |
Display(s) | Samsung T240HD // LG TV |
Case | TJ08e // Grandia GD08 |
Audio Device(s) | DT880 Pro 250 ohm // TV speakers |
Power Supply | Seasonic Plat 1000 // Seasonic Gold 760 |
Software | Windows 8 Pro x64 // Windows 7 Pro x64 |
