How does a receiver's volume setting correlate with the output?
Discussion in 'Audio, Video & Home Theater' started by twilyth, Dec 11, 2011.
  1. twilyth Guest
    Both of my receivers display output (volume) in db. My RX-V765 has 95W into 7 channels. If the display says my output is -10db, how many watts is is it putting out? Does the display mean anything at all? Thanks.
    10 Year Member at TPU
  2. qubit
    qubit Overclocked quantum bit
    Dec 6, 2007
    14,281 (4.05/day)
    7,970
    Quantum Well UK
    It all depends on how it's calibrated and the strength of the input signal.
  3. twilyth Guest
    Regarding the strength of the inputs, let's say they are all digital, which in my case they are.
  4. 1freedude
    1freedude
    Nov 16, 2007
    557 (0.16/day)
    118
    I'm gonna guess that is it is simply a logrithmic scale to indicate knob position.
    Does the knob have stops at -infinity db and 0db?
  5. twilyth Guest
    I don't know abouty -∞ but it does go at least to -50db and +10db. Never tried to push it farther in either direction.
  6. 1freedude
    1freedude
    Nov 16, 2007
    557 (0.16/day)
    118
    What I mean is....does the knob just spin and spin and spin?
  7. qubit
    Dec 6, 2007
    14,281 (4.05/day)
    7,970
    Quantum Well UK
    No, when I said the "strength" of the signal, I meant the amplitude of the analog sound's waveform. The fact it's transmitted digitally isn't relevant. :toast:
  8. twilyth Guest
    I don't understand. Since it's digital, the amplitude would have to be encoded. AFAIK, you can only attenuate that from line level.
  9. 1freedude
    1freedude
    Nov 16, 2007
    557 (0.16/day)
    118
    Think pwm
  10. twilyth Guest
    I don't think they use pulse width modulation for audio. Do they?
  11. 1freedude
    1freedude
    Nov 16, 2007
    557 (0.16/day)
    118
  12. twilyth Guest
    I'll try again later. It's saying I can't load the page. {shrug}
    edit: server not found.
  13. 1freedude
    1freedude
    Nov 16, 2007
    557 (0.16/day)
    118
    It says pwm is used to digitally encode analog
  14. BumbleBee
    BumbleBee
    Mar 6, 2009
    5,814 (1.90/day)
    2,792
    Cybertron aka Canada
    there is no way to tell. if you plug in a kill-a-watt meter the readings are going to be all over the place.
  15. Jetster
    Jetster
    Jan 17, 2010
    9,506 (3.46/day)
    6,013
    Oregon
    My Yamaha XR V571 show output in a way that I do not understand at all
  16. Bundy
    Bundy
    Oct 27, 2007
    1,132 (0.32/day)
    160
    I don't know a lot about this but AFAIK, 0dB is the reference volume. If everything is set correctly, and when playing the reference pink noise, your amp will be at maximum wattage and the speakers will be pumping the reference volume (e.g. Dolby is 105dB) when the volume is at 0dB.
    As this is almightly loud, most systems use -20dB as the reference point for calibrating speakers.
  17. de.das.dude
    de.das.dude Pro Indian Modder
    Jun 13, 2010
    8,137 (3.13/day)
    2,324
    Pune
    amplifiers. you cant explain that.
    i think a sound engineer will be able to tell you the real answer.
  18. qubit
    Dec 6, 2007
    14,281 (4.05/day)
    7,970
    Quantum Well UK
    I think this really calls for a diagram, but unfortunately, I don't have one, lol.
    Ok, let's put it another way. If the singer sings softly into the microphone, the volume level is quieter than if they shout - there's a huge difference, in fact. The output of the amplifier follows this, therefore the wattage being put out at any instant varies dynamically with the input signal - and that variation can be huge.
    EDIT: the difference in amplitude between the input signal and the output signal is called the gain of the amplifier. Adjusting that volume knob alters this gain. Therefore, the actual output level - watts put out - with the volume knob at any particular point depends on the input signal and the volume knob.
    As you can see, the above explanation doesn't say anything about how the signal is transmitted to the amplifier. Regardless of whether it's done in the analog domain or the digital domain, the result is the same. In the digital domain, the bigger the numbers, the higher the volume.
  19. Frederik S Staff
    Mar 30, 2006
    1,252 (0.30/day)
    471
    It is the attenuation level which the amplifier applies. It is not the dB of the speakers.
    -0 dB means that the amplifier is at full gain. It is related to how many watts it is putting out, but in order to compute that you need to know the speaker load, which is variable across the frequency spectrum. Your amplifier will at - 0 dB be able to output 95W RMS into a 8 Ohm load.
    A digital-in will be converted by the DAC in the amplifier Usually the DAC will output something that is very close to a normal line-level signal which is then routed to the gain stages in the amplifier.
    theJesus says thanks.
  20. twilyth Guest
    Thanks man. that's exactly the assumption I had been going on but I didn't have anything to base it on. Much appreciated. :toast:
  21. BurgKaW97521 New Member
    Dec 10, 2011
    1 (0.00/day)
    0
    Thanks men for all your tips
  22. AsRock
    AsRock TPU addict
    Jun 23, 2007
    15,056 (4.08/day)
    4,551
    US
    Same here i turn the crap off lol.
  23. CJCerny
    CJCerny
    Nov 25, 2008
    922 (0.29/day)
    282
    Akron, OH
    There's no way to tell how many watts are being output by the receiver based on the db display. The watts output is different at -10db based on the impedance of the speakers you have connected to the receiver.
