• We've upgraded our forums. Please post any issues/requests in this thread.
How to set fan speed rpm to 60% on automatic
Status
Not open for further replies.
hunter_-
10 (0.06/day)
Likes
0
#1
Cheers to all.Please help me with a suggestion.I have a big problem with my video card.I have an gtx 980ti reference card.Well, all is fine in idle my video card have interval between 24-31 degree,but when I launch a game like Wolfenstein II-The new colossus my video card go on 83 degree and is very dangerous.I launch tweak GPU-Z and my video card goes to 83 dgree because Fan Speed RPM on automatic is going to only 45% equivalent with 78-83 degree.If I set manually fan speed rpm to 60% with MSI afterburner ALL is FINE and temp drop to 62 degree.My dilemma is: WTF,why not going on automatic fan speed to 60 percent when a game launches??Why is going only to 45% fan speed rpm?Is there any way to set in NVidia driver or registry windows to going at 60% fan speed rpm when I launch game?I don t want to use always msi afterburner to set fan speed rpm is not fair.In my opinion video card must be cooled when playing game.The noise is not a problem for me,i want goes on automatic to 60% under load.
is not fair...video card in my opinion must be coled suitable with no program like msi afterburner.Video card in my opinion must be coled with more rpm on automatic under load
a video card must not depend on a program like msi afterburner.I don t understand NVidia its like a conspiracy
p.s my video card is clean,no dust and i replaced thermal compound with MX-2
588 (0.28/day)
Likes
381
Romania
System Name No name
Processor i5 8600k@4800Mhz 1.2v
Motherboard Gigabyte Z370 UD3P
Cooling Prolimatech Super Mega + Coolink 120mm
Memory 16GB 3000Mhz
Video Card(s) Evga 980Ti SC + Accelero Xtreme III
Storage Kingston AV400 256GB, WD30PURX
Display(s) Asus MG279Q
Case CM HAF 922
Audio Device(s) Asus Xonar DS
Power Supply Seasonic G650 650W
Mouse Roccat Savu
Keyboard Asus Strix MX Brown
Benchmark Scores 5948 3dmark TimeSpy
#2
Custom fan curve from MSI Afterburner.
hunter_-
10 (0.06/day)
Likes
0
#3
uite un romans ma :)
stiu ca si engleza mea e jalnica dar poate ma intelegi in romaneste.man nu este corect frate sa mearga asa de calda placa aia in load.De ce trebuie sa mearga in 83 grade cand ar fi mult mai simplu ca din driverul NVidia sa-si mareasca nr. de rpm sa ajunga la 60%.Si de ce trebuie o placa video sa depinda de un p[rogram 3rd gen msi afterburner?Nu-mi vine sa cred cat de cretini sunt astia de la NVidia.repet dc trebuie sa mearga in 83 de grade cu doar 2000 rpm echivalent la 45%,cand poate f. bine sa-si mareasca automat rotatiile la 60% adica undeva la 2800-3000 rpm si sa stea mult mai racorita la 62 grade in load.Mai cu seama ca la 100% fanul Acela atinge undeva la 4700-4800 rpm.Si dupa parerea mea frate o placa video cand intra in sarcina trebuie sa stea cat mai racorita mai ales daca faci o sesiune de 2-3 ore incontinuu.Nu poti sa ai pretentii de acustica ,de liniste,normal ca trebuie sa fie mai zgomotoasa sa fie cat mai rece.Liniste trebuie sa ai doar in idle ,cand vezi un film sau navighezi pe internet.Si dupa ce ca e o placa video reference si are racirea mult mai slaba ca cele custom sau water,isi "mai permite si luxul" sa stea incinsa in 83 grade in loc sa -si mareasca automat nr de rotatii rpm in LOAD.Sa mor io daca ii inteleg pe astia de la NVidia
Daca nu-mi vine sa turbez frateee.sa mor io daca le inteleg logica
Uite man le-am scris pe forumu official si nu ma baga nimeni in seama ma,zici ca as intreba de oase de dinozaur.Stiu si eu ca nu le mai pasa de versiunile mai vechi dar e totusi seria 900,daca ar fi vorba de serie mai veche gen 600 sau 700 as mai zice.si nici asa nu ar fi corect
https://forums.geforce.com/default/...-fan-speed-rpm-to-60-on-automatic-under-load/
588 (0.28/day)
Likes
381
Romania
System Name No name
Memory 16GB 3000Mhz
Case CM HAF 922
Mouse Roccat Savu
#4
MSI Afterburner > settings > fan > vezi poza (see picture).
Pe a mea am pus un Accelero Xtreme III rare ori cand vede 65ºC full load vara :) de auzit nu o aud niciodata.
Foloseste functia aia sa-ti setezi 100% pentru cand trece de 60º placa si un 30-40% pentru sub 60ºC.
La 83ºC isi reduce boost ca sa pastreze temperatura constanta, data viitoare ia o placa fara racire stock, AMD sunt si mai calde de atat.
^ I told him to use the custom fan curve to set the board to go to 100% when above 60 degrees Celsius and 40% for when it is below that. And to not get a reference design card next time and that AMD reference design cards are just as hot.
10,025 (3.47/day)
Likes
6,629
Oregon
System Name Delta // Alpha-HTPC
Processor Intel i7 6700K // Intel i5 4570
Motherboard GIGABYTE Z270X-Gaming K7 // Gigabyte H97M -D3H
Cooling Corsair H80i V2 // Silverstone NT-06 Pro
Memory Corsair DDR4 3000 32gb //G.SKILL Ripjaws X Series 8GB 1600
Video Card(s) EVGA GTX980ti// EVGA GTX 1050ti
Storage Samsung 950 Pro 512, 2 Tb FireCuda// Samsung 850 Pro, 1 X 4 Tb HGST, 1 x 6Tb Toshiba
Display(s) ASUS PB278Q 27" 1440X 2560 // 50" Samsung Plasma 720p
Case Corsair Obsidian Series 550D // Silverstone Granada GD05
Audio Device(s) ASUS Xonar DGX // HDMI to Yamaha RX V571
Power Supply Corsair TX850M // SeaSonic G Series 550w
Keyboard Corsair K70
Software Windows 10 64bit // Windows 7 64bit with Kodi
#5
He said he didn't want to use Afterburner
Just improve the case air flow I think the max is 92c
Tatty_One
Super Moderator
19,744 (4.54/day)
Likes
6,003
Worcestershire, UK
Processor Skylake Core i7 6700k @ 4.6gig
Motherboard MSI Z170A Tomahawk
Cooling Cooler Master Seidon 240V AIO/Viper140's
Memory 16GB Corsair Vengeance LPX 3000mhz CL14
Video Card(s) Sapphire 4gb R9 290X VaporX @1150mhz
Storage SkHynix SL308 120GB/CrucialM4/1TB WD Black
Display(s) LG 29inch 2560x1080 Curved Ultrawide IPS
Audio Device(s) Xifi Elite Pro 7.1/VideoLogic ZXR550's
Power Supply XFX Pro Black Edition 750W Gold modular
Keyboard CM Storm Octane Combo
Software Win 10 Home x64
#6
EVGA Precision Tool? Does the NVidia software not have the ability to set custom profiles? Not owned the green for around 8 years.
hunter_-
10 (0.06/day)
Likes
0
#7
deci din cauza bostului se incinge si mai tare,fir-ar sa fie.Si tot nu intleg dc isi ia boost pana la 1215mhz cand default este 1000 si maxim este 1076 pe gpu-z
For another people to understand our language: why this reference 980ti card have boost to 1215mhz?is weird because on gpu-z default clock is 1000 and with boost is max 1076mhz.Under load my card goes to 1215mhz,Is hotter because boost of 1215?:(
edit: my dream is to NVidia release a new driver to increase rpm to 60% under load automatically,but is only dream for me :(
My concern to have 60% rpm under load because I want to prolong video card life.....that's why I want less degree under load.And for me 60% fan speed rpm is not noisy under load.Over 65% become noisy
19,188 (5.03/day)
Likes
4,795
#8
Make sure you do not have a cable obstructing fan rotation.
Use AB for fan curves.
Replace crap thermal compound on gpu die, pads on ram/vrm too...
hunter_-
10 (0.06/day)
Likes
0
#9
if now on winter weather have 83c,at summer what can I do??I forgot to mentioned,my unit is set outside on balcony where ambient temperature is 15-16 degree now.thats why im worried,and my case is thermaltake VA9000 bws big tower with one 200mm on side,one 120mm back,and 2x120mm front.I think I have all condition like north pole and my card seems doesn t care about ambient temperature,only in idle is stay at 19-24c(perfect temperature).......that's why im sad and confuse
Before of this card I have many strong video card,and no one goes 70 degree in full load in the same case,ambient bla bla bla....
this card is insane it rises 60 degree over idle temp under load....im very confuse,i don t understand nothing..
http://www.thermaltake.co.nz/product/Chassis/fulltower/kandalf/va9000bws.html
infrared
4,237 (0.93/day)
Likes
1,842
Southampton, UK
System Name Raisin
Processor Ryzen 7 1800X (binned silicon lottery chip, good for 4.2GHz)
Motherboard Asus Crosshair VI Hero - bios 1401
Cooling 240mm rad with corsair ML fans, EK D5 pump/res, XSPC raystorm pro, lapped.
Memory G.Skill TridentZ DDR4-4266 16GB @ 3466MHz CL14
Video Card(s) EVGA 1080Ti FE - waterblock pending.
Storage Samsung 960 Evo 500GB + Corsair 120GB ssd (linux)
Display(s) Asus ROG Swift PG278QR 165hz 1440P
Case Lian Li test bench (can't decide on a case!)
Power Supply EVGA Supernova 750W G3
Keyboard Cherry MX Board 6.0
Software Win 10 & Linux Mint 18.1
#10
The card is designed to run at that temperature, and is actually targeting that temperature and is adjust gpu clock speed and fan speed to hold it there, and it's allowing it to go to 83c to keep the card as quiet as possible. If it starts getting warmer it will raise the fan speed and lower the clock speed to try to maintain the temperature. So you can see that there's nothing dangerous about leaving the card to do it's thing, this isn't 'too hot'. Do some research on GPU Boost 2.0 and you'll see what I'm on about.
A custom fan curve in msi afterburner is the way to do what you want.
P4-630
The Way It's Meant to be Played
9,173 (2.10/day)
Likes
8,933
Vinewood
System Name Sansaya / Sansaya Laptop
Processor Intel i5 6500 / Intel i3 7100U
Motherboard Asus Z170 Pro Gaming / HP 83A3 (U3E1)
Cooling Cooler Master Hyper 212 Evo + Thermal Grizzly Kryonaut + Scythe 1200rpm + 4 case fans / Fan
Memory 16GB DDR4 Corsair Vengeance LPX 3000MHz CL15 / 6GB DDR4 Samsung 2400MHz CL15
Video Card(s) MSI GTX1070 Gaming X 8GB / Intel HD620
Storage Samsung 850 Pro 512GB + Hitachi 2.5" 7200rpm 750GB / Samsung 256GB M.2 SSD
Display(s) 23.8" Dell S2417DG 165Hz G-Sync 1440p + 21.5" LG 22MP67VQ IPS 60Hz 1080p / 14" 1080p IPS Glossy
Audio Device(s) SupremeFX Onboard / Realtek onboard + B&O speaker system
Power Supply Be quiet! Straight Power 10 500 Watt CM / Powerbrick
Mouse Logitech MX Anywhere 2 Laser wireless / Logitech Nano Laser wireless
Software Windows 8.1 x64 / Windows 10
Benchmark Scores Superposition 14106 (1080p medium) Fire Strike 21169 graphics score. Valley 8xAA 4218
#11
^^This.
Just install After Burner and you should have full control of your GPU fan.
/thread
hunter_-
10 (0.06/day)
Likes
0
#12
A custom fan curve in msi afterburner is the way to do what you want. I
who want silent acustic don t buy this reference card,buy custom card like G1,MSI or watercoled.This reference card must be properly cooled with more rpm under load.It just my opinion and I am right im sure.Nvidia policy is not fair!!!I think is a conspiracy to run so hot to damage the card and forced to buy new series....
P4-630
9,173 (2.10/day)
Likes
8,933
Vinewood
#13
10,025 (3.47/day)
Likes
6,629
Oregon
#14
I wouldn't have messed with the thermal material ether. Sometimes it can void the warranty
12,347 (2.56/day)
Likes
5,808
Europe\Slovenia
System Name Dark Silence 2
Processor Intel Core i7 5820K @ 4.5 GHz (1.15V)
Motherboard MSI X99A Gaming 7
Cooling Cooler Master Nepton 120XL
Memory 32 GB DDR4 Kingston HyperX Fury 2400 MHz @ 2666 MHz 15-15-15-32 1T (1.25V)
Video Card(s) AORUS GeForce GTX 1080Ti 11GB (1950/11000 OC Mode)
Storage Samsung 850 Pro 2TB SSD (3D V-NAND)
Display(s) ASUS VG248QE 144Hz 1ms (DisplayPort)
Case Corsair Carbide 330R Titanium
Audio Device(s) Creative Sound BlasterX AE-5 + Altec Lansing MX5021 (HiFi capacitors and OPAMP upgrade)
Power Supply BeQuiet! Dark Power Pro 11 750W
Keyboard Cherry Stream XT Black
Software Windows 10 Pro 64-bit (Fall Creators Update)
#15
83°C for a reference blower cooler is nothing unusual. R9 290X had a thermal limit of 95°C iirc. Some are still grinding even today no problem.
hunter_-
10 (0.06/day)
Likes
0
#16
the card is not functioning at the correct clockspeed even.Under load with boost goes to 1215mhz,and official site and gpu-z show 1076 MHz with boost.Maybe that's why become so hot under load?How can I decrease to have maximum 1076 with boost???Is there any way?
infrared
4,237 (0.93/day)
Likes
1,842
Southampton, UK
System Name Raisin
#17
It is designed to do this, called GPU Boost 2.0 as I said earlier. It'll self-overclock beyond it's stated boost clocks. This is 100% normal.
hunter_-
10 (0.06/day)
Likes
0
#18
yes but im wonder 1215 MHz for a reference card is not way too much?From 1076 boost to 1215 for a reference card is too much I think,thats way becoming so hot?I don t want overclock at this reference card,i want to be cooled.Why goes so much when 1076 is maximum admitted for this card?
I HATE NVIDIA!!!!!
infrared
4,237 (0.93/day)
Likes
1,842
Southampton, UK
System Name Raisin
#19
1076 isn't the 'maximum admitted for this card'... 1076mhz is the minimum boost nvidia can advertise to the customer. In good conditions it will exceed that by a large margin, just as you're seeing. Seriously, absolutely nothing is wrong with your graphics card.
You have the answer to making it run cooler, afterburner - custom fan curve - done. If you don't want to do that then just enjoy the card as it is. Those are your options.
https://www.geforce.com/hardware/technology/gpu-boost/technology
12,347 (2.56/day)
Likes
5,808
Europe\Slovenia
#20
You need to look at actual reported clocks on teh graphs in the Sensors tab and not the numbers on first tab which are just base clocks.
5,605 (1.30/day)
Likes
1,283
New York
System Name http://www.heatware.com/eval.php?id=73751
Processor i7-920 CO@4.2GHZ / ASUS GL553VW 15.6" Gaming Laptop NVIDIA GTX 960M 4GB Intel Core i56300HQ 8GB DDR4
Motherboard Asus P6T Deluxe Intel X58
Cooling Asetek Liquid CPU Cooling System
Memory CORSAIR DOMINATOR 6GB (3 x 2GB) DDR3 1600
Video Card(s) 2X ATI Radeon HD 4870 X2 2GB DDR5 PCI-Express
Storage (RAID-0) with 4 Identical Hard Drives (1.28TB (320GBx4)
Display(s) LG 50" 50PK550 1080p 600Hz Plasma/37 Inch WestingHouse @1920x1080
Case Thermaltake M9 (I hate it its like trying to live in a 1 inch box)
Power Supply ThermalTake ToughPower 1200 Watt
Software Windows 7 professional 64
#21
When ever I game I always set my Fans to 100% and I could care a less about the noise!! I would rather have below normal temps while gaming than the opposite! I use ROG Gaming Center to set my fan speed. I have always since the day I began gaming set my cards fan to 100% and I have never ever had a fan failure as a result of running them at 100%!!! Now having said that maybe it is time to re-paste the GPU? I have also had more than a few cards that needed re-pasting and worked awesome as a result of re-pasting! Good luck and welcome to TPU!!!
infrared
4,237 (0.93/day)
Likes
1,842
Southampton, UK
System Name Raisin
#22
This was just a troll, the same was copy pasted to a few sites. This thread will be closed soon.
Felt suspect from the start! :rolleyes:
5,605 (1.30/day)
Likes
1,283
New York
#23
Yeah maybe but then again he joined back in June so.....
19,188 (5.03/day)
Likes
4,795
#24
I would just let my card do its job, never had an issue with temperarures, only time anyone should worry is if they get lockups or bsods.
@hunter_- you best to listen to what @infrared has to say, otherwise you will start to not receive help from the users here. They have told you the card is doing its job, if you are so worried, send the card back or use afterburner to get custom fan curves set.
Status
