Garth Fitzgerald
- Apr 16, 2025
- 2 (0.18/day)
I just built my system using an HX1200i-2024 to power an MSI Z790 Carbon Max WiFi II motherboard with an Intel i7 12700KF processor.
When I power on with a USB-C cable connecting the PSU and a motherboard USB header, the light on the power supply blinks green and then quickly turns a steady red.
a) If I remove all the connections from the motherboard except the 24 pin power cable, the CPU and the USB-C cable the light still turns red.
b) If I unplug the USB-C cable from the power supply, the light does not turn on.
c) If I unplug the 24 pin power cable from the motherboard, a PSU tester shows all voltages are correct and a voltmeter confirms this for all 24 pins.
I) What does this behavior show about the PSU and the motherboard?
II) What further diagnostics should I perform?
Thanks,
Garth Fitzgerald
Thanks,
Garth Fitzgerald
