I have a problem with the tiny pins on the mobo (hd audio, led, etc)
126 (12.60/day)
Virginia
System Name monkymachine
Processor i5-3570k or i5-2600k, haven't decided
Motherboard MSI B75A-IE35
Cooling Air
Memory DDR3 1333mhz 8 x 2
Video Card(s) Rx 580 Red Devil 8GB
Storage 500GB SSD
Display(s) Generic Monitor at 1280 x 1024
Case Rosewill - Black, Hot-Dipped Galvanized Steel ATX Mid Tower Computer Case with 500W Power Supply - R
Power Supply 500w Rosewill (See case for further info)
Mouse Generic Dell Mouse (Yes, I know I'm lacking)
Keyboard Generic Keyboard
Software Windows 10 Professional
Benchmark Scores N/A
I am upgrading cases, my previous case had them, but all of them were connected and it looked like the 24 pin thing, but now with my new case each of them are separate and I have no idea where to put them!
5,658 (1.70/day)
West Midlands. UK.
System Name Ryzen Reynolds
Cooling Raijintek Leto Pro
Power Supply Corsair VS 550w
Mouse Zalman ZM-M401R
Keyboard Razor Lycosa
Without sounding harsh, read the notherboard manual, it's all in there and the pins are all marked as well.
126 (12.60/day)
Virginia
Cooling Air
Storage 500GB SSD
I had a prebuilt and am making it into a gaming system. Could I search the mobo manual online?
5,658 (1.70/day)
West Midlands. UK.
You sure can, I'm sure you'll be able to find a PDF manual for the motherboard if you look closely on the motherboard you'll see where the main bank of pins for power(pwr) reset(rst) hdd activity LED (hdd) all correspond to the wires on your case, what was the prebuild make and model? Hopefully it wasn't an HP or Dell or something uses a proprietry motherboard size because you won't fit it into a regular ATX case and it won't all be marked as I have mentioned....
126 (12.60/day)
Virginia
Cooling Air
Storage 500GB SSD
I know it's a dell precision t1600, I upgraded the cpu though.
It originally had an xeon e3-1225
5,658 (1.70/day)
West Midlands. UK.
You might have jumped the gun if you have already bought the case, I'm not sure you'll a: be able to transfer it into a regular ATX spec case and b: use a standard ATX spec PSU as Dell's tend to be proprietry and don't have your regular 24 pin + 4/8/4+4 pin CPU connectors.
42,895 (9.14/day)
Processor i7 8700K
Motherboard Asus Maximus Hero X WiFi
Cooling Water
Memory 32GB G.Skill 3200Mhz CL14
Video Card(s) GTX 1080
Storage SSD's
Display(s) Nixeus EDG27
Case Thermaltake Core X5
Audio Device(s) SoundBlaster Zx
Power Supply Corsair H1000i
Mouse Finalmouse Pro
Keyboard Razer BlackWidow Tournament Ed.
Often there will be very small print on the motherboard saying what pin is what. Try to take a good pic of the area with your phone. You can then zoom in a maybe read them. The new case should have them all labeled.
**Unless it's using a normal retail motherboard you are better off ditching upgrading the prebuilt idea.
5,658 (1.70/day)
West Midlands. UK.
Trouble is from his previous threads I think he has already bought a rosewill case/PSU and a red devil RX 580 :oops:
http://d3d71ba2asa5oz.cloudfront.net/43000231/images/dt1600we31225_5.jpg picture of the motherboard to my untrained eye looks like a mixture of ATX width and mATX depth though I'm fairly certain the hole mounts will not be ATX spec knowing Dell prebuilds..
I would see what wattage your PSU is, if it can handle your 580, leave it as is and be content, lesson learned, otherwise you might be able to find a higher wattage Dell PSU on ebay that will, but I don't think you'll be able to transfer this into another case and ATX PSU
120 (0.05/day)
Los Angeles
Processor i7 3770k
Motherboard Asus ROG MVE
Cooling h80 Corsair Hydro Series
Memory 32gb DDR3 Corsair Dominator Platinum
Video Card(s) 2x xfx R9 290x (crossfire)
Storage 2x Patriot Pyro SE 240GB SSDs
Display(s) Acer H5370BD 3D Projector
Case NZXT H2 Classic Silent
Power Supply 1050W CM Silent Pro Hybrid
You are absolutely correct on the motherboard hole mounts because this is a Dell proprietary one.
Another issue will be the required extra power lead for the RX 580 not to mention that it either comes with a 265-watt PSU or a 320-watt model which may not handle the new GPU.
The only saving feature is that it uses a regular size PSU which can actually be upgraded.
As for the pins, it also uses a proprietary connector, but the new case can actually accommodate for that because they come as stand-alone.
126 (12.60/day)
Virginia
Cooling Air
Storage 500GB SSD
What's a cheap LGA 1155 motherboard that supports my cpu (listed in my specs)
5,151 (1.04/day)
USA
System Name Small ATX Desktop
Processor Intel i5 8600K @ 4.6 GHz Core & 4.3 GHz Cache @ 1.168V
Motherboard Asrock Z370 Taichi
Cooling Phanteks PH-TC14PE, MonoPlus, Fans: 2xThermalright TY143 / 2xCorsair SP-120L / 2xYate Loon D14BH-12
Memory G-Skill TridentZ 2X8GB DDR4 3200 CL14 F4-3200C14D-16GTZ @ 3200 14-14-14-34 2T @ 1.35V
Video Card(s) Zotac 1060 6GB Mini ZT-P10600A-10L with Arctic MonoPlus and Yate Loon D14BH-12 Fan
Storage OS Samsung 970 Pro 512GB NVMe, Games Phison E12 NVMe 1TB, Data WD10EZEX HDD 1TB
Display(s) 2x Asus PB258Q 2560x1440 25" IPS
Case Lian Li PC A05NB (Inverted Mobo)
Audio Device(s) Audiotechnica ATH M50X, Antlion Mod Mic 4, SYBA SD-CM-UAUD, Acoustic Research 2Ch Speakers
Power Supply Seasonic SS-660XP2 660 Watt Platinum
Mouse Zowie EC2A Mouse, Razer Naga Chroma '14, Corsair MM600, Inateck 900x300 XL pad, Tiger Gaming Skates.
Keyboard Filco Majestouch II Ninja TKL, Goldtouch GTC 0033 Ten Key, PS3 Controller
Software Win7 Pro 64 (Installed on Coffee Lake using AsRock's handy PS/2 Simulator in Bios)
could try shorting the pins with a small screw driver with the unit shut down,but plugged in and powered, until you find the two pin combo that powers the system on and then after its on, short the pins until you find the two pin combo that resets.
5,658 (1.70/day)
West Midlands. UK.
You can buy a new ATX PSU according to the comment above yours by @hckngrtfakt and keep your case, motherboad, CPU and new rx 580 without having to buy anything else, I'd recommend going this route instead of spending even more money than you have to on a dead platform.
126 (12.60/day)
Virginia
Cooling Air
Storage 500GB SSD
Should I at least try to move the mobo to the new case?
I have decided on my PSU, I'll be getting an evga white 500w
5,658 (1.70/day)
West Midlands. UK.
Measure the mounting holes, you dont need to take it all apart and try and transfer it just to find out it wont work.
That will do you fine, no need to buy another case/ motherboard etc
126 (12.60/day)
Virginia
Cooling Air
Storage 500GB SSD
I'm fine with buying another mobo, but I am 12, I've never experienced a PC game yet. I know where all my plugs go in, on my current set up. I just want to see what For Honor and Fortnite is like, tbh. (I've played fortnite on mobile and on my brother's ps4). I don't care about max settings, just 60fps consistently. I
My prebuilt: old pc I had
My cpu: i5-3570k - $60
My gpu: Rx 580 8gb = $100 + $20 shipping
My case: $70
Spent about 270 and the dell precision t1600 retails for like 100-170 online.
$370 pc
lol, I forgot ram, ram was $70
ddr3 pc3-10600 smtn like that 16gb
My pc is worth 440, but cost me like $300
5,658 (1.70/day)
West Midlands. UK.
Send the case back for refund buy your PSU, sell the old Xeon CPU and that's about the best for the buck you will get with that setup until you're ready to upgrade again down the line (as in when you're not happy with the performance and it doesnt offer up decent 60fps performance anymore, but you should be set for a good while yet with those specs) in which case you will know not to go for another pre build and maybe be in a position to build it yourself from scratch :toast: plus you'll have gained the most valuable thing, knowledge :clap:
126 (12.60/day)
Virginia
Cooling Air
Storage 500GB SSD
I tried refunding the case, $40 shipping I am in VA, new egg is in CA. I'd only get $14 after taxes and stuff. I'll sell my cpu, thanks for the knowledge.
The case is actually decent, but I don't know whether I should keep it. It cost me $70
5,658 (1.70/day)
West Midlands. UK.
you could keep it then buy another motherboard but you're getting to the point where you could have nearly built a new Ryzen 1600/16GB/580 for the same cost you have upgraded the prebuilt, ie: not worth throwing more money into an older lower performing DDR3 platform than you have to, you should have posted first about your proposed plans and we could have saved you some time and money.
126 (12.60/day)
Virginia
Cooling Air
Storage 500GB SSD
This is my mobo https://www.ebay.com/itm/Dell-OptiPlex-990-Motherboard-System-Board-6D7TR-E93839-KA0121-/382120560295
I think... I don't have a dell optiplex 990, but it has the same kind of looking mobo. Would this work>>>>>>>>>>>
5,658 (1.70/day)
West Midlands. UK.
it will likely be the same Dell proprietry layout so no it wont go into an ATX case, it's still a dell, if you're insistent on transferring the parts into a non-Dell ATX case like you have bought you will need a lga1155 motherboard either z68 or z77 that is not from Dell,HP or anyother prebuilt. So any MSI, Asus, Asrock, Gigabyte Biostar etc. But again you're spending more money and time when in short the easiest thing to do would be to probably use the PSU yoiu have in the Rosewill case, sell the case as bnib on eBay/Gumtree etc and be happy, I wouldn't reccommend spending more money.
126 (12.60/day)
Virginia
Cooling Air
Storage 500GB SSD
with my psu
I got the case, because my GPU doesn't' fit into the dell one. I'll just get a new mobo if it doesn't work.
5,658 (1.70/day)
West Midlands. UK.
Is that because of the RAM slots? (just going off the stock picture I have found of your PC)
126 (12.60/day)
Virginia
Cooling Air
Storage 500GB SSD
No, there's a pcie at the bottom of the case, pretty sure.
Just can't fit in, then again, I could just make a cardboard case, if really need to.
5,658 (1.70/day)
West Midlands. UK.
Yes I see that also, but you stated the GPU won't fit, it won't fit in either PCIE slot?
126 (12.60/day)
Virginia
Cooling Air
Storage 500GB SSD
It WOULD fit, but there's not enough space in the case for my huge rx 580
Should've gone for a 1050ti that gets power from the pcie, too late now
