I need help regarding the use of old Mining hardware for a PC build!!
142 (0.19/day)
Ballkans
Here it goes:
I recently built a pc with spare parts from my mining rig(Server psu +PICO 120w)
The pico doesn't have enaugh juice for my cpu.
Is it safe to power the Cpu via a 6pin pcie to 8pin atx adapter directly from the server psu?
Meaning the PIco is only going to provide power to the board's(24pin) while the beeffy server psu does the heavy lifting?
My Components:
Ryzen 9-5950x
RTX 3070
Asrock B550 Phantom itx/ax
64gb Fury
Samsung 980 Evo-(My boot drive)
5TB barracuda
PSU - HP 1200w platinum server PSU (12v only +Breakout board) + (120w Pico PSU)
Full watercooling loop from Alphacool.
My main fear is that there may be some sort of power delay between the two PSUs(Pico and Server PSU) and that might cause problems.
The PICO psu's input is 12v so naturally I got a 6pin pcie to DC Barrel jack adapter that is purposely made for these two PSUs.
40,435 (6.58/day)
It's about current output
578 (0.40/day)
System Name Mini efficient rig.
Processor R9 3900, @4ghz -0.05v offset. 110W peak.
Motherboard Gigabyte B450M DS3H, bios f41 pcie 4.0 unlocked.
Cooling some server blower @1500rpm
Memory 2x16GB oem Samsung D-Die. 3200MHz
Video Card(s) RX 6600 Pulse w/conductonaut @65C hotspot
Storage 1x 128gb nvme Samsung 950 Pro - 4x 1tb sata Hitachi 2.5" hdds
Display(s) Samsung C24RG50FQI
Case Jonsbo C2 (almost itx sized)
Audio Device(s) integrated Realtek crap
Power Supply Seasonic SSR-750FX
Keyboard Redragon K539 brown switches
Software Windows 7 Ultimate SP1 + Windows 10 21H2 LTSC (patched).
Benchmark Scores Cinebench: R15 3050 pts, R20 7000 pts, R23 17800 pts, r2024 1050 pts.
So what you're saying is it doesn't matter if two PSUs are connected to one motherboard as long as current/voltage requirements are met!?
shouldnt be a problem, just make sure to start both psu's at about same time (milliseconds dont really matter). I have personally used twin psu in the past to test some graphics cards (only because i didnt have a proper 500+ W psu at the time lol). Never used such setup on a daily basis tho. One thing to note maybe, as you mentioned an HP server psu and you said its for a pc build, pllease be aware that these are LOUD.. You could probably get a $100-150 seasonic 650-750W psu to put in there and avoid all the extra hassle.
4,403 (3.89/day)
Colorado, U.S.A.
System Name HP Compaq 8000 Elite CMT
Processor Intel Core 2 Quad Q9550
Motherboard Hewlett-Packard 3647h
Memory 16GB DDR3
Video Card(s) Asus NVIDIA GeForce GT 1030 2GB GDDR5 (fan-less)
Storage 2TB Micron SATA SSD; 2TB Seagate Firecuda 3.5" HDD
Power Supply 12V HP proprietary
What about balance? if one power supply has a slightly different output voltage than the other.
487 (0.13/day)
Cyprus
Processor 13700KF - 5.7GHZ
Motherboard Z690 UNIFY-X
Cooling ARCTIC Liquid Freezer III 360 (NF-A12x25)
Memory 2x16 G.SKILL M-DIE (7200-34-44-44-28)
Video Card(s) XFX MERC 7900XT
Storage 1TB KINGSTON KC3000
Display(s) FI32Q
Case LIAN LI O11 DYNAMIC EVO
Audio Device(s) HD599
Power Supply RMX1000
Mouse PULSAR XLITE V2 MINI (RETRO)
Keyboard KEYCHRON V3 (DUROCK T1 + MT3 GODSPEED R2)
Benchmark Scores Superposition 4k optimized - 20652
I don't think it's that simple, from what i remember at least, better look it up to be certain.
As you provide power to the CPU from the one PSU, but power to the motherboard from another it may cause some problems.
40,435 (6.58/day)
Yup, Power (Watts) = Electromotive Force (Volts) x Current or Intensity (AMPS)
phill
15,973 (3.39/day)
Somerset, UK
Power Supply EVGA 1600W T2
Mouse Corsair thingy
VR HMD No headset yet
I'd prefer to just buy a decent PSU and call it a day, especially with the hardware inside the box you have... Just my 2p worth :)
142 (0.19/day)
Ballkans
I was hoping to replace the fan with a noctua one :/
Also I was hoping to go for a ESFF build so I can hide it under my desk .
PS: I think there might be a way to incorporate a solenoid to turn both the PSUs on because unlike my Pico that responds to the motherboard's momentary switch, the HP psu has a switch which is not momentary( it's either ON or OFF but since you've had some experience with dual PSUs I'm more confident that say a 3-5 second delay between the PSUs won't cause any harm.
Well an ATX 1000w+ psu in a 1U FF(40mm) doesn't exist yet!!
But I have seen Breakout boards that come with integrated 300w units which it should be plenty.
phill
15,973 (3.39/day)
Somerset, UK
With the hardware you are running I'd personally just find a decent priced Seasonic/Super Flower PSU and call it a day. I'm sure for mining the breakout boards and such are fine, but I wouldn't want to run my main PC on one...
