- Oct 17, 2014
- 18,076 (4.68/day)
- Kepler-186f
Processor | 7800X3D -25 all core |
Motherboard | B650 Steel Legend (White/Silver) |
Cooling | RZ620 (White/Silver) |
Memory | 32gb ddr5 (2x16) cl 30 6000 (White/Silver) |
Video Card(s) | Merc 310 7900 XT @3100 core -.75v (Black/Silver) |
Display(s) | Agon 27" QD-OLED Glossy 240hz 1440p |
Case | NZXT H710 (Black/Red) |
Power Supply | Corsair RM850x |
The 2010 batman game on Steam/PC, I need help unlocking the fps cap on it. I have done it before in the past, I remember editing two ini files, then you have to go back in and go to properties and set it to read only for the two files you change .ini files in.
So, I know high refresh works in this game, the problem is I forgot the right combination to pull this off. there is the usual defaultengine file, you edit that ctrl find "smooth" and it will take you to the fps area of the ini settings, and then i change it from 62 max fps to 242 max fps to match my monitor, but the problem is I can't remember what to set the minimum or if I am supposed to change the bsmooth feature from TRUE to FALSE or not... I have tried a bunch of combinations, but none of them seem to be working, the game crashes as soon as I try to go past the menu screen.
any help welcome. because this game is amazing at high refresh... bleh, can't believe i forgot how to do it... and yes i already googled it and tried all the steps recommended from those. so frustrating...
store.steampowered.com
the problem is there are a bunch of places to edit the smooth frame cap of 62 and change it to 242, and yes i have tried it on all of them and changed them all to read only, etc. nothing works, so i am missing the right combination...
Batman: Arkham Asylum Game of the Year Edition on Steam
Experience what it’s like to be Batman and face off against Gotham's greatest villians. Explore every inch of Arkham Asylum and roam freely on the infamous island.
