I need your help.sapphire rx 460 2gb single fan original rom.
Discussion in 'AMD / ATI' started by leon, Jul 17, 2017.
  1. leon New Member
    Jul 17, 2017
    4 (0.33/day)
    0
    Hello!I need your help.
    My computer is Black screen.
    I forgot to back up my original bios.
    I need a copy of the sapphire rx 460 2gb single fan original rom.
    thank you very much!!!
  2. erocker
    erocker Senior Moderator Staff Member
    Jul 19, 2006
    42,172 (10.47/day)
    18,116
    There isn't one listed in our database. You will need to contact Sapphire.
    10 Year Member at TPU
  3. 95Viper
    95Viper
    Oct 12, 2008
    5,621 (1.75/day)
    2,611
    στο άλφα έως ωμέγα
    leon and erocker say thanks.
  4. erocker
    Jul 19, 2006
    42,172 (10.47/day)
    18,116
    Ah, I didn't think to look in unverified.
    95Viper says thanks.
  5. leon New Member
    Jul 17, 2017
    4 (0.33/day)
    0
    IMG_5417.JPG I tried a lot of ways, still black screen.
    I use RD Client can see the system to recognize the video card.
  6. MrGenius
    MrGenius
    Feb 2, 2015
    1,137 (1.25/day)
    851
    On The Highway To Hell \m/
    Did you try using a different display output? If that doesn't work, or if you can't try to flash a new BIOS through the RD client, you might have to try blind flashing it. Or using one of the various BIOS chip pin mods(eg. 1+8 pin) to get the card past POST without a black screen.
    leon and 95Viper say thanks.
  7. 95Viper
    95Viper
    Oct 12, 2008
    5,621 (1.75/day)
    2,611
    στο άλφα έως ωμέγα
    If you are posting the pic of the label to get the correct bios... I believe this the proper bios for that card... Sapphire RX 460 2048 MB BIOS
    eidairaman1 and leon say thanks.
  8. leon New Member
    Jul 17, 2017
    4 (0.33/day)
    0
  9. MrGenius
    MrGenius
    Feb 2, 2015
    1,137 (1.25/day)
    851
    Oh...I see what the problem probably is. You probably need a BIOS that supports Micron GDDR5. We don't have any of those here. You should probably contact Sapphire for one.
    You can run this tool to verify that you have Micron memory.
    https://www.techpowerup.com/download/asus-radeon-memoryinfo/
    I noticed you're using the default windows VGA driver. What happens if you try and install an AMD driver?
