- Jun 2, 2017
- 7,922 (3.15/day)
System Name | Best AMD Computer |
Processor | AMD 7900X3D |
Motherboard | Asus X670E E Strix |
Cooling | In Win SR36 |
Memory | GSKILL DDR5 32GB 5200 30 |
Video Card(s) | Sapphire Pulse 7900XT (Watercooled) |
Storage | Corsair MP 700, Seagate 530 2Tb, Adata SX8200 2TBx2, Kingston 2 TBx2, Micron 8 TB, WD AN 1500 |
Display(s) | GIGABYTE FV43U |
Case | Corsair 7000D Airflow |
Audio Device(s) | Corsair Void Pro, Logitch Z523 5.1 |
Power Supply | Deepcool 1000M |
Mouse | Logitech g7 gaming mouse |
Keyboard | Logitech G510 |
Software | Windows 11 Pro 64 Steam. GOG, Uplay, Origin |
Benchmark Scores | Firestrike: 46183 Time Spy: 25121 |
I had zero interest in water cooling until AIOs came out. My favourite AIO was the Cooler Master Nepton 280 but I had to change the fans to some Phanteks radiator fans because of noise. A few years later I happen to get the Thermaltake Core X9 case and as such look for an AIO that is worthy of the case. I find the Alphacool Eisbear 420 AIO for $134.99 Canadian and absolutely loved the design and performance (once I changed the fans to some Noctua Redux). I made a bone head move and broke one of the quick connect connectors so I had to order another one. I went on AquaTuning and found a B grade 420 AIO for $85 US there were some parts missing but it did what I wanted.
I bought the Sapphire Vega 64 Nitro card but there was an issue. The fans would not spin up and there was no software that would control the fans. I was not a fan of that because the heat coming from the PC would make the fans spin at 80 to 90 percent to try to keep the card under 75C and turn off when the GPU (alone) went to 55 C. Needless to say it was not conducive to Gaming while the wife was trying to sleep on a Friday night. I had a 420MM rad sitting around, so I bought a block (Byiski)and 2 quick connect cables and watercooled my GPU. I added a reference Vega 64 and used the Alpahcool Eiswolf with the Eisstation to cool 2 GPUS. I recently added this unit to act as a reservoir and extra pump
I upgraded to X399 a couple years ago and thought that the block on the Eisbear would cover the IHS and it does but not 100%. I ended up getting the Noctua TR14 DH14 (I think) and that is a great cooler but the RAM clearance issues on some Air coolers is something I forgot about. RAM has fallen quite nicely in price so I wanted to upgrade to some faster RAM. I could only add 1 stick to each DIMM bank. I mentioned in a thread that I was looking for a block and someone recommended against using acrylic. I was intrigued so I did some research but I settled on.
I will probably for now just create the loop with the CPU block, another Eistation and 420MM rad. I am using the Corsair XL5 coolant (It was the only one at the computer store close to me).
Everything should arrive by Friday. We are supposed to get a huge snow storm on Saturday so I think I already know what I will be doing.
Alphacool 13297 Eisstation DC-Ultra incl. Alphacool DC-LT 2600 Ultra Pump Water Cooling Reservoirs : Amazon.ca: Electronics
www.amazon.ca
Alphacool
Alphacool Eisblock XPX Pro U1 für LGA 3647, 2066 und TR4 optimierter CPU Wasserkühler. Ideal für 1HE, 2HE und 3HE Server Racks.
www.alphacool.com
Alphacool Eisbaer GPX Extension Set (Schlauch und Anschlüsse)
Mit dem Eisbaer Quick-Connect Extension Set lässt sich der Kreislauf eines Eisbaer oder Eiswolf GPX-Pro Kühlers spielend leicht um weitere Komponenten erweitern. Zum Beispiel mit einem weiteren Radiator, einem weiteren Kühler oder...
www.alphacool.com
