I5 2500K Upgrade - R5 3600 - x470 - Quick look over parts please.
681 (0.21/day)
coventry UK
System Name Gwafwar
Processor Ryzen 5 3600
Motherboard Msi MPG X570 Gaming Plus
Memory 16Gb Adata Spectrix 3600 Cl18
Video Card(s) Palit GTX970 SLI
Storage Adata 512Gb SX8200 pro
Display(s) 3x 27" 1080p Lg's
Case Coolermaster 690 II pure black
Power Supply Coolermaster 750W Masterwatt
Mouse Saitek X65-f HOTAS
Software Win10 Pro
Hello, It's been a while.
I'm set to upgrade my 2500K as it's started suffering from instability, I think I've had my monies worth out of it lol!
I'm looking at moving over into AMD Ryzen 5, But haven't kept up to date with specs and reviews.
This is only for Mobo - CPU - Ram - SSD.
GPU's (2x970), Case, PSU, And all small parts are going to be migrated.
The System needs to be SLI capable.
Ryzen 5 3600 Standard version with standard cooler. My Hyper 212 may get migrated if I can find the parts.
MSI X470 Gaming Plus Max.
Patriot Viper Steel 3200Mhz 16Gb (8x2), Cl 16, 1.35v
Adata XPG SX8200 Pro 512Gb 3.5K read 2.3K write.
If anyone knows why I shouldn't be picking those components pipe up!
Many thanks!
30,425 (6.52/day)
Many thanks!
Make sure the ram is Ryzen compatible
1,027 (1.78/day)
California
System Name His & Hers
Processor i9 9900k @5ghz/ R9 3900X Stock
Motherboard Asus Maximus XI Code/ X570 Aorus Master
Cooling Corsair h150i Pro Push/Pull. 5x Corsair ML120 + 4x Corsair LL120/ Corsair h115i Platinum
Memory 32 GB 4x8GB 3600mhz Corsair RGB Pro/ 32 GB 3200 CL14 @3800 CL16
Video Card(s) Asus ROG Strix 2080 ti/ Titan XP
Storage lots of SSD.
Display(s) Asus ROG PG278QR / MSI 27 inch VA panel.
Case Corsair 500D SE RGB/ Phanteks Evolv X
Audio Device(s) Arctis Pro + gaming Dac/ Corsair sp 2500/ Logitech Z 625
Power Supply Seasonic Ultra Prime Titanium 850w x2
Mouse Logitech G903 Lightspeed/ Logitech G Pro Hero.
Keyboard Corsair K95 RGB Platinum/ Logitech G Pro
looks good if you can step up to the Tomahawk max its a pretty decent upgrade in the VRM department for a usually extra 10-15 more in whatever your local currency is.
3200 is a pretty safe speed on the ram... Some 3600s have an issue 3600 ddr4 and run the IF at half speed.
edit... I see you're looking at an X470 board... Tomahawk is probably better price/perf board depending on how close they're in price. The VRM on the Tomahawk will likely run cooler actually.
681 (0.21/day)
coventry UK
System Name Gwafwar
Software Win10 Pro
Looked at those but the B450 wasn't recommended for SLI, It also has a weaker VRM, Fewer USB, and lacks one m2 slot. Price-wise both are within a beer of each other.
The X470 having 2x PCIE 3 8x8x for sli.
B450 having 1x PCIE 3x and 1x PCIE 2x for 8x4x
It seems like a downgrade to go B450 when the X470 is the same price.
I'll double-check the ram, There's a few in a similar price point. I figured AMD would have got past the Gen 1 memory issues, but it's good to know if they haven't. Corsair LPX 3000mhz is slightly cheaper so I can switch between the 2 on the build if I can't get a decent memory report for the Patriot.
434 (0.52/day)
System Name Silent
Processor i7 8700k delidded and OC'd to 5.2 daily 5.3 benchmarking/R9 3900x
Motherboard Asrock Z370 Extreme 4/MSI MEG ACE x570
Cooling Noctua D15/Noctua U12A
Memory 16GB G-Skill Trident Z RGB 3200 14CAS/32GB Team Dark Pro 3200/14
Video Card(s) 1080ti w/morpheus cooler w/Noctua 140mm fans/Quadro RTX 4000
Storage Optane 905p 480GB, 2 x 1TB 970 Pro Raid 0/Optane 905p 480GB
Display(s) 240hz 1080p/4x1440p 60hz
Case Coolermaster Cosmos C700M
Power Supply Seasonic Prime Titanium 600w Fanless
Benchmark Scores Cinebench 1725
I would recommend x570 so you're set for Zen3.
1,027 (1.78/day)
California
Yeah its a trade off the X470 seems to hit close to 100C on the VRMs with a 2700X overclocked from what I can find online vs The B450 Tomahawk Max that only hits around 80C with an overclocked 3900X which actualy uses more power. Probably why the MSI x470 board is so cheap. I would probably look at something with a 6 phase vrm if you want to stick with x470...
They likely have identical/similar 4 phase vrm but the Tomahawk has a better heatsink from the looks of it.
also SLI is pretty dead and I don't see developers supporting it well in the future.
That's up to you though obviously I think this platform can last long enough to give you another decent upgrade in the future something like a 12 core 4000 chip on the cheap a couple years from now.
681 (0.21/day)
coventry UK
System Name Gwafwar
Software Win10 Pro
It'll last as long as I make it. I'm not one for upgrading at regular intervals. I take my cpu's to the point they struggle before I upgrade.
With that in mind, AM4 will be dead long before I look at a new chip.
To put this into perspective I ran a manchester core socket 939 x2 3800 right up to 2011. So that ran for 7 years, The 2500K has run for 9 years.
I do play games but not high-end ones. ATM I'm playing World of tanks @ 5870x1080 resolution and the computer is absolutely fine just no longer stable. It randomly restarts and I suspect it's a failing memory controller as it just goes dead with no errors. New first-person shooters ect I have absolutely no interest in. In fact, the last true 1st person shooter I played and loved was Unreal Tournament 99.
I'm also not planning on overclocking. None of the current-gen CPU's offer viable overclocking. All of them are running right on the wire with perhaps 2-300 Mhz improvements. The 2500K overclocking was worth it, but the 3600 is a different animal as the power requirements are just exponential for very little gains. The days of the Jiuhb bartons are well and truly gone!
1,027 (1.78/day)
California
Your choice of parts is super solid for your goals and going with a MAX board at the very least is a very smart idea. Price on that X470 boards seems pretty great and its a great fit for the 6 core and 8 core ryzen 3000 chips.
Specifically for gaming you can plop any cpu into that board even a 3950X at stock I was just trying to relay that the vrm on the Tomahawk seems a bit better.
@Iceni How are those 970s holding up? I had a set of MSI gaming ones like 4 years ago I sold due to having issues at 4k with their 3.5GB/.5GB
vram split
The last benchmark I ran on them before selling them off they served me really well for a couple years.
681 (0.21/day)
coventry UK
System Name Gwafwar
Software Win10 Pro
X570 looks great, but I can't see me using any of the overheads it offers. My GPU's should be good for a couple more years for the way I play. Then once they hit the upgrade bench we will probably be seeing the 1st wave of PCIE4 cards that can actually use the bandwidth, It'll then be a couple more years before that moves over into the mainstream. So I'll probably pick up PCIE4 cards at that point, use them bottlenecked for a couple of years then get on the CPU bandwagon again with a new motherboard. Futureproofing doesn't really work with the way I upgrade. I used to do it but I've been caught out far too many times been an early adopter of tech then finding it gets a revision in hardware that fixes some critical bug that all the early adopters then have to live with.
It's far better to just build a solid machine and turn off the features that I see as pointless. (I'm old in computer terms).
If I were looking at a higher spec machine then I would probably go with X570, but I would also be wanting a 12core chip for it. ATM those chips might not end up being the future. And it is absolutely pointless picking up a machine that gives me such a CPU overhead when I'll be gimping it on the GPU's.
For what I do, Absolutely no problems. They get stripped about once a year and rebuild with fresh thermal compound. Outside of that, I don't run a resolution high enough that the V-ram issue has been a problem. Had I gone 4K rather than 3 monitors that might have been different. I wanted the extra width for flight sims and tank games, where the extra width gives a real advantage. 4K at the time of buying my monitors was pretty early, and no one knew if it was going to be anything more than a fad, It was also cheaper to go 3x1080 than 1x4K. The monitors I ended up with were all 27" and all cost about the same as a current low end 28" 4K. Was I buying now my choices might change, but I think it would be hard to give up the advantages 3 monitors has given me.
1,027 (1.78/day)
California
I think you're pretty golden as far as gaming with Zen 2 as both Sony and Microsoft is using it for their next gen systems and we all know Devs target consoles when developing games so you should be fine for the next half decade other than possibly needing more threads at some point depending on what you're doing with the chip.
if you do plan on keeping this system longer than 3 years gen 4 pcie might be a good idea if you plan on upgrading your gpus in the next 3 years at the very least it doesn't hurt to be able to stick substantially faster storage into your system once devs start targeting it with the new consoles and it gets a bit cheaper/better.
There's nothing wrong with grabbing what you need now and adapting when the time comes either because like you said who knows especially with ddr5 likely in the next couple years and 7GBps+ SSD being available and viable from a cost perspective.
681 (0.21/day)
coventry UK
System Name Gwafwar
Software Win10 Pro
I doubt it will be. PCIE4 might look good, and the performance might be incredible. But to get the advantage of it you will need to be running a card that is well out of my budget in 3 years time.
I don't know how many revisions of CPU's and motherboard designs you have lived through but one thing is constant with graphics. The slot comes first with huge overheads, and the first couple of waves of cards that use the new revision don't use the bandwith. It takes GPU's several years to catch up, and start to push into and use what is available.
It'll also be PCIE5 you want to watch. It's a 128bit rather than the 64bit of PCIE4, At 128bit it'll be easier to implement and will probably kill PCIE4 pretty quickly, Not for graphics but for storage.
1,027 (1.78/day)
California
It'll also be PCIE5 you want to watch. It's a 128bit rather than the 64bit of PCIE4, At 128bit it'll be easier to implement and will probably kill PCIE4 pretty quickly.
Yeah, should be interesting even though IPC has somewhat slowed chips are getting wider and storage is getting substantially faster at a decent clip.
I've only been serious into pc hardware for about a decade and have owned 8 different PC from mid range to relatively high end since then but I've also done over 30 builds with the majority coming in the last 3 years.
if you look at 2011 to 2016 mainstream pc were stuck with quads and you had to go with an HEDT chip from intel if you wanted more cores and a typically substantially higher price which I feel limited MC growth substantially when it comes to Games/programs benefiting from increase threads..... Over the last 3 years that has jumped all the way up to 16 cores that nearly match $2000 chips from a couple years ago in performance pretty exciting times..... If you told me I would be able to buy a high performance 12 core cpu for less than 500 in 3 years back in 2016 I would have told you to lay off the drugs.
681 (0.21/day)
coventry UK
System Name Gwafwar
Software Win10 Pro
Hardware works in leaps. It always has.
In the early 2000's I was doing what you are doing now, but we had so much more to play with. You could buy a cheap 1.4ghz chip, whack a huge cooler on it and run over 2ghz. To put that into perspective it's like spending $100 for a $1000 CPU. It was insanely fun, And on more than one occasion I've actually set motherboards on fire!
The past 10 years has been the biggest flat spot in gains on hardware I've ever known. It's about time thing shifted. Once things start to move you won't have enough cash to keep up.
4,260 (0.88/day)
Hurst, Texas
System Name The86
Processor Ryzen 7 1700X
Motherboard ASUS Prime X370 Pro
Cooling Coolermaster Hyper 212 Evo
Memory 2x8gb Patriot DDR4 2666 @ 2933
Video Card(s) Sapphire RX570 Pulse 4gb
Storage Samsung PM841
Display(s) HP 27in
Case Raidmax Alpha Prime
Power Supply 700W Thermaltake Smart
Mouse Logitech Mx510
Keyboard Razer BlackWidow 2012
Software Windows 10 Professional
Well he's right, ago bandwidth wasn't exceeded until gtx200, pcie 1x wasn't to slow until GTX 680, pcie2x was fine until GTX 980ti.
I remember way back testing a 6800gt on an ago 4x vs 8x board and their was no difference, and agp 8x is the same speed as pcie 8x which was fine until SLI gtx280
681 (0.21/day)
coventry UK
System Name Gwafwar
Software Win10 Pro
I ran AGP until 2011. Was running an ATI X1950pro AGP lol. Only 9 years ago. It was on it's knees by the end!
5,154 (0.92/day)
Formosa
System Name Overlord Mk MXVI
Processor AMD Ryzen 7 3800X
Cooling Corsair H115i Pro
Memory 32GB Viper Steel 3600 DDR4 @ 3800MHz 16-19-16-19-36
Video Card(s) Gigabyte RTX 2080 Gaming OC 8G
Storage 1TB WD Black NVMe (2018), 2TB Viper VPN100, 1TB WD Blue 3D NAND
Display(s) Asus PG27AQ
Case Corsair Carbide 275Q
Power Supply Corsair RM750
Mouse Logitech G500s
Keyboard Wooting Two
Benchmark Scores https://valid.x86.fr/ztiub6
The Patriot Viper RAM should work fine. I'd steer clear of the LPX modules as there are too many revisions and some don't work well with Ryzen.
5,017 (1.14/day)
Australia
Processor AMD R7 2700X | Ryzen 1600X | i7 970
Cooling AMD Wraith cooler| Stock Cooler, Copper Core)| Big shairkan B
Video Card(s) ASUS GTX 970 OC in Sli | Inno3d GTX 1050 TI | MSI RX 580 8GB
Storage 250GB Plextor SSD Por 5 /1TB WD Black | 500GB SSD WD, 2x1TB, 1x750 | WD 320/Seagate 320
Power Supply Silverstone 750 | Silverstone Mini 450W | Corsair CX-750
Software Windows 7 Pro 64 | Windows 7 Pro 64 | Windows 7 Pro 64/Windows 10 Home
If you look at my system specs you will see what I run which is very much what you want to upgrade to and it supports W7 if you intend to use it as well.
Sli/W7 compatible Mobo X470 Gaming Pro Carbon
2x8GB DDR4 3600Mhz RAM
SLi 970's
4,260 (0.88/day)
Hurst, Texas
System Name The86
Display(s) HP 27in
SLi 970's
Do not run 7, it's unsupported and there are already exploits that are published that won't be fixed. That's like sticking a sign in your yard that says rob me I'm a passifist and I won't resist.
5,017 (1.14/day)
Australia
Dont read into the BS dude, its perfectly fine and Ive been running it for yrs on Ryzen without any issues, been rock solid! and I still get updates for it.
30,425 (6.52/day)
Corsair, go to their website and verify it, they were the worst in compatibility.
4,260 (0.88/day)
Hurst, Texas
System Name The86
Display(s) HP 27in
yea as a sys admin, its no longer supported by Microsoft, it no longer gets updates unless your a software assurance partner, it's like playing russian roulette with all 6 chambers loaded
253 (0.10/day)
Denmark
System Name R7 3800x@4525MHz/E5800@4GHz/Skylake 6400
Processor R7 3800x/E5800/i5 6400
Motherboard Gigabyte Master X570/Asus P5QL-EM/Asus Z170 Pro Gaming
Cooling Noctua NH15D-SE/Zalman 9500 series/Stock
Memory 16GB CMK16GX4M2B3600C18 CL14/Kingston HyperX PC8500 - 4GB/G.Skill Ripjaws 32 GB F4-3200C16D-32GV
Video Card(s) R7/HD7800XT / R290X
Storage Aorus 2TB Corsair MP600 + 960 Evo 1TB/Seagate 7200 series 12, 11, 10 and 9 / 2xSamsung EVO 850 500GB
Display(s) 2x Acer P243w and 1 Acer G245h in the midle
Case Custom builds
Audio Device(s) -
Power Supply Silverstone 850watt modular Gold/Gold Silverstone 850watt/1000Watt Antec
Software win10pro / Win10 Home / win7 / wista 64 bit and XPpro
I have the VIper 4000mhz kit and it is Samsung B-die , would take them if its not to much more
5,852 (1.11/day)
USA
System Name Small ATX Desktop
Processor Intel i5 8600K
Motherboard Asrock Z370 Taichi
Cooling Phanteks PH-TC14PE CPU HSF, Arctic MonoPlus VGA HSF
Memory G-Skill TridentZ 2X8GB F4-3200C14D-16GTZ
Video Card(s) Zotac 1060 6GB Mini ZT-P10600A-10L
Storage Samsung 970 Pro 512GB NVMe, Phison E12 NVMe 1TB, 1xWD4005FZBX, 2xWD10EZEX
Display(s) Dell S3220DGF 32" 2560x1440 165Hz
Case Lian Li PC A05NB
Audio Device(s) Audiotechnica ATH M50X, Antlion Mod Mic 4, SYBA SD-CM-UAUD
Power Supply Seasonic SS-660XP2 660 Watt Platinum
Mouse Zowie EC2A Mouse on Corsair MM600
Keyboard Filco Majestouch II Ninja TKL
Software Win 10 LTSC 1809
30,425 (6.52/day)
They should of never changed what worked from 3.1 to 7, how everything was laid out...
If anything phone editions should of stayed closer to desktop model than being a copycat of Android/iOS
5,017 (1.14/day)
Australia
Just like Windows 8 and XP and do you ever hear or anyone having issues? nope, again dont read into it and all my W7 PC's (10) are still getting updates and Im not a partner.
