System Name | Sunk Cost Fallacy |
Motherboard | ASRock B650E Steel Legend Wifi |
Cooling | Arctic Liquid Freezer II 360 Rev. 7 |
Memory | 2x16GB G.Skill Trident Z5 NEO 6000 CL30 |
Video Card(s) | Sapphire Nitro+ RX 7900 XTX Vapor-X |
Storage | WD Black SN850X 1TB + 2x 2TB, 2x 4TB Crucial MX500, 4TB Samsung 870 Evo. |
Display(s) | Alienware AW2723DF, LG 27GR93U, LG 27GN950-B |
Case | Lian Li O11 Air Mini |
Audio Device(s) | Bose Companion Series 2 III, Sennheiser GSP600 and HD599 SE - Creative Soundblaster X4 |
Power Supply | bequiet! Dark Power Pro 12 1500w Titanium |
Mouse | Logitech GPRO X Superlight & G502 X |
Keyboard | Corsair K65 RGB Mini, Razer Black Widow V3 TKL |
VR HMD | Oculus Rift S |
5.1 is not stable enough to run more than 4-5 rounds.@GerKNG Now loop that for 30mins.
System Name | Mean machine |
Processor | 13900k |
Motherboard | MSI Unify X |
Cooling | Noctua U12A |
Memory | 7600c34 |
Video Card(s) | 4090 Gamerock oc |
Storage | 980 pro 2tb |
Display(s) | Samsung crg90 |
Case | Fractal Torent |
Audio Device(s) | Hifiman Arya / a30 - d30 pro stack |
Power Supply | Be quiet dark power pro 1200 |
Mouse | Viper ultimate |
Keyboard | Blackwidow 65% |
System Name | The work PC /2700x/5950x |
Processor | 3900X stock/ 2700x stock/ 5950x 4200 MHz fixed @ 1,056-1,08V |
Motherboard | Gigabyte AORUS Master X570/2xMSI X470 M7 AC |
Cooling | Custom WC XSPC RX480, Laing DDC, XSPC Laing DDC Top V3 and EK Velocity/NH15/NH-U12S SE |
Memory | 32 GB Viper 3600/14 /16 GB Trident Z F4-4000C18D-16GTZSW 3600 /32 GB G Skill Flare CL14 3400 |
Video Card(s) | 2070 Super X MSI/GTX 970 MSI/ GTX 970 MSI |
Storage | 1 TB SSD+500 GB NVMe / 500 GB SSD/ 500 GB SSD |
Display(s) | Dell UltraSharp U2518D/2408WFP |
Case | Corsair 800D / Lian test bench/NZXT 500 |
Power Supply | AX 850 Titanium/AX 860i/AX 760 |
Software | Dual boot/Win 7 & 10 / Linux / Win 10 |
Processor | Intel Core i9-14900KF |
Motherboard | Asus Maximus Z790 Apex |
Cooling | Full Custom Water |
Memory | 48GB DDR5 |
Video Card(s) | Nvidia RTX 3090 FE |
Storage | Crucial T700 2TB Gen5 SSD |
Display(s) | Asus PG27AQDM |
Case | Primochill Praxis WetBench |
Audio Device(s) | SteelSeries Arctis Pro |
Power Supply | SeaSonic Prime TX-1600 |
Mouse | G502 Lightspeed |
Keyboard | Ducky MIYA Pro |
Software | Windows 11 Pro 23H2 |
Benchmark Scores | http://www.3dmark.com/spy/46650491 http://www.3dmark.com/fs/31566677 |
Thank for sharing this. I will use this in my segue so we can all end this debate about Alder Lake cooling.5.1 is not stable enough to run more than 4-5 rounds.
5Ghz is fine and goes up to ~80°C
Processor | 13700KF Undervolted @ 5.6/ 5.5, 4.8Ghz Ring 200W PL1 |
Motherboard | MSI 690-I PRO |
Cooling | Thermalright Peerless Assassin 120 w/ Arctic P12 Fans |
Memory | 48 GB DDR5 7600 MHZ CL36 |
Video Card(s) | RTX 4090 FE |
Storage | 2x 2TB WDC SN850, 1TB Samsung 960 prr |
Display(s) | Alienware 32" 4k 240hz OLED |
Case | SLIGER S620 |
Audio Device(s) | Yes |
Power Supply | Corsair SF750 |
Mouse | Xlite V2 |
Keyboard | RoyalAxe |
Software | Windows 11 |
Benchmark Scores | They're pretty good, nothing crazy. |
To sum this up. It takes X amount of time for a material to reach its absorption limits (or thermal soak) before that energy in the form of heat must be expel by other means. A single benchmark run is not a good indication of thermal cooling capacity. Simply put, those who put screenshots of a high overclock with a single short benchmark and say a air-cooler or AIO is fine, is just wrong. That of course depends on the target wattage and application.
Processor | i7 8700k 4.6Ghz @ 1.24V |
Motherboard | AsRock Fatal1ty K6 Z370 |
Cooling | beQuiet! Dark Rock Pro 3 |
Memory | 16GB Corsair Vengeance LPX 3200/C16 |
Video Card(s) | ASRock RX7900XT Phantom Gaming |
Storage | Samsung 850 EVO 1TB + Samsung 830 256GB + Crucial BX100 250GB + Toshiba 1TB HDD |
Display(s) | Gigabyte G34QWC (3440x1440) |
Case | Fractal Design Define R5 |
Audio Device(s) | Harman Kardon AVR137 + 2.1 |
Power Supply | EVGA Supernova G2 750W |
Mouse | XTRFY M42 |
Keyboard | Lenovo Thinkpad Trackpoint II |
Software | W10 x64 |
that's absolutely no Problem.
My NH D15 has zero problems cooling my 10900k at 5.1 Ghz (that pulls almost 260W in R23)
and my 12600k at 5.1 Ghz (with a way higher thermal density) runs at around 90°C because of the almost 1.45V
cooling the 12600k at a reasonable 4.9 GHz (around 150W... what you said is "not easy on any air cooler at all") sits in the LOW 60s even after a 30 Minute loop and barely audible fans set to a bit above 1100 RPM.
Edit: 90°C... not 80.
Until you hit a hot summer day and you just happened to do some CPU heavy task. The problem is the burst temp you might exceed momentarily. You simply need some headroom with every OC, why not lose the last 200mhz because they evidently don't give you much of an advantage at all - its just there so you can say 'look, it goes up to eleven'.tldr; going beyond the limits of your cooling solution in a unrealistic stress test (prime 95) is fine as long as you don't run prime 95 for a living.
Mouse | Xlite V2 |
You are correct on Intel CPUs in shorter bursts AND with the thinner IHS the more recent gens have. But if you are unlucky in the lottery, your IHS contact can still be below par, you can still have an uneven heatspreader, you can still get a CPU that wants more volts for X frequency, etc. etc. My data comes from the worst-case situation of >4 cores and A. no soldered IHS and B. the thicker IHS Coffee Lake still had. But also: we're still talking fundamentally about Intel Core architecture and the node hasn't really changed its limitations - not in the least because Intel seems adamant to clock it way out of its comfort zone. It may need less volts under 5 Ghz, but go above and you're pulling more watts through a smaller node that has even more cores. That's why the top end SKUs barely perform better in net/real-use cases and are in general utterly pointless on any MSDT platform. But hey, epeen wants epeen stuff... even in a crossover gen to DDR5 where more bandwidth gets unlocked over dual channel.
Basically what I'm seeing on 1.35V is representative of a shitty ADL bin, and yes they happen on K CPUs because Intel is still producing monolithic large dies that still vary in quality quite a bit. This is part of the reason Ryzen has little trouble equalling ADL perf within a tighter wattage range, 241W is unheard of in that camp.
Devil is always in the details, its about reading the numbers right and applying historical context
Another bit of context is that you are cooling a 12600k. Not a 12900k.
And let's be realistic here. 200mhz on 5000 is what... 4%? If that's two FPS in a game, we're optimistic, but in 99% of all use cases its not even that, the GPU limits you earlier. For most other applications you might count that advantage in seconds on a full day.
Its very curious how the sentiment with some overclockers radically changed over the last five or seven years in this regard. Leaving headroom for your 24/7 OC was always good practice but somehow ever since AVX offsets got introduced and AVX started killing Intel's advertised frequencies, people have turned to your reasoning. Its hilarious.
Its all show, and utter BS to say you can get a higher frequency. But the OC is not stable. Its simply what it is, and it will bite you in the ass sooner or later. CPU loads increase over time, and degradation (even ever so slightly) does occur over time. No headroom is a recipe for troubleshooting later down the line - especially if you're not swapping every other gen.
But- that's just my opinion. OC your CPU wherever you want, its your silicon But I've seen too many topics of people mimicking some Youtuber and then left to wonder why everything doesn't seem to line up. Case in point... this topic.
Your screenshot shows a minimum CPU package temperature of just 12°C, do you bench outside or chill your water below room temperature?With i9-12900K PL2 @ 200W, MORA 420 Pro cooling,.. running R23 my CPU will get up to 67c.
It's vary unlikely the Corsair H150i will shed the temps this chip generates at full load drawing 200W,.. your going to be fine however in most cases.
This chip does indeed run vary hot at full load,.. even with a custom loop.
Processor | Intel core i9 13900ks sp117 direct die |
Motherboard | Asus Maximus Apex Z790 |
Cooling | Custom loop 3*360 45mm thick+ 3 x mo-ra3 420 +Dual D5 pump and dual ddc pump |
Memory | 2x24gb Gskill 8800c38 |
Video Card(s) | Asus RTX 4090 Strix |
Storage | 1TB Samsung 860Evo,2*2tb Samsung 970Evo Plus, 1tb Intel 660p nvme |
Display(s) | Sammsung G7 32” |
Case | Dynamic XL |
Audio Device(s) | Creative Omni 5.1 usb sound card |
Power Supply | Corsair AX1600i |
Mouse | Model O- |
Keyboard | Hyper X Alloy Origin Core |
He put the Mora outside his house and it was snowing I guess.Your screenshot shows a minimum CPU package temperature of just 12°C, do you bench outside or chill your water below room temperature?
My package usually has minimum temperature of ~28°C under comfortable ambient conditions (at 23°C room temp.), which will be the case for most people I think. That means for comparison one roughly has to add the difference between ambient/initial temperature (~16°C) to all of your values. I.e., your max temp. under most people's ambient conditions would be more like ~83°C instead of ~67°C, at least if you do not want to wear a jacket while gaming.
Cooling performance has always to be judged according to DeltaT above ambient, never according to absolute T values. People should always give DeltaT or at least mention the ambient temperature, otherwise the values are basically meaningless.
If it weren't the board, I wouldn't have 1.45v being thrown into the processor at random times when it should never be going past 1.3. I don't disagree that these processors run hot AF regardless, but the boards are NOT optimized for them and it is unquestionably a large part of the heat issues. Not to mention I have seen tons of people with 12900s playing BF and other games running in the mid 40s while playing. This is 20 degrees cooler than mine. I have also reseated the waterblock on the CPU twice with no change whatsoever. It is 90% the board and 10% the processor.It's not the boards, its the 12900k. I have a asus z690-a board and 12700k and i have no problems, custom loop too.
I have tried it. I set it to 1.35v just to test and it didn't give a crap, my vcore was still going to 1.45v.Have you tried a manual voltage? then look to see if it exceeds that? On my board there is a place you can set the max voltage, i have set it at 1.29v for mine, i can pop in my bios and find it, and post you a pic of it if you like?
Case | Dynamic XL |
Mouse | Model O- |
Case | Dynamic XL |
Mouse | Model O- |
@mrthanhnguyen Your only pulling 183 watts. 43c is good, but not crazy lower considering the power draw
Memory | 7600c34 |
Mouse | XTRFY M42 |
Well, just received my ddr5 and... As i was saying, the temperatures are nowhere near what the reviews are claiming. Got a u12a single tower cooler, hitting around 70 to 72 in cbr20 and 77 on cbr23. In gaming... Its usually at 50c, maybe 60 if i try cyberpunk at 720p with a 3090.
So yeah... As i was saying for 5 posts and random users kept telling me i was wrong...
